Momed80
150
35,046
ROPA Harvester Keiler 2 (RK22) (2023-) Spare Parts Catalog
Brand: ROPA
Type of Machine: Harvester, Potato Technology
Model: ROPA Keiler 2 (RK22) (2023-) Harvester
Year of Manufacture: 2023-
Number of Pages: 1926 Pages
Ropa Keiler 2 (RK22) (2023-)
0 Cover Ropa Keiler 2 (RK22) (2023-)
01 - Pickup
01.01 - Ridge pickup
01.01 - E5223001 Pickup - depth guide
01.02 - E5223002 Pickup - ridge roller frame with bearing and angle sensor
01.03 - E5223003 Pickup - ridge roller with bearing
01.04 - E5223004 Pickup - haulm extraction rollers
01.05.1 - E5215008 Pickup - frame with share blade (single section) and attached parts
01.05.2 - E5215005 Pickup - frame with share blade (two sections) and attached parts
01.05.3 - E5215009 Pickup - frame with share blade (three sections) and attached parts
01.06 - E5215006 Pickup - left, right and centre retainer rubber
01.07 - E5223005 Pickup - disc coulter
01.08 - E5223029 Pickup - wiring harness - ridge pickup
Special equipment
01.10 - E5223006 Model pickup - disc coulter left with hydraulic drive
01.11 - E5223007 Pickup variant - right disc coulter with hydraulic drive
01.12 - E5223008 Pickup variant - disc coulter right with additional disc coulter
01.13 - E5223009 Model pickup - central disc coulter with hydraulic drive
01.14.1 - E5215012 Pickup model - central share 75 cm
01.14.2 - E5215752 Variant pickup - adjustable central share 75 cm
01.15.1 - E5215013 Pickup model - central share 90 cm
01.15.2 - E5215753 Variant pickup - adjustable central share 90 cm
01.16.1 - E5215662 Pickup version - with Robalon share blades (75 cm row width)
01.16.2 - E5215750 Pickup version - with Robalon share blades (90 cm row width)
01.17 - E5215690 Pickup variant - spring relief for ridge drum
01.18 - E5215720 Pickup version - with share carrier-stone protection
01.19 - E5215721 Pickup version - share carrier-stone protection model with overload protection
01.20 - E5215745 Variant pickup - hollow disc
01.21 - E5215751 Variant pickup - central wheel
01.21 - E5215775 Variante Aufnahme - Mittenrad
01.02 - Swath pickup with share carrier shaft-share blades
01.01 - E5223010 Swath pickup - frame with support wheels (mechanical)
01.01 - E5223025 Swath pickup - frame with support wheels (hydraulic)
01.02 - E5215202 Swath pickup - frame with share blades (single section) and attached parts
01.03 - E5223011 Swath pickup - frame with disc coulter
01.04 - E5223028 Swath pickup - frame with Vulkollan rods and hooks
Special equipment
01.10 - E5215722 Pickup version - with share carrier-stone protection
01.11 - E5215723 Pickup version - share carrier-stone protection model with overload protection
01.03 - Swath pickup with lifting shaft cover belt
01.01 - E5223012 Swath pickup - frame with support wheels (mechanical)
01.01 - E5223026 Swath pickup - frame with support wheels (hydraulic)
01.02 - E5215212 Swath pickup - frame with attachments
01.03 - E5223013 Swath pickup - frame with lifting shaft
01.04 - E5215214 Swath pickup - gears for lifting shaft
01.05 - E5215215 Swath pickup - cover belt frame with attachments
01.06 - E5215216 Swath pickup - clamping frame with support rollers
01.07 - E5223014 Swath pickup - cover belt drive
01.08 - E5215218 Swath pickup - cover belt
01.09 - E5223036 Swath pickup - wiring harness - swath-pickup
Special equipment
01.10 - E5223015 Model - swath pickup-channel tapering
01.04 - Swath pickup with carrot share
01.01 - E5223016 Swath pickup - frame with support wheels (mechanical)
01.02 - E5215206 Swath pickup - frame with carrot shares and attachments
01.03 - E5223017 Swath pickup - frame with disc coulter
01.04 - E5223027 Swath pickup - frame with wiper rubber and hooks
Special equipment
01.10 - E5215590 Pickup model - central disc coulter with mechanical drive
01.05 - Pickup without ridge rollers
01.01.1 - E5215525 Pickup - frame with support wheel left
01.01.2 - E5215526 Pickup - frame with support wheel right
01.02.1 - E5223018 Pickup - hydraulic cylinder for support wheel left
01.02.2 - E5215543 Pickup - hydraulic cylinder for support wheel right
01.03.1 - E5223019 Pickup - keys for height and steering - part 1
01.03.2 - E5223020 Pickup - keys for height and steering - part 2
01.04 - E5223021 Pickup - retaining flap, movable
01.05 - E5215530 Pickup - haulm extraction rollers
01.06.1 - E5215531 Pickup - frame with share blade (single section) and attached parts
01.06.2 - E5215532 Pickup - frame with share blade (two sections) and attached parts
01.06.3 - E5215533 Pickup - frame with share blade (three sections) and attached parts
