118
6,911
PowerBoss Sweeper Armadillo 10X Series Parts Catalog Wiring Diagram 4100046 2023
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss Armadillo 10X Series 10XT3DSL ; 10XT3LP ; 10XT3GAS ; 10XT3DSL-US Sweeper
Part Number: 4100046
Publication Date: 2023
Number of Pages: 268 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Standard Abbreviations
Parts Breakdown
Frame Assembly
Frame Assembly 1 (Us Model)
Frame Assembly 2 (Us Model)
Broom Door Assembly
Axle, Brake And Wheel Assemblies
7” Mechanical Brake Assembly
Steering Wheel, Gauges & Fuses
Side Broom Assembly - Drive Motor, Arm And Mounting
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Engine Cover, Side Door, Latch & Rear Grill (Us Model)
Engine Cover (Us Model)
Hydraulic Hoses, Steering Unit & Column
Powerflex
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Console Assembly (Continued)
Console Assembly (Us Model)
Seat, Floor Pan & Tail Light
Lp Mount Assembly
Rtr Switch Detail Lift Arm
Lift & Rotation Cylinders, Hydraulic Hoses
Lift & Rotation Cylinders, Hydraulic Hoses (Continued)
Hopper
Hopper Cover
Hopper Latch
Hopper Dump Door And Flaps
Hopper Filters And Shaker
Front Bumper Assembly
Battery Components
Timer-Filter Shaker Sealed
Engine Pivot Assy
Engine Pivot Assy (Us Model)
Engine Pan, Hydraulic Hose Retainer & Latch
Engine Pan, Hydraulic Hose Retainer & Latch (Us Model)
Fuel Tank, Gasoline And Diesel
Fuel Tank, Diesel (Us Model)
Hydraulic Reservoir Assembly
Hydraulic Control Valve Assembly
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Gasket Mount Assembly
Vacuum Switch
2203 Kubota Engine Parts Breakdown
2203 Kubota Engine Block Assy
2203 Kubota Engine Oil Pan
2203 Kubota Engine Cylinder Head
2203 Kubota Engine Gear Case
2203 Kubota Engine Head Cover
2203 Kubota Engine Oil Filter
2203 Kubota Engine Dipstick And Guide
2203 Kubota Engine Oil Pump
2203 Kubota Engine Oil Filler Flange
2203 Kubota Engine Main Bearing Case
2203 Kubota Engine Camshaft And Idle Gear Shaft
2203 Kubota Engine Piston And Crankshaft
2203 Kubota Engine Flywheel
2203 Kubota Engine Fuel Camshaft And Governor Shaft
2203 Kubota Engine Idle Apparatus
2203 Kubota Engine Stop Lever
2203 Kubota Engine Stop Solenoid
2203 Kubota Engine Injection Pump
2203 Kubota Engine Governor
2203 Kubota Engine Speed Control Plate
2203 Kubota Engine Nozzle Holder And Glow Plug
2203 Kubota Engine Fuel Filter
2203 Kubota Engine Fuel Pump (Mechanical)
2203 Kubota Engine Alternator And Pulley
2203 Kubota Engine Alternator (Component Parts)
2203 Kubota Engine Starter
2203 Kubota Engine Starter (Component Parts)
2203 Kubota Engine Oil Switch And Plug
2203 Kubota Engine Water Flange And Thermostat
2203 Kubota Engine Water Pump
2203 Kubota Engine Fan
2203 Kubota Engine Valve And Rocker Arm
2203 Kubota Engine Inlet Manifold
2203 Kubota Engine Exhaust Manifold
2203 Kubota Engine Accessories And Service Parts
2203 Kubota Engine Label And Operator's Manual
2203 Kubota Engine Upper Gasket Kit [Option]
2203 Kubota Engine Lower Gasket Kit [Option]
2203 Kubota Engine - Radiator And Senders
2203 Kubota Engine - Mounts And Hose Retainer
2203 Kubota Engine - Air And Exhaust
2203 Kubota Engine - Fuse Panel
2203 Kubota Engine - Fuse Box Detail
2203 Kubota Engine - Hydraulic Pump Detail
2203 Kubota Engine - Hydraulic Pump Detail (Continued)
Engine Kubota V1505 Diesel, WG1605 Gas & Lpg - Hydraulic Pump Detail
Engine Kubota WG1605 Lpg - Air Cleaner Detail
Engine Kubota WG1605 Gas - Air Cleaner Detail
Engine Kubota WG1605 Gas & Lpg Engine Assembly
Engine Kubota WG1605 Gas & Lpg - Mounts-Exhaust Side
Engine Kubota WG1605 Gas & Lpg - Mounts-Intake Side
Engine Kubota WG1605 Gas & Lpg - Mounting Fastener Detail
Engine Kubota WG1605 Gas & Lpg - Mounting Air Cleaner Bracket
Engine Kubota WG1605 Gas & Lpg - Radiator Mounts
Engine Kubota WG1605 Gas & Lpg - Exhaust Detail
Engine Kubota WG1605 Lpg - Inlet Manifold
Vaporizer To Lpg Tank Connections
D1803 Kubota Engine Parts Breakdown (Us Model)
D1803 Engine Assembly
501200 Dipstick And Guide (D1803 Engine)
501500 Oil Pump (D1803 Engine)
502000 Cylinder Head (D1803 Engine)
503000 Inlet Valve And Exhaust Valve (D1803 Engine)
505000 Head Cover (D1803 Engine)
508000 Gear Case (D1803 Engine)
508200 Oil Filter (D1803 Engine)
510500 Main Bearing Case (D1803 Engine)
511000 Piston And Crankshaft(D1803 Engine)
512000 Camshaft And Idle Gear Shaft (D1803 Engine)
515000 Flywheel (D1803 Engine)
521000 Injection Pump (D1803 Engine)
522000 Fuel Camshaft (D1803 Engine)
526500 Supply Pump (D1803 Engine)
531000 Fuel Filter (D1803 Engine)
532500 Separator (D1803 Engine)
540200 Injector And Glow Plug (D1803 Engine)
545000 Injection Pipe (D1803 Engine)
547100 Fuel Pump (D1803 Engine)
548000 Common Rail (D1803 Engine)
550000 Alternator And Pulley (D1803 Engine)
551000 Alternator Components
556000 Oil Switch And Thermometer (D1803 Engine)
554000 Starter (D1803 Engine)
555000 Starter Components (D1803 Engine)
557500 Injector Harness (D1803 Engine)
558000 Electrical Wiring (D1803 Engine)
501000 Oil Pan (D1803 Engine)
Options
Opt - Air Cleaner, Heavy Duty (3331034-10x)
Opt - Merv/Hepa Filter, 10x (690697-10x)
Opt - Overhead Guard 9x/10x (690840)
Schematics
Hydraulic Schematic
Electrical Schematic (Us Model)
