ROPA Harvester euroTiger (with MAN engine years of constr. 02-05) (2002-2005) Spare Parts Catalog
- Download this document, you need 8625 Gallons
Brand: ROPA
Type of Machine: Harvester, Harvesting Technology
Model: ROPA euroTiger (with MAN engine years of constr. 02-05) (2002-2005) Harvester
Year of Manufacture: 2002-2005
Number of Pages: 1827 Pages
0 Cover Eurotiger (with MAN engine years of constr. 02-05) (2002-2005)
01 - Topper
01 - Topper BS
01.01 - E902127 Leaf sensor with attachments BS
01.02 - E902129 Swivel arm for leaf sensor BS
01.03 - E902133 Topper wheel BS
01.04 - E902137 Topper housing - inside and outside BS
01.05 - E902147 Topper housing - rear and right with drive only BS
01.06 - E902148 Topper shaft and leaf auger only BS
01.07.1 - E902149 Topper drive with reduction unit only BS (standard - cylindrical roller bearing)
01.07.2 - E902219 Topper drive with reduction unit only BS (reinforced - cylindrical roller bearing)
01.07.3 - E902220 Topper drive with reduction unit only BS (reinforced - tapered roller bearing)
01.08 - E902150 Leaf spreader BS
01.09 - E902151 Scalper bracing tube-parallel BS
01.10 - E902152 Scalper-parallel BS
01.11 - E902153 Angular gear BS
01.12 - E902154 Hydraulic cylinders on the topper BS
01 - Topper IBS
01.01 - E902125 Leaf sensor with attachments IBS
01.02 - E902124 Swivel arm for leaf sensor IBS (from 2004)
01.02 - E902131 Swivel arm for leaf sensor IBS (up to 2003)
01.03 - E902135 Topper wheel IBS
01.04 - E902139 Topper housing IBS
01.05.1 - E902142 Topper shaft IBS (with cutting shaft ø 20)
01.05.2 - E902141 Topper shaft IBS (with cutting shaft ø 22)
01.06 - E902143 Scalper bracing tube IBS
01.07 - E902144 Scalper-parallel IBS
01.08 - E902145 Hydraulic cylinders on the topper IBS
01.09.1 - E902163 Topper drive with reduction unit only IBS (standard - cylindrical roller bearing)
01.09.2 - E902223 Topper drive with reduction unit only IBS (reinforced - tapered roller bearing)
01 - Topper PBSm-45 (from year of construction 2006)
01.01 - E906151 Leaf sensor (PSm-45_50_V)
01.02 - E905098 Topper wheel (PBSm-45_50_V)
01.03 - E905093 Topper housing - left and right (PBSm-45_50_V)
01.04 - E906135 Topper housing - front and rear (PBSm-45_50)
01.05 - E906136 Topper shaft (PBSm-45)
01.06 - E905087 Topper drive (PBSm-45_50)
01.07 - E905091 Leaf auger with cleaning roller (PBSm-45_50)
01.08.1 - E906137 Leaf spreader - standard (PBSm-45_50_V)
01.08.2 - E906134 Leaf spreader - stone protection (PBSm-45_50_V)
01.09 - E905094 Scalper bar (PBSm-45_50)
01.10 - E906138 Scalper and gripper clamp holding frame (PBSm-45_50)
01.11.1 - E906133 Scalper - Standard (PBSm-45_50_V)
01.11.2 - E906132 Scalper - Micro-Topper 2 (PBSm-45_50_V)
01 - Topper PBSm-45-4R (from year of construction 2006)
01.01 - E906151 - Leaf sensor (PSm-4550V)
01.02.1 - E906145 Topper wheel - internal (PBSm-45-4R)
01.02.2 - E906146 Topper wheel - external (PBSm-45-4R)
01.03 - E906147 Topper housing - left and right (PBSm-45-4R)
01.04 - E906148 Topper housing - front and rear (PBSm-45-4R)
01 - Topper PBSm-45_50 (year of construction 2005)
01.01 - E905097 Leaf sensor (PBSm-45_50_V)
01.04 - E905092 Topper housing - front and rear (PBSm-45_50)
01.05.1 - E905088 Topper shaft (PBSm-45)
01.05.2 - E905089 Topper shaft (PBSm-50)
01.08 - E905085 Leaf spreader (PBSm-45_50_V)
01.10 - E905086 Scalper and gripper clamp holding frame (PBSm-45_50)
01.11 - E905096 Scalper (PBSm-45_50_V)
01 - Topper PBSm-V (year of construction 2005)
01.04 - E905101 Topper housing - front and rear (PBSm-V)
01.05 - E905090 Topper shaft (PBSm-V)
01.06 - E905099 Topper drive (PBSm-V)
01.07 - E905100 Leaf auger with cleaning roller (PBSm-V)
01.09 - E905102 Scalper bar (PBSm-V)
01.10 - E905095 Scalper and gripper clamp holding frame (PBSm-V)
01 - Topper PISm-45 (from year of construction 2006)
01.02 - E905075 Topper wheel (PISm-45_50_V)
01.03 - E905070 Topper housing - left and right (PISm-45_50_V)
01.04 - E906139 Topper housing - front and rear (PISm-45)
01.05 - E905080 Topper shaft (PISm-45_50)
01.06 - E905079 Topper drive (PISm-45_50)
01.07 - E905071 Scalper bar (PISm-45_50)
01.08 - E906140 Scalper holding frame (PISm-45_50)
01.09.1 - E906141 Scalper - Standard (PISm-45_50_V)