01.07 - E5215534 Pickup - left, right and centre retainer rubber
01.08 - E5223035 Pickup - wiring harness - pickup w_o ridge rollers
Special equipment
01.10 - E5223022 Model pickup - disc coulter left with hydraulic drive
01.11 - E5223023 Pickup variant - right disc coulter with hydraulic drive
01.12 - E5215538 Pickup variant - disc coulter right with additional disc coulter
01.13 - E5223024 Model pickup - central disc coulter with hydraulic drive
01.14.1 - E5215540 Pickup model - central share 75 cm
01.15.1 - E5215541 Pickup model - central share 90 cm
01.06 - All-round pickup
01.08.1 - E5223030 Pickup - frame with support wheel left
01.08.2 - E5223031 Pickup - frame with support wheel right
01.09.1 - E5223032 Pickup - hydraulic cylinder for support wheel left
01.09.2 - E5223033 Pickup - hydraulic cylinder for support wheel right
01.10 - E5223034 Pickup - wiring harness - all-round pickup
Special equipment
01.12 - E5223040 Model pickup - central disc coulter with hydraulic drive
01.13 - E5223041 Variant pickup - central wheel
Hydraulics pickup
01.01 - E5223180 Connection raise and lower pickup for pickup with ridge rollers
01.02 - E5223181 Connection raise and lower pickup for pickup without ridge rollers
01.03 - E5223182 Connection for lifting depth guide
01.04 - E5223183 Connection drive cover belt and lifting shaft with swath pickup
01.05 - E5223184 Connection support wheel for swath pickup
01.06 - E5223185 Connection support wheel & retaining flap for pickup without ridge roller
01.07 - E5223186 Connection support wheel for all-round pickup
01.08 - E5223187 Connection driven disc coulter right for pickup with ridge roller
01.09 - E5223188 Connection driven disc coulter - left & right on pickup with ridge roller
01.10 - E5223189 Connection driven disc coulter - left & right on pickup without ridge roller
01.11 - E5223190 Connection driven disc coulter left, right and middle for pickup with ridge roller
01.12 - E5223191 Connection driven disc coulter left, right and middle for pickup without ridge roller
02 - Sieving channel
02.01 - Sieving channel (model without lifter chain)
02.01 - E5215724 Raise and lower sieving channel front section with cylinder
02.02 - E5223051 Sieving channel front section with thrust rod
02.03 - E5223052 Sieving channel front section with side guide arm and angle sensor
02.04 - E5223053 Sieving channel front section - shaker drive
02.05 - E5215730 Sieving channel front section - vibrator shaft and belt tensioner with support rollers
02.06 - E5223054 Sieving channel front section - supporting rollers on frame
02.07 - E5215734 Sieving channel rear - sieve conveyor 1 and 2 drive
02.08 - E5215738 Sieving channel - transfer roller, belt tensioner and leaf removal rod
02.09.1 - E5215029 Sieving channel rear - support rollers on frame - part 1
02.09.2 - E5215030 Sieving channel rear - support rollers on frame - part 2
02.10 - E5223055 Sieving channel rear - attached parts on frame
02.11 - E5215038 Sieving channel rear - side cover right-front
02.12 - E5215039 Sieving channel rear - side cover right-centre
02.13 - E5215040 Sieving channel rear - side cover right-rear
02.14 - E5215032 Sieving channel rear - sieve conveyor 1
02.14 - E5215771 Siebkanal-Vorderbau - Siebkette 1 - Verschluss-Variante A
02.15 - E5215033 Sieving channel rear - sieve conveyor 2
02.16 - E5223059 Sieving channel rear - leaf chain
Special equipment - sieve channel without lifter chain
02.20 - E5215035 Model of rubber paddle roller
02.21 - E5215036 Clod breaker model - sieve conveyor 1 and 2
02.22 - E5215037 Transition lock model - sieving channel rear
02.23 - E5215735 Sieving channel-front end version - cleaning roller
02.24 - E5215737 Sieving channel-front end version - cleaning roller (retractable)
02.02 - Sieving channel (model with lifter chain)
01.04.1 - E5223056 Sieving channel front section - shaker drive
02.04.2 - E5215729 Sieving channel front section - drive lifter chain and belt tensioner
02.05 - E5215731 Sieving channel front section - vibrator shaft and belt tensioner with support rollers
02.06 - E5223057 Sieving channel front section - supporting rollers on frame
02.07 - E5215749 Sieving channel rear - sieve conveyor 1 and 2 drive
02.14 - E5215740 Sieving channel front section - lifter chain and sieve conveyor 1
02.14 - E5215772 Siebkanal-Vorderbau - Rodekette und Siebkette 1 - Verschluss-Variante A
Special equipment - sieve channel with lifter chain
02.23 - E5215736 Sieving channel-front end version - cleaning roller
