118
6,911
PowerBoss Sweeper AM9D-III Parts Catalog Wiring Diagram 988750ZH 2017
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss AM9D Series AM9D-III Sweeper
Part Number: 988750ZH
Publication Date: 2017
Number of Pages: 156 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Standard Abbreviations
Exploded Drawings And Parts Lists
Frame Assembly Am9d-Iii
Hydraulic Brake Assembly
Hydraulic Brake Assembly - Continued
Brake - 8” ARMA L/H PN-3321450
Brake - 8” ARMA R/H PN-3321471
Steering Wheel, Gauges & Fuses
Steering Column
Side Broom Assembly - Drive Motor, Arm, And Mounting
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Lift & Rotation Cylinders, Hydraulic Hoses
Rtr Switch Detail Lift Arm
Hopper - Filter And Shaker Motor Components
Hopper - Cover And Latch Components
Front Bumper Assembly
Battery Components
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Detail
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
Engine Air Cleaner Assembly
Engine Kubota V1505 Diesel - Fuse Box Assembly
Engine Kubota V1505 Diesel - Fuse Box Details
Engine Kubota V1505 Diesel - Alternator, Water Pump, Fan, And Oil Pan
Engine Kubota V1505 Diesel - Flywheel, Starter, Head Cover, And Manifold
Engine Kubota V1505 Diesel - Fuel System And Speed Control
Engine Kubota V1505 Diesel - Motor Mounting
Engine Kubota V1505 Diesel - Exhaust Detail
Engine Kubota V1505 Diesel - Radiator Detail
Engine Kubota V1505 Diesel - Radiator Coolant Tank & Mount
Engine Kubota V1505 Diesel - Radiator Assembly & Mounting Brackets
Engine Kubota V1505 Diesel - Radiator Assembly, Clamps, Hoses & Senders
Engine Kubota V1505 Diesel - Hydraulic Pump Detail
Options
Opt - Michigan Suspension Seat (600005)
Opt - Tires Pneumatic With Welded Nuts (660075)
Opt - Raise Hopper, Main Broom Shut Off (690100)
Opt - Key Latch 9x (690102)
Opt - Seat Switch Engine Shut Off (690147)
Option - Hopper Pressure Bypass (690231)
Opt - Seat Belt For Standard Seat With Lock (690230)
Opt - Seat Belt For Suspension Seat With Lock (690233)
Opt - Air Conditioning Unit Riser (690317)
Opt - Air Conditioning, DSL (3316990)
Opt - Hopper, Stainless Steel (3315078)
Opt - Spotlight, Curb Broom (3316152)
Opt - Overhead Guard (3317260)
Opt - Heater (3316472)
Opt - Fan/Defroster (3317266)
Opt - Fire Extinguisher (3317268)
Opt - Light, Flash Amber (3317270)
Opt - Light, Flash Blue (3317271)
Opt - Light, Rotating Red (3317272)
Opt - Light, Rotating Amber (3317273)
Opt - Light, Strobe Amber (3317276)
Opt - HD Curb Broom, Right (3317302)
Opt - HD Curb Broom, Left (3330752)
Opt - Safety, Fire In Hopper Indicator (3317307)
Opt - Backup Alarm & Neutral Safety Switch (3317306)
Opt - Powerflex (3322125)
Opt - Air Cleaner, External Aux (3330896)
Opt - Air Cleaner, Heavy Duty (3331034)
Opt - Air Cleaner, External Aux Overhead Guard (3331338)
Opt - LH Curb Broom Kit Assembly (3338666)
Opt - Dual Curb Broom Kit Assembly With Hopper (3333918br)
Dual Curb Broom Sub-Assembly (3319421)
Side Broom Lift LH (3335420)
Opt - Extreme Environment Dust Cover (3334437)
Opt - Vacuumized Side Broom (3338470)
Hydraulic Schematic Am9d-Iii
Electrical Schematic With Kubota V1505
Warranty