01.09.2 - E906142 Scalper - Micro-Topper 2 (PISm-45_50_V)
Hydraulic system - PISm-45 topper
01.20 - E905575 Topper wheel and scalper height adjustment (PISm-45_50V)
01 - Topper PISm-45_50 (year of construction 2005)
01.01 - E905074 Leaf sensor (PISm-45_50_V)
01.04 - E905073 Topper housing - front and rear (PISm-45_50)
01.08 - E905077 Scalper holding frame (PISm-45_50)
01.09 - E905076 Scalper (PISm-45_50_V)
Hydraulic system - PISm-45_50 topper
01 - Topper PISm-V (year of construction 2005)
01.04 - E905072 Topper housing - front and rear (PISm-V)
01.05 - E905083 Topper shaft (PISm-V)
01.06 - E905081 Topper drive (PISm-V)
01.07 - E905082 Scalper bar (PISm-V)
01.08 - E905078 Scalper holding frame (PISm-V)
Hydraulic system - PISm-V topper
01.21 - E905576 Scalper - displacement cylinder (PISm-V)
01.22 - E905577 Scalper - clamping cylinder (PISm-V)
01 - Topper RL-BS
01.01 - E902128 Leaf sensor with attachments RL-BS
01.02 - E902132 Swivel arm for leaf sensor RL-BS
01.03 - E902136 Topper wheel RL-BS
01.04 - E902166 Topper housing - rear and right with drive only RL-BS
01.05 - E902167 Topper housing - inside and outside RL-BS
01.06 - E902168 Topper shaft RL-BS
01.07 - E902169 Leaf auger RL-BS
01.08 - E902170 Leaf spreader - left RL-BS
01.09 - E902171 Leaf spreader - right RL-BS
01.10 - E902172 Topper drive with reduction unit RL-BS
01.11 - E902173 Scalper bracing tube-parallel only RL-BS
01.12 - E902174 Scalper-parallel RL-BS
01 - Topper VBS
01.01 - E902126 Leaf sensor with attachments VBS
01.02 - E902130 Swivel arm for leaf sensor VBS
01.03 - E902134 Topper wheel VBS
01.04 - E902138 Topper housing - inside and outside VBS
01.05 - E902146 Topper housing - rear and right with drive only VBS
01.06 - E902155 Topper shaft and leaf auger only VBS
01.07.1 - E902156 Topper drive with reduction unit only VBS (standard - cylindrical roller bearing)
01.07.2 - E902221 Topper drive with reduction unit only VBS (reinforced - cylindrical roller bearing)
01.07.3 - E902222 Topper drive with reduction unit only VBS (reinforced - tapered roller bearing)
01.08 - E902157 Leaf spreader VBS
01.09 - E902158 Scalper bracing tube-parallel only VBS
01.10 - E902159 Scalper-parallel VBS
01.11 - E902160 Angular gear VBS
01.12 - E902161 Hydraulic cylinders on the topper only VBS - part 1
01.13 - E902162 Hydraulic cylinders on the topper only VBS - part 2
02 - Lifter
02 - Lifter PRm-45 (from year of construction 2006)
02.01 - E906102 Cross tube for shaking share pickup (PRm-45_50)
02.02 - E906103 Shaking share clamping brackets (PRm-45)
02.03 - E906104 Shaking share drive (PRm-45)
02.04 - E906101 Shaking share gears - from year of construction 2008 (PRm-45_50_V)
02.04 - E906105 Shaking share gears - to year of construction 2007 (PRm-45_50_V)
02.05 - E906106 Linear guide cross tube (PRm-45_50_V)
02.06 - E906107 Linear guide (PRm-45)
02.07 - E905128 Bracket for linear guide PA rods (PRm-45_50)
02.08 - E906108 Share body with linear guide - to year of construction 2013 (PRm-45_50_V)
02.08 - E906127 Share body with linear guide - from year of construction 2014 (PRm-45_50_V)
02.09.1 - E906128 Share body with lifting shares - to year of construction 2013 (PRm-45_50_V)
02.09.1 - E906152 Share body with lifter shares - from year of construction 2014 (PRm-45_50_V)
02.09.2 - E906098 Share guide rods - to year of construction 2013 (PRm-45_50_V)
02.09.2 - E906158 Share guide rods - from year of construction 2014 (PRm-45_50_V)
02.10 - E905143 Lifter steering (PRm-45_50_V)
02.11 - E906109 Depth-control wheel - till year of constr. 2006 (PRm-45)
02.11 - E906125 Depth-control wheel - from year of construction 2007 (PRm-45_50)
02.12 - E905127 Supporting roller drive - to year of construction 2006 (PRm-45_50_V)
02.12 - E906124 Supporting roller drive - from year of construction 2007 (PRm-45_50)
02.13.1 - E906111 Supporting roller supporting arm - left - to year of construction 2006 (PRm-45)
02.13.2 - E906110 Supporting roller supporting arm - right - to year of construction 2006 (PRm-45)
02.14 - E906123 Supporting roller supporting arm - left and right - from year of construction 2007 (PRm-45_50)
02.15 - E906636 Depth guide (PRm-45_50)
02.16 - E906112 Lifting rollers (PRm-45)