Hydraulics sieving channel
02.01.1 - E5223201 Connection sieving channel front section and vibrator drive - part 1
02.01.2 - E5223202 Connection sieving channel-front section - part 2
02.01.3 - E5223203 Connection sieving channel-front section - part 3
02.02.1 - E5223204 Connection drive shaker and sieve conveyor 1
02.02.2 - E5223205 Connection drive shaker, lifter chain and sieve conveyor 1
03 - Separation units
03.01 - E5223081 Side section right-rear
03.02 - E5223082 Side section left-rear
03.03.1 - E5223083 Leaf removal rods, support rollers and scraper
03.03.2 - E5215196 Additional leaf removal rod (optional)
03.03.3 - E5223084 Transfer roller and and carrier for rubber
03.04.1 - E5223085 Drive unit
03.04.2 - E5223086 Leaf separation central lubrication
03.05 - E5223087 Side cover - right
03.06 - E5223088 Rear rubber wall, side rubber and leaf deflector rubber
03.07 - E5223090 Rear cover, rear apron and rear view camera
Hydraulics separation units
03.01.1 - E5223235 Connection drive sieve conveyor 1 and 2 without lifter chain
03.01.2 - E5223236 Connection drive sieve conveyor 1 and 2 with lifter chain
03.02 - E5223237 Leaf chain drive connection
03.03 - E5223238 Connection drive deflector roller 1 (up to ch.no. 2S0926)
03.03 - E5223282 Connection drive deflector roller 1 (from ch.no. 2S0927)
03.04 - E5223239 Connection drive-deflector roller 2 - 2-part
03.04 - E5223240 Connection drive-deflector roller 2 - 3-part
03.05 - E5223285 Connection drive deflector roller 4
03.06 - E5223241 Connection drive pintle 1 and 2
03.07 - E5223242 Connection cylinder - height adjustment pintle 1 and 2
03.08 - E5223247 Connection drive - pintle 3 and deflector roller 3
03.09 - E5223248 Connection drive - pintle 4 and deflector roller 4
03.10 - E5223249 Connection drive - pintle 4 and UFK finger conveyor 1 and 2
03.11 - E5223250 Connection cylinder - height adjustment pintle 4 and UFK
03.12 - E5223254 Connection drive soil removal belt and transfer shaft and lines rear-left
Special equipment
03.01 - Version - double UFK with trash conveyor
03.02 - Version - double UFK without trash conveyor
Leaf spring units
03.08 - E5223091 Leaf spring unit front - part 1
03.09 - E5223092 Leaf spring unit front - part 2
03.10 - E5223093 Leaf spring unit front - part 3
03.11 - E5223094 Leaf spring unit rear - part 1
03.12 - E5223095 Leaf spring unit rear - part 2
03.13 - E5223096 Leaf spring unit rear - part 3
03.14 - E5223097 Leaf spring unit rear - part 4
Pintle belt 1 (only with double UFK model)
03.18 - E5215665 Pintle 1 - support frame with attachments and support rollers
03.19 - E5223147 Pintle 1 - frame with attached parts
03.20 - E5215667 Pintle belt 1 - frame with support rollers
03.21 - E5215668 Pintle belt 1 - drive unit
03.22 - E5215062 Pintle 1 - pintle belt
03.23 - E5215669 Pintle 1 - rocker and drive of deflector roller 1
03.24 - E5215670 Pintle 1 - drive and bearing of discharge roller 1
03.25 - E5215065 Pintle 1 and 2 - height adjustment
Pintle belt 1 (standard version)
03.18 - E5223104 Pintle 1 - support frame with attachments and support rollers
03.19 - E5223105 Pintle 1 - frame with attached parts
03.20 - E5223106 Pintle belt 1 - frame with support rollers
03.21 - E5223107 Pintle belt 1 - drive unit
03.23 - E5223108 Pintle 1 - rocker and drive of deflector roller 1
03.24 - E5223109 Pintle 1 - drive and bearing of discharge roller 1
03.25 - E5223283 Pintle belt 1 - 4 deflector roller
03.26 - E5223110 Pintle 1 and 2 - height adjustment
Pintle belt 2 (standard version)
03.26 - E5223117 Pintle 2 - frame with attached parts
03.27 - E5223118 Pintle 2 - frame with support rollers and clamping frame
03.28 - E5223119 Pintle belt 2 - drive unit
03.29 - E5215069 Pintle 2 - pintle belt
03.30.1 - E5223120 Pintle 2 - drive and bearing of discharge roller 2 - 2-part
03.30.2 - E5223121 Pintle 2 - drive and bearing of discharge roller 2 - 3-part
Pintle belt 2 and UFK (only for double UFK model with trash conveyor)
03.26.1 - E5215671 Pintle 2 - frame with attached parts - part 1
03.26.2 - E5223148 Pintle 2 - frame with attached parts - part 2
03.27 - E5215673 Pintle 2 - frame with support rollers and clamping frame
03.28 - E5215674 Pintle belt 2 - drive unit
03.29 - E5215675 Pintle 2 - pintle belt
03.30 - E5215676 Pintle 2 - drive and bearing of discharge roller 2
03.31 - E5215677 UFK - frame with support rollers
03.32 - E5215678 UFK - frame with covers
03.33 - E5223149 UFK - drive unit
03.34 - E5215680 UFK - finger band 1
03.35 - E5215681 UFK - finger band 2
