118
6,911
PowerBoss Sweeper AM9D-III AM9D SW9XKDSL Parts Catalog Wiring Diagram 988750 2014
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss AM9D-III Series AM9D SW9XKDSL Sweeper
Part Number: 988750
Publication Date: 2014
Number of Pages: 104 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Standard Abbreviations
Table Of Contents
Table Of Contents (Continued)
Frame Assembly Am9d-Iii
Hydraulic Brake Assembly
Hydraulic Brake Assembly - Continued
Brake - 8” ARMA L/H PN-3321450
Brake - 8” ARMA R/H PN-3321471
Steering Wheel, Gauges & Fuses
Steering Column
Side Broom Assembly - Drive Motor, Arm, And Mounting
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Lift & Rotation Cylinders, Hydraulic Hoses
RTR Switch Detail Lift Arm
This Page Is Intentionally Left Blank
Hopper - Filter And Shaker Motor Components
Hopper - Cover And Latch Components
Front Bumper Assembly
Battery Components
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Detail
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
Engine Kubota V1505 Diesel - Air Cleaner Assembly
Engine Kubota V1505 Diesel - Fuse Box Assembly
Engine Kubota V1505 Diesel - Fuse Box Details
Engine Kubota V1505 Diesel - Alternator, Water Pump, Fan, And Oil Pan
Engine Kubota V1505 Diesel - Flywheel, Starter, Head Cover, And Exhaust
Engine Kubota V1505 Diesel - Fuel System And Speed Control
Engine Kubota V1505 Diesel - Block And Freeze Plugs
Engine Kubota V1505 Diesel - Head
Engine Kubota V1505 Diesel - Main Bearing Case
Engine Kubota V1505 Diesel - Camshaft And Idle Gear Shaft
Engine Kubota V1505 Diesel - Piston And Crankshaft
Engine Kubota V1505 Diesel - Starter, Fan, Fuel Pump, Motor Mounting
Engine Kubota V1505 Diesel - Exhaust Detail
Engine Kubota V1505 Diesel - Radiator Detail
Engine Kubota V1505 Diesel - Radiator Coolant Tank & Mount
Engine Kubota V1505 Diesel - Radiator Mounts Detail
Engine Kubota V1505 Diesel - Radiator Assembly & Mounting Brackets
Engine Kubota V1505 Diesel - Radiator Assembly, Clamps, Hoses & Senders
Engine Kubota V1505 Diesel - Hydraulic Pump Detail
Electrical Schematic With Kubota V1505
Hydraulic Schematic Am9d-Iii
Warranty