02.17 - E906113 Short lifting rollers (PRm-45)
02.18.1 - E905113 Paddle (PRm-45_50_V)
02.18.2 - E905342 Paddle gears - to year of construction 2006 (PRm-45_50_V)
02.18.2 - E906126 Paddle gears - from year of construction 2007 (PRm-45_50_V)
02.19 - E905225 Complete lifter gears - left-rear (PRm-45_50_V)
02.20 - E905112 Complete lifter gears - right-rear (PRm-45_50_V)
02.21 - E905109 Complete lifter gears - left-front (PRm-45_50_V)
02.22 - E905111 Complete offset gears with angular gears - part 1 (PRm-45_50_V)
02.23 - E905110 Complete offset gears with angular gears - part 2 (PRm-45_50_V)
02.24 - E906114 Lifting unit drive (PRm-45_50_V)
02.25 - E906115 Supporting frame and lifter side arm (PRm-45)
02.26 - E906116 Topper guide parallelogram - to year of construction 2006 (PRm-45_50_V)
02.26 - E906122 Topper guide parallelogram - from year of construction 2007 (PRm-45_50_V)
02.27 - E906117 Supporting arm - centre (PRm-45_50_V)
02.28 - E906100 Lifter side covers - from year of construction 2008 (PRm-45)
02.28 - E906118 Lifter side covers - to year of construction 2007 (PRm-45)
02.29 - E906120 Supporting frame lifter covers - left (PRm-45)
02.30 - E906119 Supporting frame lifter covers - right (PRm-45)
02.31 - E906121 Three-point suspension, lower guide rod and upper guide rod with MAN (PRm-45)
02.32 - E906654 Height indicator for supporting roller (PRm-45)
02 - Lifter PRm-45_50 (year of construction 2005)
02.01 - E905131 Cross tube for shaking share pickup (PRm-45_50)
02.02 - E905133 Shaking share clamping brackets (PRm-45_50)
02.03 - E905116 Shaking share drive - to year of construction 2005 (PRm-45_50)
02.03.1 - E905107 Shaking share drive - from year of construction 2006 (PRm-45)
02.03.2 - E905115 Shaking share drive - from year of construction 2006 (PRm-50)
02.04 - E905105 Shaking share gears - from year of construction 2006 (PRm-45_50_V)
02.04 - E905138 Shaking share gears - to year of construction 2005 (PRm-45_50_V)
02.05 - E905135 Linear guide cross tube (PRm-45_50)
02.06 - E905139 Linear guide (PRm-45_50)
02.08 - E905141 Share body with linear guide (PRm-45_50_V)
02.09 - E905142 Bracket for share guide rods on the share body (PRm-45_50_V)
02.11.1 - E905144 Depth-control wheel (PRm-45)
02.11.2 - E905145 Depth-control wheel (PRm-50)
02.13 - E905126 Supporting roller supporting arm - left (PRm-45_50)
02.14 - E905125 Supporting roller supporting arm - right (PRm-45_50)
02.15 - E905117 Depth guide (PRm-45_50_V)
02.16 - E905119 Lifting rollers (PRm-45_50)
02.17 - E905118 Short lifting rollers (PRm-45_50)
02.24 - E905114 Lifting unit drive (PRm-45_50)
02.25 - E905120 Supporting frame and lifter side arm (PRm-45_50)
02.26 - E905124 Topper guide parallelogram - left (PRm-45_50)
02.27 - E905123 Topper guide parallelogram - right (PRm-45_50)
02.28 - E905130 Supporting arm - centre (PRm-45_50)
02.29 - E905108 Lifter side covers (PRm-45_50)
02.30 - E905121 Supporting frame lifter covers - left (PRm-45_50)
02.31 - E905122 Supporting frame lifter covers - right (PRm-45_50)
02.32 - E905229 Three-point suspension, lower guide rod and upper guide rod with MAN (PRm-45_50)
02.33 - E905227 Height indicator for supporting roller (PRm-45_50)
02 - Lifter PRm-50 (from year of construction 2006)
02.02 - E906621 Shaking share clamping brackets (PRm-50)
02.03 - E906622 Shaking share drive - to year of construction 2007 (PRm-50)
02.03 - E906623 Shaking share drive - from year of construction 2008 (PRm-50)
02.06 - E906624 Linear guide (PRm-50)
02.11 - E906625 Depth-control wheel - till year of constr. 2006 (PRm-50)
02.13.1 - E906632 Supporting roller supporting arm - left - to year of constr. 2006 (PRm-50_V)
02.13.2 - E906633 Supporting roller supporting arm - right - to year of constr. 2006 (PRm-50_V)
02.16 - E906640 Lifting rollers (PRm-50)
02.17 - E906642 Short lifting rollers (PRm-50_V)
02.25 - E906643 Supporting frame and lifter side arm (PRm-50)
02.28 - E906645 Lifting roller side shift - left - to year of construction 2007 (PRh-50_V)
02.28 - E906646 Lifting roller side shift - left - from year of construction 2008 (PRh-50_V)
02.29 - E906647 Lifting roller side shift - right - to year of construction 2007 (PRh-50_V)