Pintle belt 2 and UFK (only for double UFK model without trash conveyor)
03.26.1 - E5223265 Pintle 2 - frame with attached parts - part 1
03.26.2 - E5223266 Pintle 2 - frame with attached parts - part 2
03.27 - E5223267 Pintle 2 - frame with support rollers and clamping frame
03.28 - E5223268 Pintle belt 2 - drive unit
03.29 - E5223269 Pintle 2 - pintle belt
03.32 - E5223270 UFK - frame with covers
Pintle belt 3 (only with double UFK model)
03.36 - E5223217 Pintle 3 - frame bottom with attached parts
03.37 - E5223218 Pintle 3 - frame bottom and top with support rollers
03.38 - E5223219 Pintle belt 3 - drive unit
03.39 - E5215685 Pintle 3 - pintle belt
03.40 - E5223220 Pintle 3 - deflector roller 3 support frame
03.41 - E5223221 Pintle 3 - drive and bearing of discharge roller 3
03.42 - E5223222 Pintle 3 - operating unit - deflector rollers and cover rubbers
03.43 - E5223223 Pintle belt 3 - terminal, camera and working floodlight(s)
Pintle belt 3 (standard version)
03.31 - E5223130 Pintle 3 - frame bottom with attached parts
03.32 - E5223131 Pintle 3 - frame bottom and top with support rollers
03.33 - E5223132 Pintle belt 3 - drive unit
03.34 - E5215074 Pintle 3 - pintle belt
03.35 - E5223133 Pintle 3 - deflector roller 3 support frame
03.36 - E5223134 Pintle 3 - drive and bearing of discharge roller 3
03.37 - E5223135 Pintle 3 - operating unit - deflector rollers and cover rubbers
Pintle belt 4 and UFK (only with double UFK model)
03.43 - E5223224 Pintle 4 - frame with attached parts
03.44 - E5223225 Pintle belt 4 - frame with support rollers
03.45 - E5223226 Pintle 4 - frame with cover rubbers
03.46 - E5223227 Pintle belt 4 - drive unit
03.47.1 - E5215695 Pintle 4 - pintle belt
03.47.2 - E5215747 Pintle belt 4 - slat conveyor
03.48 - E5223200 Igel 4 - Tragrahmen-Ableitwalze 4 verstellbar (ab Baujahr 2025)
03.48 - E5223228 Pintle 4 - deflector roller 4 support frame
03.49 - E5223229 Pintle 4 - drive and bearing of discharge roller 4
03.50 - E5223230 UFK - frame with support rollers and attachments
03.51 - E5223231 UFK - frame with cover rubbers
03.52 - E5223232 UFK - drive unit
03.53 - E5223233 UFK - picking table control unit
03.54 - E5223304 UFK - finger band 1
03.55 - E5223305 UFK - finger band 2
03.56.1 - E5223306 UBK - brush belt
03.56.2 - E5223307 UBK _ UFK - brush belt with finger conveyor
03.57 - E5223234 Pintle 4 and UFK - height adjustment
Pintle belt 4 and UFK (standard version)
03.38 - E5223136 Pintle 4 - frame with attached parts
03.39 - E5223137 Pintle belt 4 - frame with support rollers
03.40 - E5223138 Pintle 4 - frame with cover rubbers
03.41 - E5223139 Pintle belt 4 - drive unit
03.42.1 - E5215082 Pintle 4 - pintle belt
03.42.2 - E5215746 Pintle belt 4 - slat conveyor
03.43 - E5223140 Pintle 4 - deflector roller 4 support frame
03.43 - E5223150 Igel 4 - Tragrahmen-Ableitwalze 4 verstellbar (ab Baujahr 2025)
03.44 - E5223141 Pintle 4 - drive and bearing of discharge roller 4
03.45 - E5223142 UFK - frame with support rollers and attachments
03.46 - E5223143 UFK - frame with cover rubbers
03.47 - E5223144 UFK - drive unit
03.48 - E5223145 UFK - picking table control unit
03.49 - E5223192 UFK - finger band 1
03.50 - E5223193 UFK - finger band 2
03.51.1 - E5223194 UBK - brush belt
03.51.2 - E5223195 UBK _ UFK - brush belt with finger conveyor
03.52 - E5223146 Pintle 4 and UFK - height adjustment
Soil removal belt
03.15.1 - E5223101 Frame - soil removal belt
03.15.2 - E5223102 Soil removal belt support rollers
03.16 - E5223103 Soil removal belt drive
03.17 - E5215057 Soil removal belt
04 - Sorting section
04.01 - E5223151 Sorting platform right - ladder, platforms and locks
04.02 - E5223152 Sorting platform right - shift unit
04.03 - E5223153 Sorting platform right - discharge chute
04.04 - E5223154 Sorting platform left - ladder, platform and rubber flaps
04.05 - E5223155 Sorting platform left - tool box and wheel chocks
04.06 - E5223156 Sorting platform left - discharge chute
04.07 - E5223157 Picking conveyor frame - attachments and video camera
04.08 - E5223158 Picking conveyor frame - height adjustment and articulation cylinder
04.09 - E5223159 Picking conveyor frame - drive unit and support rollers
04.10 - E5223160 Bunker filling conveyor frame - attachments, angle sensor and ultrasound sensor
04.11 - E5223161 Bunker filler conveyor frame - support rollers and tensioning unit
04.12 - E5215182 Picking conveyor
04.13 - E5215183 Trash conveyor - attachments and supporting rollers
04.14 - E5215184 Trash conveyor - drive unit
04.15 - E5215185 Trash conveyor - slat conveyor
