ROPA Harvester euroBunkerMaus (with MAN-engine) (2002-2006) Spare Parts Catalog
Brand: ROPA
Type of Machine: Harvester, Cleaning Technology, Loading Technology
Model: ROPA euroBunkerMaus (with MAN-engine) (2002-2006) Harvester
Year of Manufacture: 2002-2006
Number of Pages: 519 Pages
0 Cover euroBunkerMaus (with MAN-engine) (2002-2006)
01 - Bunker
01.01 - E950028 Bunker - front part with chassis, bunker wall foldable at the front
01.02 - E950025 Bunker telescope in_out, rear bunker wall (to year of construction 2008)
01.03 - E950030 Cross conveyor chains and cross conveyor drive
01.04 - E950026 Transmission
01.05 - E950029 Gears, dirt auger and short conveyor roller counter-bearing
01.06 - E950027 Overview cleaning
01.07 - E950024 Swivel plates (up to year of construction 2008)
03 - Infeed conveyor and re-cleaner
03.01 - E950043 Infeed conv.
03.02.1 - E920049 Cleaning - part 1
03.02.2 - E920124 Cleaning - part 2 (to year of construction 2004)
03.02.2 - E920125 Cleaning - part 2 (from year of construction 2005)
03.03 - E920020 Frame pinch rollers cleaner
03.04 - E920112 8 pinch rollers cleaner, rotating trestle - bottom and gears
03.05 - E920111 Beet brake f. roller cleaner
03.06 - E970036 Suspension pinch roller cleaner - top
03.07 - E920048 8 pinch roller cleaner, pinch roller and bearing
04 - Truck conveyor
04.01 - E920061 Swivel arm
04.02 - E920021 Rotating trestle
04.03 - E920022 Truck conveyor
04.04 - E920051 Truck conv. articulation (standard)
04.05 - E920023 Truck conveyor articulation (extended model)
05 - Chassis
05.01.1 - E920024 Chassis - part 1
05.01.2 - E920025 Chassis - part 2
05.02 - E920053 Diesel tank
05.03 - E920027 Fuel tank lock
05.04 - E980036 Tool box with doors
05.05 - E920028 Axles and steering display
05.06 - E980105 Additional axle
05.07 - E920029 Pneumatic ladder adjustment
05.08.1 - E920132 Model - water spray system - part 1 (from year of construction 2005)
05.08.2 - E950040 Model - water spray system - part 2 (from year of construction 2005)
05.08.3 - E950041 Model - water spray system - part 3 (from year of construction 2005)
06 - Cabin
06.01 - E920130 Front window, side window and cabin door
06.02 - E920030 Cabin roof, mounting and cover
06.03 - E920031 Fresh air filter and air jets
06.04 - E920131 Radio, radio (Funk) consoles and cabin upright
06.05 - E950035 Terminal housing
06.06 - E920017 Rotating seat with rotating seat mounting and locking
06.07 - E920034 Front windshield wiper and side window wiper
06.08 - E900306 Mirror bracket and working floodlight
06.09 - E920004 Accelerator and brake pedals
06.10 - E920055 Cover for insulation
06.11 - E920056 Insulation for cabin
07 - Engine
07.01 - E920066 Engine compartment (from year of construction 2003)
07.01 - E920067 Engine compartment (till year of construction 2002)
07.02 - E920002 Diesel engine
07.03 - E920045 Pump distributor gears
07.04 - E920035 Air filter system
07.05 - E920036 Exhaust system
07.06 - E920065 Oil and water cooler
07.07 - E920110 Water cooler (hot and cold water)
07.08 - E920135 Housing for oil- and water cooler
07.09 - E920037 Battery case and windscreen washer system
07.10 - E920001 Diesel engine charge air cooler
07.11 - E920057 Bracket for 2nd generator and air conditioning compressor (to year of constr. 2002 - 2-groove)
07.11 - E920058 Bracket for 2nd generator and air conditioning compressor (from year of constr. 2002 - 3-groove)
07.11 - E920114 Bracket for 2nd generator and air conditioning compressor (from year of constr. 2005)