02.29 - E906648 Lifting roller side shift - right - from year of construction 2008 (PRh-50_V)
02.30 - E906649 Lifter side covers - to year of construction 2007 (PRm-50_V)
02.30 - E906650 Lifter side covers - from year of construction 2008 (PRm-50_V)
02.31 - E906651 Supporting frame lifter covers - left (PRm-50_V)
02.32 - E906652 Supporting frame lifter covers - right (PRm-50_V)
02.33 - E906653 Three-point suspension, lower guide rod and upper guide rod with MAN (PRm-50_V)
02.34 - E906655 Height indicator for supporting roller (PRm-50_V)
02 - Lifter PRm-V (from year of construction 2006)
02.01 - E906620 Cross tube for shaking share pickup (PRm-V)
02.02 - E905134 Shaking share clamping brackets (PRm-V)
02.03 - E905106 Shaking share drive (PRm-V)
02.06 - E905140 Linear guide (PRm-V)
02.07 - E905129 Bracket for linear guide PA rods (PRm-V)
02.11 - E906626 Depth-control wheel - to year of construction 2006 (PRm-V)
02.11 - E906627 Depth-control wheel - from year of constr. 2007 (PRm-V)
02.12 - E906628 Supporting rollers drive - year of construction 2007 (PRm-V)
02.12 - E906629 Supporting roller drive - from year of construction 2008 (PRm-V)
02.14 - E906634 Supporting roller supporting arm - left and right - year of constr. 2007 (PRm-V)
02.14 - E906635 Supporting roller supporting arm - left and right - year of constr. 2008 (PRm-V)
02.15 - E906637 Depth guide - year of construction 2006 (PRm-V)
02.15 - E906638 Depth guide - year of construction 2007 (PRm-V)
02.15 - E906639 Depth guide from year of construction 2008 (PRm-V)
02.16 - E906641 Lifting rollers (PRm-V)
02.25 - E906644 Supporting frame and lifter side arm (PRm-V)
02 - Lifter PRm-V (year of construction 2005)
02.01 - E905132 Cross tube for shaking share pickup (PRm-V)
02.05 - E905338 Linear guide cross tube (PRm-V)
02.11 - E905146 Depth-control wheel (PRm-V)
02.13 - E905341 Supporting roller supporting arm - left (PRm-V)
02.14 - E905340 Supporting roller supporting arm - right (PRm-V)
02.16 - E905337 Lifting rollers (PRm-V)
02.17 - E905336 Short lifting rollers (PRm-V)
02.24 - E905335 Lifting unit drive (PRm-V)
02.25 - E905333 Supporting frame and lifter side arm (PRm-V)
02.26 - E905331 Topper guide parallelogram - left (PRm-V)
02.27 - E905332 Topper guide parallelogram - right (PRm-V)
02.28 - E905339 Supporting arm - centre (PRm-V)
02.29 - E905137 Lifting roller side shift - left (PRm-V)
02.30 - E905136 Lifting roller side shift - right (PRm-V)
02.31 - E905330 Lifter side covers (PRm-V)
02.32 - E905104 Supporting frame lifter covers - left (PRm-V)
02.33 - E905334 Supporting frame lifter covers - right (PRm-V)
02.34 - E905228 Three-point suspension, lower guide rod and upper guide rod with MAN (PRm-V)
02.35 - E905226 Height indicator for supporting roller (PRm-V)
02 - Lifting unit PV6
02.01 - E902178 Main frame with drive PV6
02.02 - E902179 Lifting frame with parallelogram PV6
02.03 - E902180 Automatic steering share body PV6
02.04 - E902181 Share body and share body bearing PV6 (from year of construction 2004)
02.04 - E902183 Share body and share body bearing - bracket for share guide rods exchangeable PV6 (to year of constr. 2003)
02.04 - E902184 Share body and share body bearing PV6 (to year of construction 2003)
02.05 - E902182 Drive shaking share PV6
02.06 - E902185 Forced intake with slip clutch and automatic depth control with BS_RL-BS-PV6 (to year of constr. 2003) and IBS (to year of constr. 2002)
02.06.1 - E902186 Forced intake with slip clutch and automatic depth control with IBS-PV6 (from year of constr. 2003)
02.06.2 - E902211 Forced intake with slip clutch and automatic depth control with BS_RL-BS-PV6 (from year of constr. 2004)
02.07.1 - E902189 Bearing lifting rollers - right and left PV6
02.07.2 - E902175 Bearing lifting rollers - accessories PV6 (from year of construction 2004)
02.07.2 - E902190 Bearing lifting rollers - accessories PV6 (to year of construction 2003)
02.08 - E902187 Paddle with drive PV6 (from year of constr. 2004)
02.08 - E902188 Paddle with drive PV6 (to year of construction 2003)
02.09 - E902191 Bearing and drive short lifting rollers PV6 (to year of construction 2003)
02.09.1 - E902177 Bearing and drive short lifting rollers PV6 - part 1 (from year of constr. 2004)