04.16 - E5215186 Trash discharge conveyor - attachments and rubber flaps
04.17 - E5223162 Trash discharge conveyor - drive unit and support rollers
04.18 - E5215188 Trash discharge conveyor - slat conveyor
04.19 - E5215189 Sorting platform left & right - foldable seat (optional)
Hydraulics sorting section
04.01 - E5223251 Connection drive trash conveyor without reversing, trash discharge conveyor & picking conveyor
04.02 - E5223252 Connection drive trash conveyor with reversing, trash discharge conveyor & picking conveyor
04.03.1 - E5223271 Connection cylinder bunker filling conveyor - part 1
04.03.2 - E5223272 Connection cylinder bunker filling conveyor - part 2
Special equipment
04.10 - Model - collection box hydraulics
04.20 - Variant - potato crusher hydraulics
Special equipment
04.01 - Collection box variant
04.20 - E5215190 Collection box - suspension
04.21 - E5223163 Collection box - panels with flap cover
04.22 - E5223164 Collection box - drive unit and support rollers
04.23 - E5215193 Collection box - slat conveyor
04.02 - Potato crusher variant
04.30 - E5215555 Potato crusher - suspension
04.31 - E5215556 Potato crusher - infeed
04.32 - E5223165 Potato crusher - frame with swing arm and attached parts
04.33 - E5215558 Potato crusher - drive with wheel
04.34 - E5215559 Potato crusher - carrier bracket on wheel - rear
04.35 - E5215560 Potato crusher - guard
04.03 - Version sorting platform left-rear (only with double UFK model)
04.40 - E5215561 Sorting platform left rear - attachments
04.41 - E5215562 Sorting platform left rear - shift unit
04.42 - E5215563 Sorting platform left rear - ladder and clamping bracket
04.04 - Trash conveyor variant (only for version with double UFK)
04.50 - E5215711 Trash conveyor - tensioning unit, chute and attachments
04.51 - E5215712 Trash conveyor - drive unit and support rollers
04.52 - E5215713 Trash conveyor
05 - Bunker
05.01 - Bunker without articulation
05.01 - E5223311 Bunker coupling and bunker height adjustment
05.02 - E5223312 Bunker trough frame with side walls and attachments
05.03 - E5223313 Bunker extension frame with side walls and attachments
05.04 - E5223314 Bunker filler slide with bunker soft floor cylinder
05.05 - E5223315 Cylinder and angle sensor for bunker folding
05.06 - E5223316 Cylinder and angle sensor for bunker flap
05.07 - E5223317 Bunker - drive unit
05.08 - E5223318 Bunker - pad-roll floor with tensioning unit
05.09 - E5223393 Bunker Nachrüstsatz und Reparaturteile
Special equipment
05.10 - E5215240 Bunker - tray filler
05.11 - E5223319 Bunker - frame connection and tray filler cylinder
05.12 - E5215743 Bunker - bunker increase
05.13 - E5223376 Bunker - Kettenöler
05.02 - Bunker with articulation
05.03 - E5223320 Bunker extension frame with side walls and attachments
05.05 - E5223321 Cylinder and angle sensor for bunker folding
05.06 - E5223322 Cylinder and angle sensor for bunker flap
05.07 - E5223323 Bunker articulation - drive unit
05.08 - E5223324 Bunker articulation - guide rollers and sliding shoes
05.09 - E5223325 Bunker articulation - pad-roll floor with tensioning unit
05.10 - E5223394 Bunker Nachrüstsatz und Reparaturteile
Special equipment
05.03 - Overloading bunker
05.01 - E5223326 Bunker trough - bunker mounting
05.02 - E5223327 Bunker trough - rear wall and attachments
05.03 - E5223328 Bunker trough - side walls rear and attachments
05.04 - E5223329 Bunker trough - side walls front and attachments
05.05 - E5223330 Bunker trough - hydraulic cylinder for rear wall and unload conveyor
05.06 - E5223331 Bunker trough - drive unit
05.07 - E5223332 Bunker trough - transfer shaft
05.08 - E5223333 Bunker trough - walking floor metal strips with tensioning unit
05.09 - E5223334 Unload conveyor segment 1 - attachments
05.10 - E5223335 Unload conveyor segment 1 - supporting rollers
05.11 - E5223336 Unload conveyor segment 2 - attachments
05.12 - E5223337 Unload conveyor segment 2 - supporting rollers
05.13 - E5223338 Unload conveyor segment 3 - attachments
05.13 - E5223379 Entladeband-Segment 3 - Anbauteile (ab Baujahr 2026)
05.14 - E5223339 Unload conveyor segment 3 - supporting rollers
05.15 - E5223340 Unload conveyor segment 4 - attachments
05.16 - E5223341 Unload conveyor segment 4 - supporting rollers
05.17 - E5223342 Unloading conveyor - drive unit
05.18 - E5223343 Unloading conveyor - sieve conveyor
Special equipment
05.20 - E5223367 Überladebunker - Kistenfüller (mechanisch)
05.20.1 - E5223368 Überladebunker - Kistenfüller (hydraulisch) - Teil 1