07.12 - E920003 Diesel lines on the diesel engine (up to year of construction 2002)
07.12 - E920109 Diesel lines on the diesel engine (from year of construction 2003)
07.13.1 - E920108 Independent heating and air conditioning system - part 1
07.13.2 - E920040 Independent heating and air conditioning system - part 2
Components and Details
- E9800489 301018300 - Separ fuel filter
- E9800490 301023000 - Separ fuel filter
08 - Pneumatic system
08.01 - E920052 Air chamber (30 litre) with piping
08.02 - E920041 Air dryer connection with piping (till year of construction 2004)
08.02 - E920069 Air dryer connection with piping (from year of construction 2005)
08.03 - E980107 Brake
08.04 - E980108 Circuit and lock
08.05 - E950036 Mirror folding (up to chassis no. 8_477)
08.05 - E950037 Mirror folding (from chassis no. 8_478)
09 - Hydraulic system
09.01 - E910101 Hydraulic oil tank
09.02 - E920118 Lines - traction drive, suction lines, conveyor- and truck conveyor (up to chassis no. 8_478)
09.02 - E920123 Lines - traction drive, suction lines, infeed conveyor and truck conveyor (from chassis no. 8_479)
09.03 - E920008 Lines - holding tube for control blocks for operating hydraulics
09.04 - E900325 Control block 7-part (block 1)
09.05 - E900326 Control block 6-part (block 2)
09.06 - E920119 Lines - pump working drive and suction lines
09.07 - E980086 Lines - speed valve and hydraulic oil tank
09.08 - E920054 Lines - pump operating hydraulics
09.09 - E920042 Lines front axle steering
09.10 - E980092 Lines - rear axle steering
09.11 - E950019 Lines - bunker - lift and lower
09.12 - E950016 Lines - bunker - in and out
09.13 - E920007 Lines to control unit rear
09.14 - E950015 Lines - bunker - fold at the front
09.15.1 - E950017 Lines - drive burl cleaning
09.15.2 - E950020 Lines - drive burl cleaning and dirt auger
09.16 - E980074 Lines - cylinder lock tank
09.17 - E990030 Lines axle support
09.18 - E980077 Lines turning the swivel arm
09.19 - E980088 Lines - truck conveyor rotate
09.20.1 - E950038 Lines - infeed conveyor- and truck conveyor drive (short-standard)
09.20.2 - E950039 Lines - infeed conveyor and truck conveyor drive (long)
09.21 - E980085 Lines - truck conveyor up_down
09.22.1 - E980090 Lines - articulate truck conveyor and apron (short-standard)
09.22.2 - E980091 Lines - articulate truck conveyor (long)
09.23 - E920005 Lines - oil cooler- and ventilator drive
09.24.1 - E920122 Lines pump - return flow sieving conveyor cleaner
09.24.2 - E900311 Lines - pump return flow pinch rollers cleaner
09.25.1 - E900317 Lines - drive sieve conveyor cleaner
09.25.2 - E980081 Lines - drive 8-part pinch roller cleaner
09.26 - E980075 Lines - beet brake and infeed conveyor
09.27 - E950018 Lines - cross conveyor drive
09.31 - E980102 Lines - additional axle
09.32 - E920120 Lubricating pipe system on the PDG (up to chassis no. 8_477)
09.32 - E920121 Lubricating pipe system on PDG (from chassis no. 8_478)
10 - Central electrical system
- E9800477 Übersicht Stecker - Teil 2
- E9800478 018079700 - Electrical assortment box
- E9800499 Overview of plugs
10.01 - E920060 Central electrical system
11 - Gears & axles
Front axle (Planet - 3 gears - Differential - 7_37)
11.14.1 - E920085 (O-11220010) Differential housing for front axle (up to chassis no. 8_478)
11.15.1 - E920086 (O-11220010) Front axle (up to chassis no. 8_478)
11.16.1 - E920087 (O-11220010) Wheel hub - front axle (up to chassis no. 8_478)
11.17.1 - E920088 (O-11220010) Drum brake (up to chassis no. 8_478)