02.09.2 - E902176 Bearing and drive short lifting rollers PV6 - part 2 (from year of constr. 2004)
02.10.1 - E902218 Lifter gears PV6 - details
02.10.2 - E907091 Complete lifter gears (PV6) - reinforced
02.11 - E902193 Angular gear PV6
02.12 - E902195 Hydraulic cylinders on the lifter PV6 - part 1
02.13 - E902196 Hydraulic cylinders on the lifter PV6 - part 2
02.14 - E902194 Paddle gears PV6
02.15 - E902215 Gears short lifting roller - right PV6
02.16 - E902216 Gears short lifting roller - left PV6
02 - Lifting unit VPV6
02.01 - E902197 Main frame with drive VPV6
02.02 - E902198 Share body frame with shift VPV6
02.03 - E902199 Automatic steering share body VPV6
02.04 - E902200 Share body and share body bearing VPV6
02.05 - E902201 Bearing and drive eccentric shaft VPV6
02.06 - E902202 Bearing lifting rollers - right and left VPV6
02.07 - E902203 Forced intake arm with automatic depth control VPV6
02.08 - E902204 Forced intake shaft with slip clutch VPV6
02.09 - E902205 Paddle with drive VPV6
02.10 - E902206 Bearing and drive short lifting rollers VPV6
02.11 - E902207 Lifter gears VPV6
02.12 - E902208 Hydraulic cylinders on the lifter VPV6 - part 1
02.13 - E902209 Hydraulic cylinders on the lifter VPV6 - part 2
02.14 - E902210 Paddle gears VPV6
02.15 - E902212 Offset gears for lifter unit VPV6
03 - Intermediate belt
03.01 - E902020 Sieve conveyor, rollers and transfer pipe
03.02 - E902021 Intermediate belt frame and intermediate belt rubber (till year of constr. 2003)
03.02 - E902024 Intermediate belt frame and intermediate belt rubber (from year of construction 2004)
03.03 - E902019 Intermediate belt suspension (from year of constr. 2004)
03.03 - E902022 Intermediate belt suspension (up to year of construction 2003)
04 - Strainer wheel
04.01 - E902025 Strainer wheel 1
04.02 - E902026 Strainer wheel 2
04.03 - E902027 Strainer wheel 3
04.04.1 - E902028 Strainer wheel guide grids without spring tines
04.04.2 - E902029 Strainer wheel guide grids with spring tines
04.04.3 - E902031 Holding device and guide grid for pig tails (from 2004)
04.05 - E902030 Strainer wheel rubber cover
04.06 - E902033 Central adjustment of strainer wheel guide grids
04.07 - E902034 Bearing arm guide grids
04.08 - E902035 Guide grid adj. control lever
04.09 - E902032 Transfer tube central adjustment
04.10 - E902018 Strainer wheel mounting frame and safety bar
04.11 - E902017 Optional equipment agitator in strainer wheel 1
05 - Elevator
05.01 - E902036 Elevator drive
05.02 - E902037 Elevator arm - right
05.03 - E901202 Elevator arm - left, elevator rubber - above
05.04 - E901247 Elevator duct - left
05.05 - E902038 Elevator duct elevator bearer - left
05.06 - E901261 Elevator duct elevator bearer - right
05.07 - E901257 Elevator angular gear
06 - Bunker
- E9800498 Frame tubes on conveyor drive
06.01 - E902047 Bunker auger
06.02 - E902040 Rear cover in bunker
06.03 - E902046 Cleaning roller w. chain drive
06.04 - E901252 PA guide bars conveyors
06.05 - E901256 Longitudinal conveyor
06.06 - E909075 Cross conveyor
06.07 - E901231 Rubber in the bunker
06.08 - E902041 Foldable bunker connection bracket
06.09 - E902039 Bunker inside
07 - Unload conveyor
07.01 - E902042 Unload conveyor frame
07.02 - E902043 Unload conveyor, belt and rollers
08 - Chassis
08.01 - E902044 Three-point suspension, lower guide rod and upper guide rod
08.02 - E902045 Front frame component, articulated joint and axle support
08.03.1 - E902079 Cabin ladder
08.03.2 - E902080 Bunker ladder
08.04 - E902081 Main drive shaft - part 1 (from 2004)
08.04 - E902082 Main drive shaft - part 1 (up to 2003)
08.05 - E902075 Main drive shaft - part 2 (from 2005)
08.05 - E902085 Main drive shaft - part 2 (up to 2004)
08.06 - E902083 Engine compartment underride guard
08.07 - E902084 Engine compartment frame and rear cover
08.08 - E902088 Engine compartment frame - above
08.09 - E902089 Engine housing cover - top
08.10 - E902078 Support arm, axle 3
08.11.1 - E902090 Axles, cardan shafts, tyres - part 1
08.11.2 - E902086 Axles, cardan shafts, tyres - part 2
08.12 - E902077 axle 4_
08.13 - E902091 Bunker entry gate, ultrasound
08.14 - E902076 Hydraulic pipe covers
08.15 - E902093 Protective cover on the bunker - right
