PowerBoss Sweeper Armadillo 6X Parts Catalog 4100043 2010
Brand: PowerBoss
Type of Machine: Sweeper
Model: PowerBoss Armadillo 6X 3338200, 3338300, SW6XVDSL Sweeper
Engine:
Kubota D902 Diesel Engine
Kubota DF752 LPG, DF752 Gas Engine
Kubota WG750 Gasoline Engine
Part Number: 4100043
Publication Date: 2010
Number of Pages: 102 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Notes
Parts Breakdown
Frame
Instrument Panel
Axle, Brakes And Wheel Assembly
3318673 Front Axle Assembly
Battery
Main Broom Door
Engine Cover
Direction Control Assembly
Bumper
Hopper
Hopper Hood And Lid Assemblies
Control Valve
Hydraulic Manifold Assembly
Hydraulic Manifold
Hydraulic Reservoir
Impeller
Gasket Mount
Lift Arm Part 1
Lift Arm Part 1 (Continued)
Lift Arm Part 2
Main Broom Assembly
Main Broom Assembly (Continued)
Side Broom Assembly
Side Broom Actuator
Steering Assembly
Tilt Steering Assembly
Fuel Tank - Gas And Diesel
Engine Kubota D902 Diesel & DF752 Lp/Gas - Mounting And Pumps
Engine Kubota D902 Diesel & DF752 Lp/Gas - Air Cleaner & Exhaust
Engine Kubota D902 Diesel & DF752 Lp/Gas - Radiator & Fluid Cooler
Engine Kubota D902 Diesel & DF752 Lp/Gas - Alternator, Water Pump, & Fan
Engine Kubota D902 Diesel & DF752 Lp/Gas - Starter, & Exhaust Manifold
Engine Kubota D902 Diesel & DF752 Lp/Gas - Block And Freeze Plugs
Engine Kubota D902 Diesel & DF752 Lp/Gas - Cylinder Head And Valves
Engine Kubota D902 Diesel & DF752 Lp/Gas - Main Bearing Case
Engine Kubota D902 Diesel & DF752 Lp/Gas - Camshaft, Idle & Oil Pump
Engine Kubota D902 Diesel & DF752 Lp/Gas - Piston And Crankshaft
Engine Kubota DF752 Lp/Gas - Distributor And Spark Plug
Engine Kubota DF752 Lp/Gas - Carburetor And Governor
Engine Kubota D902 Lp/Gas - Fuel System
Engine WG750 Gas - Mountings
Engine WG750 Gas - Radiator And Exhaust System
Engine WG750 Gas - Components
Engine WG750 Gas - Components (Continued)
Miscellaneous
Main And Side Brooms
Warranty
Notes
Brand: PowerBoss
Engine:
Preface
Dimensions & Weight
Sweeping System
Notes
Parts Breakdown
Frame
Instrument Panel
Battery
Main Broom Door
Engine Cover
Bumper
Hopper
Control Valve
Hydraulic Manifold
Hydraulic Reservoir
Impeller
Gasket Mount
Lift Arm Part 1
Lift Arm Part 2
Main Broom Assembly
Side Broom Assembly
Side Broom Actuator
Steering Assembly
Miscellaneous
Warranty
Notes
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
