118
5,348
PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
Brand: PowerBoss
Type of Machine: Walk-Behind Scrubber Traction Drive Disc Deck
Type of Manual: User Manual
Model: PowerBoss PHX26ECO Walk-Behind Scrubber Traction Drive Disc Deck
Part Number: 988737UMPB
Publication Date: 2016
Number of Pages: 40 Pages
Safety Instructions
Unpacking Instructions
Inspection
Electrical
Batteries
Operator Responsibility
Machine Overview
Controls
Bail Handle
Handle Adjustment Knobs
Key Switch
Direction Switch
Squeegee Lift Lever
Battery / Fault Gauge
Speed Control
Charge Status Indicator
Optional Hour Meter
Vacuum Hose Routing
Circuit Breakers
Battery Compartment
Diagnostic Code Guide
Machine Overview
Handle Adjustment
Angle Adjustment
Horizontal Adjustment
Solution Tank Drain Hose
Solution Level Indicator
Solution Fill Filter
Recovery Tank Drain Hose
Screened Float
Screened Float Removal
In-Line Solution Filter Assembly
Rear Squeegee
Cleaning The Squeegee
Changing The Squeegee Blades
Squeegee Blades
Angle Adjustment
Squeegee Blades
Height Adjustment
Brush Deck
Brush Loading / Unloading
Aquastop Solution Control
The Phx26eco
Machine Operation
To Turn On Machine:
To Turn On Vacuum:
To Turn On Brush Motor:
To Turn On Cleaning Solution:
Direction Switch:
Speed Control:
Driving:
To Charge Batteries:
Hour Meter (Optional):
After Use
Maintenance
Troubleshooting
Warranty