08.16 - E902092 Protective cover on the bunker - left
08.17 - E902087 Operator protection deflector bracket - left
08.18 - E902094 Operator protection deflector bracket - right
09 - Cabin
09.01 - E902095 Cabin roof, mounting and cover
09.02 - E902096 Fresh air filter, air jets and covers
09.03 - E902097 TERMINAL
09.04 - E902098 Radio and radio consoles (Funk) cab upright
09.05 - E902099 Steering column, driver's seat and passenger's seat
09.06 - E902101 Front window, side window, cabin door and roller console
09.07 - E902102 Front window wiper
09.08 - E902100 Mirror bracket and working floodlight - cabin (up to 2002)
09.08 - E902104 Mirror bracket and working floodlight - cabin (from 2003)
09.09 - E902103 Accelerator and brake pedals and cleaning flap
09.10 - E901283 Windscreen washer system
10 - Engine
10.01 - E902105 Diesel tank
10.02 - E902113 Pump distributor gears with pumps
10.03 - E902107 Diesel engine radiator
10.04 - E902108 Air filter
10.05 - E902109 Exhaust system
10.06 - E902110 Diesel engine, engine bracket
10.07 - E902111 Oil cooler
10.08 - E902106 Diesel filter, diesel flow meters and engine oil filter
10.09 - E902114 Pneumatic lines-right the frame - right
10.10 - E902115 Heating flow
10.11 - E902116 Air conditioning system
10.12 - E902117 Air conditioning compressor and generator
Components and Details
- E9800489 301018300 - Separ fuel filter
11 - Hydraulic system
11.01 - E902378 Hydraulic lines topper wheel cylinder BS and VBS
11.02 - E902381 Hydraulic lines topper wheel IBS
11.03.1 - E902383 Hydraulic lines scalper cylinder only BS
11.03.2 - E902377 Hydraulic lines scalper cylinder and displacement cylinder VBS
11.04 - E902376 Hydraulic lines clamping cylinder (only VPV)
11.05 - E902356 Hydraulic lines fold leaf auger motor and lock the leaf spreader
11.06 - E902321 Hydraulic lines leaf spreader RL-BS right fold, topper wheel
11.07 - E902316 Hydraulic lines RL-BS leaf auger drive
11.08 - E902355 Hydraulic lines RL-BS leaf spreader - right
11.09 - E902305 Hydraulic lines topper relief activity PV6 with BS or RL-BS 45_50
11.10 - E902312 Hydraulic lines topper relief activity PV6 with IBS 45_50
11.11 - E902301 Hydraulic lines topper maintenance position
11.12 - E902373 Hydraulic lines lifting depth
11.13 - E902375 Hydraulic lines diagonal cylinder and leaf spreader cylinder
11.14 - E902361 Hydraulic lines diagonal cylinder VPV6
11.15 - E902363 Hydraulic lines shift share body VPV6
11.16 - E902309 Hydraulic lines shaking share only BS and RL-BS
11.17 - E902382 Hydraulic lines shake share only IBS
11.18 - E902379 Hydraulic lines drive shaking share VPV
11.19 - E902372 Hydraulic lines short lifting roller drive
11.20 - E902380 Hydraulic lines short lifting roller drive and return flow VPV
11.21 - E902308 Hydraulic lines paddle motor
11.22 - E902303 Hydraulic lines supply line leaf-spreader drive PV6
11.23 - E902302 Hydraulic lines supply line leaf spreader drive PV6 with RL-BS 45_50
11.24 - E902306 Hydraulic lines leaf spreader only PV6
11.25 - E902307 Hydraulic lines leaf spreader RL-BS left
11.26 - E902310 Hydraulic lines paddle drive VPV6
11.27 - E902304 Hydraulic lines leaf spreader only VPV6
11.28 - E902374 Hydraulic lines block reverse roller
11.29 - E902311 Hydraulic lines to three-point
11.30 - E902364 Hydraulic lines control unit shaking share
11.31 - E902315 Hydraulic lines depth guide block
11.32 - E902313 Hydraulic lines pressure depth guide
11.33 - E902314 Hydraulic lines tank line and pressure line brake
11.34 - E902340 Hydraulic lines intermediate conveyor tighten, LS-brake block
11.35 - E902371 Hydraulic lines brake
11.36 - E902318 Hydraulic lines front axle steering - part 1
11.37 - E902369 Hydraulic lines front axle steering - part 2
11.38 - E902319 Hydraulic lines pressure steering
11.39 - E902320 Hydraulic lines steering priority valve
11.40 - E902370 Hydraulic lines 4th axle
11.41 - E902322 Hydraulic lines steering articulation connecting cylinder
11.42 - E902323 Hydraulic lines steering articulation connecting control block
11.43 - E902317 Hydraulic lines axle support
11.44 - E902339 Hydraulic lines pressure control unit infeed conveyor
11.45 - E902335 Hydraulic lines infeed conv.
