PowerBoss Sweeper Armadillo 10X Diesel 10XT3DSL Parts Catalog 4100046 2017
Brand: PowerBoss
Type of Machine: Sweeper
Model: PowerBoss Armadillo 10X Diesel 10XT3DSL Sweeper
Engine: Kubota 2203 Engine
Part Number: 4100046
Publication Date: 2017
Number of Pages: 168 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Notes
Standard Abbreviations
Frame Assembly
Broom Door Assembly
Axle, Brake And Wheel Assemblies
7” Mechanical Brake Assembly
Steering Wheel, Gauges & Fuses
Side Broom Assembly - Drive Motor, Arm And Mounting
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Hydraulic Hoses, Steering Unit & Column
Steering Cylinder
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Lift & Rotation Cylinders, Hydraulic Hoses
Lift & Rotation Cylinders, Hydraulic Hoses (Continued)
RTR Switch Detail - Lift Arm
RTR Switch Detail - Hopper
Hopper Latch System
Hopper Filters
Hopper Covers And Flap Components
Hopper Dump Door And Filter Shaker Components
Front Bumper Assembly
Battery Components
Engine Pivot Assy
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Assembly (Page 1 Of 3)
Hydraulic Control Valve Assembly (Page 2 Of 3)
Hydraulic Control Valve Assembly (Page 3 Of 3)
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
2203 Kubota Engine Block Assy
2203 Kubota Engine Oil Pan
2203 Kubota Engine Cylinder Head
2203 Kubota Engine Gear Case
2203 Kubota Engine Head Cover
2203 Kubota Engine Oil Filter
2203 Kubota Engine Dipstick And Guide
2203 Kubota Engine Oil Pump
2203 Kubota Engine Oil Filler Flange
2203 Kubota Engine Main Bearing Case
2203 Kubota Engine Camshaft And Idle Gear Shaft
2203 Kubota Engine Piston And Crankshaft
2203 Kubota Engine Flywheel
2203 Kubota Engine Fuel Camshaft And Governor Shaft
2203 Kubota Engine Idle Apparatus
2203 Kubota Engine Stop Lever
2203 Kubota Engine Stop Solenoid
2203 Kubota Engine Injection Pump
2203 Kubota Engine Governor
2203 Kubota Engine Speed Control Plate
2203 Kubota Engine Nozzle Holder And Glow Plug
2203 Kubota Engine Fuel Filter
2203 Kubota Engine Fuel Pump (Mechanical)
2203 Kubota Engine Alternator And Pulley
2203 Kubota Engine Alternator (Component Parts)
2203 Kubota Engine Starter
2203 Kubota Engine Starter (Component Parts)
2203 Kubota Engine Oil Switch And Plug
2203 Kubota Engine Water Flange And Thermostat
2203 Kubota Engine Water Pump
2203 Kubota Engine Fan
2203 Kubota Engine Valve And Rocker Arm
2203 Kubota Engine Inlet Manifold
2203 Kubota Engine Exhaust Manifold
2203 Kubota Engine Accessories And Service Parts
2203 Kubota Engine Label And Operator's Manual
2203 Kubota Engine Upper Gasket Kit [Option]
2203 Kubota Engine Lower Gasket Kit [Option]
2203 Kubota Engine - Radiator And Senders
2203 Kubota Engine - Mounts And Hose Retainer
2203 Kubota Engine - Air And Exhaust
2203 Kubota Engine - Fuse Panel
2203 Kubota Engine - Fuse Box Detail
2203 Kubota Engine - Hydraulic Pump Detail
2203 Kubota Engine - Hydraulic Pump Detail (Contuied)
Warranty
Brand: PowerBoss
Preface
Dimensions & Weight
Sweeping System
Notes
Frame Assembly
Broom Door Assembly
Steering Cylinder
Rear Drive Assembly
Console Assembly
Hopper Latch System
Hopper Filters
Battery Components
Engine Pivot Assy
Impeller Assembly
Main Broom Assembly
Vacuum Switch
Warranty
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