05.20.2 - E5223369 Überladebunker - Kistenfüller (hydraulisch) - Teil 2
05.21 - E5223377 Überladebunker - Kettenöler
05.04 - XL bunker without articulation
05.01 - E5223344 Bunker coupling and bunker height adjustment
05.02 - E5223345 Bunker trough frame with side walls and attachments
05.03 - E5223346 Bunker extension frame with side walls and attachments
05.04 - E5223348 Bunker filler slide with bunker soft floor cylinder
05.05 - E5223349 Cylinder and angle sensor for bunker folding
05.06 - E5223351 Cylinder and angle sensor for bunker flap
05.07 - E5223353 Bunker - drive unit
05.08 - E5223355 Bunker - pad-roll floor with tensioning unit
Special equipment
05.11 - E5215241 Bunker - frame connection and tray filler cylinder
05.12 - E5215744 XL bunker - bunker increase
05.05 - XL bunker with articulation
05.03 - E5223347 Bunker extension frame with side walls and articulation attachments
05.05 - E5223350 Cylinder and angle sensor for bunker folding-articulation
05.06 - E5223352 Cylinder and angle sensor for bunker flap and cylinder for bunker articulation
05.07 - E5223354 Bunker articulation - drive unit
05.08 - E5223356 Bunker articulation - guide rollers and sliding shoes
05.09 - E5223357 Bunker articulation - pad-roll floor with tensioning unit
Special equipment
Hydraulics bunker
Hydraulics overloading bunker
05.10.1 - E5223380 Connections control unit LVS - part 1
05.10.2 - E5223381 Connections control unit LVS - part 2
05.11.1 - E5223382 Unloading conveyor drive and hydraulic cylinder for folding in unloading conveyor - part 1
05.11.2 - E5223383 Unloading conveyor drive and hydraulic cylinder for folding in unloading conveyor - part 2
05.11.3 - E5223384 Unloading conveyor drive and hydraulic cylinder for folding in unloading conveyor - part 3
05.12 - E5223385 Hydraulic hose kit with unload conveyor drive
05.13 - E5223386 Hydraulic cylinder raise unloading conveyor
05.14 - E5223387 Hydraulic cylinder(s) unload conveyor articulation 1
05.15 - E5223388 Hydraulic cylinder(s) unload conveyor articulation 2
05.16.1 - E5223389 Hydraulic cylinder rear wall and picking conveyor height adjustment - part 1
05.16.2 - E5223390 Hydraulic cylinder rear wall and picking conveyor height adjustment - part 2
05.17 - E5223391 Drive bunker walking floor
Hydraulics standard bunker, XL bunker and double bunker
05.01 - E5223370 Connection lift bunker
05.02.1 - E5223371 Connection fold bunker and bunker filling soft floor - part 1
05.02.2 - E5223372 Connection fold bunker and bunker filling soft floor - part 2
05.03 - E5223373 Connection bunker flap and articulate bunker
05.04 - E5223374 Connection drive bunker walking floor
05.05 - E5223375 Connection drive bunker walking floor in double bunker version
Special equipment
05.20 - E5223392 Tray filler connection
05.21.1 - E5223395 Variante Anschluss Kistenfüller für Überladebunker - Teil 1
05.21.2 - E5223396 Variante Anschluss Kistenfüller für Überladebunker - Teil 2
06 - Chassis
06.01 - E5223400 Telescopic axle - right with cylinder for steering and telescope
06.01 - E5223401 Telescopic axle - right with cylinder for steering and telescope - version with drive axle
06.02 - E5223402 Telescopic axle - right with attached parts
06.02 - E5223403 Telescopic axle - right with attached parts - version with drive axle
06.03 - E5223404 Telescopic axle - left with cylinder for steering and slope compensation
06.04 - E5223405 Telescopic axle - left with attached parts
06.05.1 - E5223406 Telescopic axle with pneumatic brake - part 1
06.05.1 - E5223408 Telescopic axle with pneumatic brake - model with drive axle - part 1
06.05.2 - E5223407 Telescopic axle with pneumatic brake - part 2
06.05.2 - E5223409 Telescopic axle with pneumatic brake - model with drive axle - part 2
06.06 - E5223410 Push rod with attached parts and angle sensor
06.07 - E5223411 Drawbar with attached parts
06.08 - E5223412 Cylinder for drawbar with angle sensor
06.09 - E5223413 Cylinder(s) for support foot
06.10 - E5223414 Pump distributor gears (PDG) with articulated shaft
06.10 - E5223415 Pump distributor gears (PDG) with articulated shaft - version with drive axle
06.11 - E5223416 Oil cooler with attached parts
06.12 - E5223417 Side cover for PDG and oil cooler
06.13 - E5223418 Hydraulic oil tank and attached parts
06.14 - E5223419 Lighting and warning signs front
06.15 - E5223420 Lighting and warning signs rear
06.16.1 - E5223421 Cable ducts and empty tubes for electric cable, inclination sensor, working floodlights and video camera
06.16.2 - E5223422 Main frame with attachments