11.46 - E902338 Hydraulic lines tighten infeed conveyor and drive
11.47 - E902324 Hydraulic lines steering block
11.48 - E902325 Hydraulic lines rear axle steering
11.49 - E902326 Hydraulic lines pressure leaf spreader (right ejection)
11.50 - E902327 Hydraulic lines to operating hydraulics
11.51 - E902328 Hydraulic lines LS to operating hydraulics
11.52 - E902329 Hydraulic lines unload conveyor up_down - part 1
11.53 - E902368 Hydraulic lines unload conveyor up_down - part 2
11.54 - E902330 Hydraulic lines supply valves
11.55 - E902331 Hydraulic lines bunker auger - up_down
11.56 - E902367 Hydraulic lines drive bend unload conveyor
11.57 - E902332 Hydraulic lines elevator - up_down
11.58 - E902333 Hydraulic lines fold bunker connection bracket
11.59 - E902334 Hydraulic lines guide grids height adjustment
11.60 - E902336 Hydraulic lines pressure 3rd axle - part 1
11.61 - E902337 Hydraulic lines pressure 3rd axle - part 2
11.62 - E902341 Hydraulic lines pressure cleaning block
11.63 - E902342 Hydraulic lines drive strainer wheels
11.64 - E902343 Hydraulic lines elevator throw-in - part 1
11.65 - E902348 Hydraulic lines elevator throw-in - part 2
11.66 - E902344 Hydraulic lines elevator drive - part 1
11.67 - E902345 Hydraulic lines elevator drive - part 2
11.68 - E902346 Hydraulic lines tighten elevator
11.69 - E902347 Hydraulic lines drive auger
11.70 - E902349 Hydraulic lines drive cross conveyor
11.71 - E902366 Hydraulic lines drive unload conveyor
11.72 - E902351 Hydraulic lines longitudinal-cross conveyors
11.73 - E902365 Hydraulic lines traction drive
11.74 - E902350 Hydraulic lines leak oil traction drive
11.75 - E902358 Hydraulic lines return lines
11.76 - E902352 Pressure lines on the PDG
11.77 - E902353 Hydraulic lines leaf spreader, bunker auger and depth guide
11.78 - E902354 Intake lines gear pump at PDG
11.79 - E902357 Intake_tank lines drive train, bunker unloading
11.80 - E902360 Intake_tank lines drive train oil cooler
11.81 - E902359 Lubrication lines on the pump distributor gears
11.82 - E902362 Pump distributor gears
11.83 - E902300 Oil tank
12 - Central electrical system
- E9800477 Übersicht Stecker - Teil 2
- E9800478 018079700 - Electrical assortment box
- E9800499 Overview of plugs
13 - Gears & axles
Front axle
13.09 - E902264 (O-11340016) Differential housing 483.88.016 - 11_37
13.09 - E902271 (O-11340019) Differential housing 483.88.019 - 12_33
13.10 - E902265 (O-11340019) Brake
13.11 - E902266 (O-11340016) Planetary axle carrier 483.88.016 - 46_31
13.11 - E902272 (O-11340019) Planetary axle carrier 483.88.019 - 49_27
13.12 - E902267 (O-11340019) Front axle wheel hub
13.13 - E902268 (O-11340019) Steering group
13.14 - E902269 (O-11340019) Front axle steering cylinder
Intermediate belt gears
13.29 - E902270 (O-10630020) Intermediate belt gears
Manual transmission
13.15 - E902250 (O-10560084) Manual transmission housing
13.16 - E902251 (O-10560084) Manual transmission drive shaft
13.17 - E902252 (O-10560084) Manual transmission output drive shaft
13.18 - E902253 (O-10560084) Gearshift - gear 1-2
13.19 - E902254 (O-10560084) Drive turn off
13.01 - E902240 (O-10620029) Pump distributor gears compartment
13.02 - E902241 (O-10620029) Pump drive shaft
13.03 - E902242 (O-10620029) Pump distributor gears drive shaft
13.04 - E902243 (O-10620029) Pump distributor gears side shaft
13.05 - E902244 (O-10620029) Pump distributor gears intermediate shaft
13.06 - E902245 (O-10620029) Pump distributor gears side shaft
13.07.1 - E902246 (O-10620029) Pump distributor gears coupling shaft - part 1
13.07.2 - E902247 (O-10620029) Pump distributor gears coupling shaft - part 2
13.08 - E902248 (O-10620029) Pump distributor gears drive shaft
Rear axle 1
13.20 - E902255 (O-11220041) Differential housing 1st rear axle - 482.80.041
13.20 - E902273 (O-11220051) Differential housing 1st rear axle - 482.80.048
13.21 - E902256 (O-11220051) rear axle
13.22 - E902257 (O-11220051) Rear axle wheel hub
13.23 - E902258 (O-11220051) Rear axle steering cylinder
13.24 - E902259 (O-11220051) Reduction gears
Rear axle 2
13.25 - E902260 (O-11220031) Differential housing rear axle 2
13.26 - E902261 (O-11220031) Rear axle 2
13.27 - E902262 (O-11220031) 2nd rear axle wheel hub
13.28 - E902263 (O-11220031) 2nd rear axle steering cylinder