11.18.1 - E920089 (O-11220010) Front axle steering cylinder (up to chassis no. 8_478)
Front axle (Planet - 4 gears - Differential - 9_39)
11.14.2 - E920145 (O-11220052) Differential housing - front axle (from chassis no. 8_479)
11.15.2 - E920146 (O-11220052) Front axle (from chassis no. 8_479)
11.16.2 - E920147 (O-11220052) Front axle - wheel hub (from chassis no. 8_479)
11.17.2 - E920148 (O-11220052) Drum brake (from chassis no. 8_479)
11.18.2 - E920149 (O-11220052) Front axle steering cylinder (from chassis no. 8_479)
Manual transmission
11.23 - E920094 (O-10560058) Housing for manual transmission (4-gear)
11.24 - E920095 (O-10560058) Manual transmission drive shaft
11.25 - E920096 (O-10560058) Driven shaft - manual transmission
11.26 - E920097 (O-10560058) Gearshift - gear 1-2
11.27 - E920098 (O-10560058) All-wheel switching
11.28 - E920099 (O-10560058) Reduction gearing
Pinch roller gears
11.07 - E920076 (O-10630011) 8-roller pinch roller gears
11.01 - E920070 (O-10620025) Pump distributor gears - housing
11.02 - E920071 (O-10620025) Pump distributor gears - drive shaft
11.03 - E920072 (O-10620025) Pump distributor gears - intermediate- and side shaft (to year of construction 2004)
11.03 - E920140 (O-10620025) Pump distributor gears - intermediate and side shaft (from year of construction 2005)
11.04 - E920073 (O-10620025) Pump distributor gears - coupling shaft
11.05 - E920074 (O-10620025) Pump distributor gears - coupling shaft
11.06 - E920075 (O-10620025) Pump distributor gears - output drive shaft
rear axle
11.19 - E920090 (O-11220035) Differential housing for rear axle
11.20 - E920091 (O-11220035) rear axle
11.21 - E920092 (O-11220035) Wheel hub - rear axle
11.22 - E920093 (O-11220035) Rear axle steering cylinder
12 - Angular planetary gear
12.01 - E920100 (1.350.3.103.0) Output drive shaft - toothed shaft 58x53
12.01 - E920101 (1.350.3.101.0) Output drive shaft - cylindrical ø 60
12.02 - E920102 (1.356.3.305.0) Reduction
12.03 - E920103 (1.362.1.025.0) Bevel stage
12.04 - E920104 (1.368.4.114.0) Brake
12.05 - E920105 (1.387.5.501.0) Mounting flange and coupling
13 - Central lubrication
- E9800492 Central lubricating pump
- E9800493 Distributor - components
- E9800494 Hose connections
- E9800495 Screw connections - central lubrication
13.01 - E950042 Central lubricating system euro-Bunkermaus
13.02 - E980089 Holder grease bucket and electric pump central lubrication
14 - Park heating
- E9800600 320007700 - park heating Thermo 90 - part 1
- E9800601 320007700 - park heating Thermo 90 - part 2
- E9800602 320007700 - park heating Thermo 90 - part 3
- E9800603 320007700 - park heating Thermo 90 - part 4
- E9800604 320007700 - park heating Thermo 90 - part 5
- E9800605 320007700 - park heating Thermo 90 - part 6
- E9800606 320049300 - park heating Thermo 90S - part 1
- E9800607 320049300 - park heating Thermo 90S - part 2
- E9800608 320049300 - park heating Thermo 90S - part 3
- E9800609 320049300 - park heating Thermo 90S - part 4
- E9800610 320049300 - park heating Thermo 90S - part 5
- E9800611 320049300 - park heating Thermo 90S - part 6
15 - Hydraulic screw connections
15.01 - E9800500 Hydraulic screw connection - type_ G
15.02 - E9800501 Hydraulic screw connection - type_ W
15.03 - E9800502 Hydraulic screw connection - type_ T
15.04 - E9800503 Hydraulic screw connection - type_ K
15.05 - E9800504 Hydraulic screw connection - type_ EVW
15.06 - E9800505 Hydraulic screw connection - type_ EVT