06.17 - E5223424 Basic machine pneumatics
06.17 - E5223425 Basic machine pneumatics - variant with drive axle
06.18 - E5223426 Central lubrication basic machine
06.19 - E5223428 Tarps and covers for basic machine
Hydraulics chassis
06.01.1 - E5223450 Anschluss Pumpenverteilergetriebe (PVG) - Teil 1
06.01.2 - E5223451 Anschluss Pumpenverteilergetriebe (PVG) - Teil 2 - Standard
06.01.2 - E5223452 Anschluss Pumpenverteilergetriebe (PVG) - Teil 2 - Ausführung mit Triebachse
06.02 - E5223453 Anschluss Ölkühler - Standard
06.03 - E5223454 Anschluss Ölkühler - Ausführung mit Triebachse
06.04 - E5223455 Anschluss Hydrauliktank - Standard
06.05 - E5223456 Anschluss Hydrauliktank - Ausführung mit Triebachse
06.06.1 - E5223457 Anschluss Zylinder Lenkung - Teil 1
06.06.2 - E5223458 Anschluss Zylinder Lenkung - Teil 2
06.07 - E5223459 Anschluss Zylinder Teleskopachse und Hangausgleich
06.08 - E5223460 Anschluss Stützfuß
06.09 - E5223461 Anschluss Deichsel und LS-Signal
06.10.1 - E5223462 Anschluss Hochdruckfilter, Vorlauf und Rücklauf Arbeitshydraulik - Teil 1
06.10.2 - E5223463 Anschluss Hochdruckfilter, Vorlauf und Rücklauf Arbeitshydraulik - Teil 2
06.11 - E5223464 Anschluss Vorlauf A, B, Achslenkung und Druckspeicher
06.12 - E5223465 Anschluss Vorlauf Aufnahme, Siebkanal und LS
06.13 - E5223466 Anschluss Vorlauf Siebkette, Igel, Reinigung und Sortierung
06.14 - E5223467 Anschluss Vorlauf UFK, ALW, VLB, BMB und Rücklauf Öltank
06.15.1 - E5223468 Anschluss Sammelrücklaufrohr - Teil 1
06.15.2 - E5223469 Anschluss Sammelrücklaufrohr - Teil 2
Sonderausstattungen
06.20 - Variante Hydraulik-Zusatzachse
06.30 - Variante Hydraulik-Triebachse
06.40 - Variante Hydraulik-Schutzdach
Special equipment
06.01 - Canopy model - sun protection
06.20 - E5223430 Canopy - guide unit - right rear
06.21 - E5223431 Canopy - guide unit - left rear
06.22 - E5223432 Canopy - guide unit - front, control unit and lighting
06.23 - E5223433 Canopy - roof frame with sun protection
06.24 - E5223437 Canopy with double UFK with trash conveyor
06.02 - Canopy model - weather protection
06.23 - E5223434 Canopy - roof frame with weather protection
06.24 - E5223435 Canopy - weather protection side sections - right
06.25 - E5223436 Canopy - weather protection side sections - left
06.03 - Additional axle model
06.30 - E5223445 Additional axle - auxiliary axle with wheel
06.31 - E5223446 Additional axle - hydraulic cylinder(s) and angle sensor
06.04 - Tool box model
06.40 - E5215323 Tool box
06.05 - Variant immobiliser on drawbar eye
06.50 - E5215328 Immobiliser on drawbar eye
06.06 - Hand-washing tank model
06.60 - E5215329 Hand-washing tank
07 - Transmission
07.01 - E5215281 (O-10630075 _ 0088) Pump distributor gears (PDG) housing
07.02 - E5215282 (O-10630075 _ 0088) Input shaft
07.03 - E5215283 (O-10630075 _ 0088) Output drive shaft
07.04 - E5215284 (O-10630075) Output drive shaft - standard
07.04 - E5215286 (O-10630088) Output drive shaft - version with drive axle
07.05 - E5215285 (Berma-18475) Gears - disc coulter
08 - Hydraulic system
Hydraulics bunker
Special equipment
Hydraulics chassis
Sonderausstattungen
Hydraulics pickup
Special equipment
Special equipment
09 - Electrics
09.01 - E5223480 Bedieneinheit - Terminal-CCI 1200
09.02 - E5223481 Bedieneinheit - Rodesteuerung
09.03 - E5223482 Bedieneinheit - Bunkersteuerung
09.05 - E5223484 Bedieneinheit - Ableitwalzen
09.06 - E5223485 Bedieneinheit - Verlesetisch
09.06 - E5223486 Bedieneinheit - Verlesetisch (bei Ausführung Doppel-UFK)
09.07 - E5223488 Videomonitor mit Zubehör
09.08 - E5223489 Nachrüstsatz - ISOBUS für Traktor
09.09.1 - E5223490 Schaltkasten - Zentralelektrik - Teil 1
09.09.2 - E5223491 Schaltkasten - Zentralelektrik - Teil 2
09.10 - E5223492 Beleuchtung vorne und hinten
09.11 - E5223494 Arbeitsscheinwerfer und Rundumleuchte
09.12.1 - E5223496 Video-Kamera-System - digital - Teil 1
09.12.2 - E5223497 Video-Kamera-System - digital - Teil 2
10 - Stickers
10.01 - E5223500 Aufkleber - Logos und Dekors
10.02 - E5223501 Aufkleber - Piktogramme
11 - Spare parts package, tools and accessories
11.01 - E5215308 Spare parts package - large and small
11.02 - E5215305 Assembly kit - bunker support
11.03 - E5215306 Hoist - crane loading
11.04 - E5215593 Guard rail - disc coulter right
11.05 - E5215307 Elevation (displacement) of support roller - sieving channel-front section
12 - Control blocks & seat valves
270048600 - E5015010 Dual lowering brake valve
270068000 - E5015002 Control unit - operating hydraulics
270068100 - E5015033 Stromregler 3-Wege mit Handrad (8 l_min.)
