118
6,911
PowerBoss Sweeper Armadillo 9XR 9XR-Europe 9XV Parts Catalog 4100000 02.2011
Brand: PowerBoss
Type of Machine: Sweeper
Model: PowerBoss Armadillo 9X Series Sweeper
Tier III Models: 9XRT3DSL ; 9XRT3LPG ; 9XRT3GAS
Other Models:
9XRGASES ; 9XRLPES ; 9XRDSLES ; 9XRGASESBR ; 9XRLPESBR ; 9XRDSLESBR
9XRDSLCE ; 9XRLPGCE ; 9XNDLXLP ; 9XNDLXGAS ; 9XKDLXDSL ; 9XDLXLPBR ;
9XDLXDSLBR ; 9XDLXGASBR
Engine:
Kubota V1505 Diesel Engine
GM 1.6 Gasoline , 1.6 LPG Engine
Part Number: 4100000
Publication Date: 2011
Number of Pages: 164 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Ce Declaration Of Conformity
Standard Abbreviations
Frame Assembly 9xr And 9xr Europe
Frame Assembly 9xv
Axle Brake And Wheel Assemblies
7” Mechanical Brake Assembly
Steering Wheel, Gauges & Fuses
Instrument Panel And Tilt Steering Assemblies For 9xv
Side Broom Assembly - Drive Motor, Arm, And Mounting
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Hydraulic Hoses, Steering Unit, & Column
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Seat Assembly 9xr Europe
Lp Tank Hoses And Fittings - 9xr Europe
Lp Tank Mount - 9xr Europe
Lift & Rotation Cylinders, Hydraulic Hoses
Lift & Rotation Cylinders, Hydraulic Hoses (Continued)
Rtr Switch Detail Lift Arm
Rtr Switch Detail Hopper
Hopper - Filter And Shaker Motor Components - 9xr & 9xr Europe
Hopper - Filter And Shaker Motor Components - 9xv
Hopper - Covers, Flap, And Latch Components
Front Bumper Assembly
Battery Components
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Assembly - 9xr And 9xv
Solenoid And Hydraulic Control Valve Mounting - 9xr Europe
Solenoid Valve Details - 9xr Europe
Hydraulic Control Valve Detail - 9xr Europe
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
Engine Gm 1.6l Lpg & Gasoline - Oil Filter, Plug Wires & Water Pump
Engine Gm 1.6l Lpg & Gasoline - Fan, Alternator Belt & Starter
Engine Gm 1.6l Lpg & Gasoline - Pan, Motor Mounts & Brackets
Engine Gm 1.6l Lpg & Gasoline - Pan, Motor Mounts & Brackets (Continued)
Engine Gm 1.6l Lpg & Gasoline - Radiator & Brackets
Engine Gm 1.6l Lpg & Gasoline - Radiator Hoses, Sending Units & Clamps
Engine Gm 1.6l Lpg & Gasoline - Exhaust System
Engine Gm 1.6l Lpg & Gasoline - Exhaust System (Continued)
Engine Gm 1.6l Lpg & Gasoline - Hydraulic Hoses & Fittings
Engine Gm 1.6l Lpg & Gasoline - Air Cleaner
Engine Gm 1.6l - Hydraulic Pump Details
Engine Gm 1.6l - Hydraulic Pump Details (Continued)
Engine Gm 1.6l - Engine Component Breakdown Illustration 1
Engine Gm 1.6l - Engine Component Breakdown Illustration 1 (Continued)
Engine Gm 1.6l - Engine Component Breakdown Illustration 2
Engine Gm 1.6l - Engine Component Breakdown Illustration 2 (Continued)
Engine Gm 1.6l - Lpg Fuel System T2
Engine Gm 1.6l - Lpg Fuel System T2 (Continued)
Engine Gm 1.6l - Gasoline Fuel System T2
Engine Kubota V1505 Diesel - Air Cleaner Assembly
Engine Kubota V1505 Diesel - Fuse Box Assembly
Engine Kubota V1505 Diesel - Fuse Box Details
Engine Kubota V1505 Diesel - Alternator, Water Pump, Fan, And Oil Pan
Engine Kubota V1505 Diesel - Flywheel, Starter, Head Cover, And Exhaust
Engine Kubota V1505 Diesel - Fuel System And Speed Control
Engine Kubota V1505 Diesel - Block And Freeze Plugs
Engine Kubota V1505 Diesel - Head
Engine Kubota V1505 Diesel - Main Bearing Case
Engine Kubota V1505 Diesel - Camshaft And Idle Gear Shaft
Engine Kubota V1505 Diesel - Piston And Crankshaft
Engine Kubota V1505 Diesel - Starter, Fan, Fuel Pump, Motor Mounting
Engine Kubota V1505 Diesel - Exhaust Detail
Engine Kubota V1505 Diesel - Radiator Detail
Engine Kubota V1505 Diesel - Radiator Coolant Tank & Mount
Engine Kubota V1505 Diesel - Radiator Mounts Detail
Engine Kubota V1505 Diesel - Radiator Assembly & Mounting Brackets
Engine Kubota V1505 Diesel - Radiator Assembly, Clamps, Hoses & Senders
Engine Kubota V1505 Diesel - Hydraulic Pump Detail
Common Stock Items
Warranty
