118
6,911
PowerBoss Sweeper Armadillo 9X 9XCE User Manual 4100033 2015
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: User Manual
Model:
PowerBoss Armadillo 9X Series SW9XKDSL, SW9XKGAS, SW9XKLPG Sweeper
PowerBoss Armadillo 9XCE Series 9XRDSLCE, 9XRLPGCE Sweeper
Part Number: 4100033
Publication Date: 2015
Number Of Pages: 96 Pages
Preface
Technical Specifications
Sweeping System
Features
Air-Moving System
Ergonomics System
Debris-Handling System
Drive-Train System
Chassis System
Powerboss® Innovations
Environmental Friendly Features
Clean Air
Lower Emissions
Safer Work Environment
Clean Energy
Safety Information
Important Safety Instructions
Safety During Operation
Servicing Or Maintaining Machine
Safety Symbols
Safety Decals
Basic Powerboss® Safety
Machine Operation
Basic Operating Controls & Indicators 24
Ignition Switch
Throttle Switch (Gas And Lpg Only)
Glow Plug Switch (Diesel Only)
Throttle Control (Diesel Only)
Light Switch
Hour Meter
Horn Button
Automatic Diesel Shutoff Switch
Hopper Filter Shaker Button
Fuel Level Gauge (Diesel And Gas Only) 26
Voltmeter Gauge
Engine Oil Pressure Gauge
Engine Coolant Temperature Gauge 26
Circuit Breaker
Directional Control Pedal
Brake Pedal
Tilt Steering Lever
Dual Side Broom Switch
Fire In The Hopper Light
Clogged Filter Light
Check Engine Light
Sweeping Controls
Broom Control Lever
Main Broom Handle
Side Broom Handle
Debris Hopper Dump Controls
High Dump
Lever 1
Lever 2
To Raise And Dump The Hopper:
Rotary Trash Relocator (Rtr™)
Operating Procedures
Pre-Operation Checks
Starting
Slowing And Stopping
Operating On Grades
Sweeping
Empty Hopper With High Dump Feature 36
Transporting The Machine
Using A Trailer Or Transport Vehicle
Pushing The Machine
Options
Neutral Start Sensor
Operator Seat Sensor
Second Hand Operation Pushbutton
Raise Hopper - Main Broom Shut Off
Low Lp Indicator
Parking Brake Bypass Switch
Air Conditioning
Heater
Vacuum Wand
Blower Wand
Dual Curb Broom
Dust Suppression System
Preventative Maintenance
Introduction
Scheduled Maintenance Chart
Preventative Maintenance Instructions 52
Air Intake System
Check Air Filter Service Indicator
Air Filter Element Removal
Air Filter Cleaning
Air Filter Inspection
Air Filter Installation
Battery Cleaning
Battery Replacement
Circuit Breaker
Fuses
Fuel System
Coolant System
Blowing Out Radiator Fins
Reverse Flow Flushing
Lubrication
Changing Engine Oil
Lubrication Points
Steering Cylinder
Engine Mount Pivot
Latches & Hinges
Hopper Lift Arm Mounts
Hydraulics System
Filling The Fluid Reservoir
Hydraulic Fluid Viscosity Specifications
Maintaining Hydraulic Oil Cooler Efficiency
Changing The Hydraulic Fluid
Changing The Hydraulic Fluid Filter
Adjusting The Directional Control Return Spring 63
Sweep Components
Broom Door Flap Inspection
Broom Door Flap Replacement And Adjustment 64
Main Broom Adjustment
Main Broom Height Adjustment
Main Broom Taper Adjustment
Main Broom Replacement
Side Broom Angle Adjustment
Side Broom Height (Wear) Adjustment
Adjust Side Broom Height
Side Broom Lift Cable Adjustment
Side Broom Replacement
Hopper
High Dump Hopper Removal
High Dump Hopper Replacement
Floor Clearance And Dump Angle Adjustment 72
Hopper Filter Removal (Dual Filter)
Filter Cleaning
Filter Replacement
Table Of Contents
Vacuum Gasket Mount Adjustment
Flap Replacement
Frame Seal Replacement
Front Frame Seal
Side Frame Seal
Adjusting The Parking Brake Cable Length
Tires
Changing Solid Tires
Changing Pneumatic Tires
Miscellaneous Adjustments
Anti-Static Chain Adjustment
Latch And Hinge Maintenance
Cables
Troubleshooting
Troubleshooting Chart
Notes
Ce Declaration Of Conformity
Warranty