270068300 - E5015011 Current controller - LVM 3-way
270068400 - E5015012 Current controller - LVM 2-way
270068500 - E5015013 Current controller, 2-way, (25 l_min)
270068600 - E5015014 Current controller, 2-way, (10 l_min)
270068700 - E5015015 Current controller, 3-way with hand wheel (25 l_min)
270068900 - E5015006 Control unit - tie rod
270069100 - E5015016 Current controller, 3-way, (16 l_min)
270069300 - E5015018 Seat valve 2-part
270071200 - E5015017 Seat valve 4-part
270071300 - E5015019 Seat valve 1-part
270071900 - E5015001 Control unit - operating hydraulics
270073000 - E5015003 Control unit - walking floor speed 2
270076400 - E5015004 Control unit - MTKL 4-part
270076500 - E5015005 Control unit - SRM 4-part
270082210 - E5015020 Seat valve 1-part (closed)
270082310 - E5015021 Seat valve 1-part (open)
270082500 - E5015007 Control unit - LVS 3-part
270082900 - E5015009 Control unit - wheel drive
270083800 - E5015008 Control unit - additional axle
270084800 - E5015022 Control unit - trash conveyor reversing
270090900 - E5015023 Steuerblock - Schlepperhydraulik I (LVS 5-fach)
270091200 - E5015029 Steuerblock - Bunker senken
270092400 - E5015031 Steuerblock - Lenkung, Neigung, Teleskop
270092610 - E5015026 Steuerblock - Reinigung _ Sortierung
270093400 - E5015024 Steuerblock - Schlepperhydraulik III
270094600 - E5015028 Steuerblock - Verleseband
270095200 - E5015030 Steuerblock - Eilgang-Rollboden
270095400 - E5015032 Steuerblock - Zusatzachse
270095800 - E5015027 Steuerblock - Siebkette-Reversierung _ Schüttler
270097200 - E5015025 Steuerblock - Schlepperhydraulik III
13 - Hydraulic screw connections
13.01 - E50000311 Hydraulic screw connection - type_ G
13.02 - E50000271 Hydraulic screw connection - type_ W
13.03 - E50000272 Hydraulic screw connection - type_ T
13.04 - E50000273 Hydraulic screw connection - type_ K
13.05 - E50000274 Hydraulic screw connection - type_ EVW
13.06 - E50000275 Hydraulic screw connection - type_ EVT
13.07 - E50000276 Hydraulic screw connection - type_ EVL
13.08.1 - E50000277 Hydraulic screw connection - type_ EVGE - part 1 (metric)
13.08.2 - E50000278 Hydraulic screw connection - type_ EVGE - part 2 (inch)
13.09.1 - E50000279 Hydraulic screw connection - type_ GE - part 1 (metric)
13.09.2 - E50000312 Hydraulic screw connection - type_ GE - part 2 (metric)
13.09.3 - E50000281 Hydraulic screw connection - type_ GE - part 3 (metric)
13.09.4 - E50000282 Hydraulic screw connection - type_ GE - part 4 (inch)
13.09.5 - E50000283 Hydraulic screw connection - type_ GE - part 5 (inch)
13.09.6 - E50000284 Hydraulic screw connection - type_ GE - part 6 (inch)
13.10 - E50000285 Hydraulic screw connection - type_ GR
13.11 - E50000286 Hydraulic screw connection - type_ GVO
13.12.1 - E50000287 Hydraulic screw connection - type_ KOR - part 1
13.12.2 - E50000288 Hydraulic screw connection - type_ KOR - part 2
13.13 - E50000289 Hydraulic screw connection - type_ SWVE
13.14.1 - E50000313 Hydraulic screw connection - type_ VSTI - part 1 (metric)
13.14.2 - E50000291 Hydraulic screw connection - type_ VSTI - part 2 (inch)
13.15 - E50000292 Hydraulic screw connection - type_ ROV
13.16.1 - E50000293 Hydraulic screw connection - type_ RED - part 1 (metric)
13.16.2 - E50000294 Hydraulic screw connection - type_ RED - part 2 (inch)
13.17 - E50000295 Hydraulic screw connection - type_ GAI
13.18 - E50000296 Hydraulic screw connection - type_ MAV
13.19 - E50000297 Hydraulic screw connection - type_ MAV-EV
13.20 - E50000298 Hydraulic screw connection - type_ Measuring screw connection
13.21 - E50000299 Hydraulic screw connection - type_ measuring port
13.22 - E50000314 Hydraulic screw connection - type_ gauge connection
13.23 - E50000301 Hydraulic screw connection - type_ pressure gauge
13.24 - E50000302 Hydraulic screw connection - type_ pressure gauge connection
13.25 - E50000303 Hydraulic screw connection - type_ hose for pressure gauge
13.26 - E50000304 Hydraulic screw connection - type_ Bulkhead screw connection
13.27 - E50000305 Hydraulic screw connection - type_ Bulkhead union elbow
13.28 - E50000306 Hydraulic screw connection - type_ Flat nut for bulkhead screw connections
13.29 - E50000307 Hydraulic screw connection - type_ screw cap
13.30 - E50000308 Hydraulic screw connection - type_ BUZ
13.31 - E50000309 Hydraulic screw connection - type_ cutting ring
13.32 - E50000315 Hydraulic screw connection - type_ reinforcing sleeve
14 - Lubricants
14.01 - E5215400 Lubricants
14.02 - E5215399 Sealants and aid materials