14 - Central lubrication
- E9800491 Central lubricating pump
- E9800493 Distributor - components
- E9800494 Hose connections
- E9800495 Screw connections - central lubrication
14.01 - E902275 Central lubricating system - 3-axle beet harvesters total
14.02 - E902276 Central lubricating system - lifter and topper
15 - Hydraulic screw connections
15.01 - E9800500 Hydraulic screw connection - type_ G
15.02 - E9800501 Hydraulic screw connection - type_ W
15.03 - E9800502 Hydraulic screw connection - type_ T
15.04 - E9800503 Hydraulic screw connection - type_ K
15.05 - E9800504 Hydraulic screw connection - type_ EVW
15.06 - E9800505 Hydraulic screw connection - type_ EVT
15.07 - E9800506 Hydraulic screw connection - type_ EVL
15.08.1 - E9800507 Hydraulic screw connection - type_ EVGE - part 1 (metric)
15.08.2 - E9800508 Hydraulic screw connection - type_ EVGE - part 2 (inch)
15.09.1 - E9800509 Hydraulic screw connection - type_ GE - part 1 (metric)
15.09.2 - E9800510 Hydraulic screw connection - type_ GE - part 2 (metric)
15.09.3 - E9800511 Hydraulic screw connection - type_ GE - part 3 (metric)
15.09.4 - E9800512 Hydraulic screw connection - type_ GE - part 4 (inch)
15.09.5 - E9800513 Hydraulic screw connection - type_ GE - part 5 (inch)
15.09.6 - E9800514 Hydraulic screw connection - type_ GE - part 6 (inch)
15.10 - E9800515 Hydraulic screw connection - type_ GR
15.11 - E9800516 Hydraulic screw connection - type_ GVO
15.12.1 - E9800517 Hydraulic screw connection - type_ KOR - part 1
15.12.2 - E9800518 Hydraulic screw connection - type_ KOR - part 2
15.13 - E9800519 Hydraulic screw connection - type_ SWVE
15.14.1 - E9800520 Hydraulic screw connection - type_ VSTI - part 1 (metric)
15.14.2 - E9800521 Hydraulic screw connection - type_ VSTI - part 2 (inch)
15.15 - E9800522 Hydraulic screw connection - type_ ROV
15.16.1 - E9800523 Hydraulic screw connection - type_ RED - part 1 (metric)
15.16.2 - E9800524 Hydraulic screw connection - type_ RED - part 2 (inch)
15.17 - E9800525 Hydraulic screw connection - type_ GAI
15.18 - E9800526 Hydraulic screw connection - type_ MAV
15.19 - E9800527 Hydraulic screw connection - type_ MAV-EV
15.20 - E9800528 Hydraulic screw connection - type_ Measuring screw connection
15.21 - E9800529 Hydraulic screw connection - type_ measuring port
15.22 - E9800530 Hydraulic screw connection - type_ gauge connection
15.23 - E9800531 Hydraulic screw connection - type_ pressure gauge
15.24 - E9800532 Hydraulic screw connection - type_ pressure gauge connection
15.25 - E9800533 Hydraulic screw connection - type_ hose for pressure gauge
15.26 - E9800534 Hydraulic screw connection - type_ Bulkhead screw connection
15.27 - E9800535 Hydraulic screw connection - type_ Bulkhead union elbow
15.28 - E9800536 Hydraulic screw connection - type_ Flat nut for bulkhead screw connections
15.29 - E9800537 Hydraulic screw connection - type_ screw cap
15.30 - E9800538 Hydraulic screw connection - type_ BUZ
15.31 - E9800539 Hydraulic screw connection - type_ cutting ring
15.32 - E9800540 Hydraulic screw connection - type_ reinforcing sleeve
21 - Lubricants
21.01 - E9016500 Lubricants
Brand: ROPA
01 - Topper
01 - Topper BS
01 - Topper IBS
01 - Topper RL-BS
01 - Topper VBS
02 - Lifter
04 - Strainer wheel
05 - Elevator
06 - Bunker
08 - Chassis
09 - Cabin
10 - Engine
13 - Gears & axles
Front axle
Manual transmission
Rear axle 1
Rear axle 2
21 - Lubricants
- ROPA Harvesting Tiger 6S (2019-) Parts Catalog DE
- ROPA Harvester BunkerMaus 5 (2015-2023) Spare Parts Catalog
- ROPA Harvester BunkerMaus 6 (2024-) Spare Parts Catalog
- ROPA Harvester euroBunkerMaus (with MAN-engine) (2002-2006) Spare Parts Catalog
- ROPA Harvester euroBunkerMaus 3 (2006-2019) Spare Parts Catalog
- ROPA Harvester euroBunkerMaus 4 (2014-2020) Spare Parts Catalog
- ROPA Harvester euroMaus (with MAN-engine) (2002-2006) Spare Parts Catalog
- ROPA Harvester euroMaus 3 (2006-2019) Spare Parts Catalog
- ROPA Harvester euroMaus 4 (2010-2020) Spare Parts Catalog
- ROPA Harvester Maus 5 (2015-2023) Spare Parts Catalog
- ROPA Harvester Maus 6 (2022-) Spare Parts Catalog
- ROPA Harvester Tiger 6S (2019-) Spare Parts Catalog
- ROPA Harvester Tiger 6 (2016-) Spare Parts Catalog
- ROPA Harvester Tiger 5 (2014-2017) Spare Parts Catalog
- ROPA Harvester Panther 2S (2021-) Spare Parts Catalog