15.07 - E9800506 Hydraulic screw connection - type_ EVL
15.08.1 - E9800507 Hydraulic screw connection - type_ EVGE - part 1 (metric)
15.08.2 - E9800508 Hydraulic screw connection - type_ EVGE - part 2 (inch)
15.09.1 - E9800509 Hydraulic screw connection - type_ GE - part 1 (metric)
15.09.2 - E9800510 Hydraulic screw connection - type_ GE - part 2 (metric)
15.09.3 - E9800511 Hydraulic screw connection - type_ GE - part 3 (metric)
15.09.4 - E9800512 Hydraulic screw connection - type_ GE - part 4 (inch)
15.09.5 - E9800513 Hydraulic screw connection - type_ GE - part 5 (inch)
15.09.6 - E9800514 Hydraulic screw connection - type_ GE - part 6 (inch)
15.10 - E9800515 Hydraulic screw connection - type_ GR
15.11 - E9800516 Hydraulic screw connection - type_ GVO
15.12.1 - E9800517 Hydraulic screw connection - type_ KOR - part 1
15.12.2 - E9800518 Hydraulic screw connection - type_ KOR - part 2
15.13 - E9800519 Hydraulic screw connection - type_ SWVE
15.14.1 - E9800520 Hydraulic screw connection - type_ VSTI - part 1 (metric)
15.14.2 - E9800521 Hydraulic screw connection - type_ VSTI - part 2 (inch)
15.15 - E9800522 Hydraulic screw connection - type_ ROV
15.16.1 - E9800523 Hydraulic screw connection - type_ RED - part 1 (metric)
15.16.2 - E9800524 Hydraulic screw connection - type_ RED - part 2 (inch)
15.17 - E9800525 Hydraulic screw connection - type_ GAI
15.18 - E9800526 Hydraulic screw connection - type_ MAV
15.19 - E9800527 Hydraulic screw connection - type_ MAV-EV
15.20 - E9800528 Hydraulic screw connection - type_ Measuring screw connection
15.21 - E9800529 Hydraulic screw connection - type_ measuring port
15.22 - E9800530 Hydraulic screw connection - type_ gauge connection
15.23 - E9800531 Hydraulic screw connection - type_ pressure gauge
15.24 - E9800532 Hydraulic screw connection - type_ pressure gauge connection
15.25 - E9800533 Hydraulic screw connection - type_ hose for pressure gauge
15.26 - E9800534 Hydraulic screw connection - type_ Bulkhead screw connection
15.27 - E9800535 Hydraulic screw connection - type_ Bulkhead union elbow
15.28 - E9800536 Hydraulic screw connection - type_ Flat nut for bulkhead screw connections
15.29 - E9800537 Hydraulic screw connection - type_ screw cap
15.30 - E9800538 Hydraulic screw connection - type_ BUZ
15.31 - E9800539 Hydraulic screw connection - type_ cutting ring
15.32 - E9800540 Hydraulic screw connection - type_ reinforcing sleeve
21 - Lubricants
21.01 - E9016500 Lubricants
Brand: ROPA
01 - Bunker
04 - Truck conveyor
05 - Chassis
06 - Cabin
07 - Engine
11 - Gears & axles
Manual transmission
Pinch roller gears
rear axle
14 - Park heating
21 - Lubricants
- ROPA Harvesting Tiger 6S (2019-) Parts Catalog DE
- ROPA Harvester BunkerMaus 5 (2015-2023) Spare Parts Catalog
- ROPA Harvester BunkerMaus 6 (2024-) Spare Parts Catalog
- ROPA Harvester euroBunkerMaus 3 (2006-2019) Spare Parts Catalog
- ROPA Harvester euroBunkerMaus 4 (2014-2020) Spare Parts Catalog
- ROPA Harvester euroMaus (with MAN-engine) (2002-2006) Spare Parts Catalog
- ROPA Harvester euroMaus 3 (2006-2019) Spare Parts Catalog
- ROPA Harvester euroMaus 4 (2010-2020) Spare Parts Catalog
- ROPA Harvester Maus 5 (2015-2023) Spare Parts Catalog
- ROPA Harvester Maus 6 (2022-) Spare Parts Catalog
- ROPA Harvester Tiger 6S (2019-) Spare Parts Catalog
- ROPA Harvester Tiger 6 (2016-) Spare Parts Catalog
- ROPA Harvester Tiger 5 (2014-2017) Spare Parts Catalog
- ROPA Harvester Panther 2S (2021-) Spare Parts Catalog
- ROPA Harvester Panther 2 (2017-2021) Spare Parts Catalog
