118
6,911
PowerBoss Sweeper AM9D-III AM9D-LH Parts Catalog Wiring Diagram 988750LHZH 2023
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss AM9D AM9D-III AM9D-LH Sweeper
Part Number: 988750LHZH
Publication Date: 2023
Number of Pages: 128 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Standard Abbreviations
Exploded Drawings And Parts Lists
Frame Assembly Am9d-Iii
Hydraulic Brake Assembly
Hydraulic Brake Assembly - Continued
Brake - 8” ARMA L/H PN-3321450
Brake - 8” ARMA R/H PN-3321471
LH Parking Brake Group
Directional Lighting, Four Way Flashers, And Rear Mirrors
Steering Wheel, Gauges & Fuses
Steering Column
Side Broom Assembly - Drive Motor, Arm, And Mounting (Page 1 Of 2)
Side Broom Assembly - Drive Motor, Arm, And Mounting (Page 2 Of 2)
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Lift & Rotation Cylinders, Hydraulic Hoses
RTR Switch Detail Lift Arm
Hopper - Filter And Shaker Motor Components
Hopper - Cover And Latch Components
Front Bumper Assembly
Battery Components
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Detail
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
Turbo Pre-Cleaner Group
Engine Air Cleaner Assembly
Engine Kubota V1505 Diesel - Fuse Box Details
Engine Kubota V1505 Diesel - Alternator, Water Pump, Fan, And Oil Pan
Engine Kubota V1505 Diesel - Flywheel, Starter, Head Cover, And Manifold
Engine Kubota V1505 Diesel - Fuel System And Speed Control
Engine Kubota V1505 Diesel - Motor Mounting
Engine Kubota V1505 Diesel - Exhaust Detail
Engine Kubota V1505 Diesel - Radiator Detail
Engine Kubota V1505 Diesel - Radiator Detail 2
Engine Kubota V1505 Diesel - Radiator Coolant Tank & Mount
Engine Kubota V1505 Diesel - Radiator Assembly & Mounting Brackets
Engine Kubota V1505 Diesel - Radiator Assembly, Clamps, Hoses & Senders
Engine Kubota V1505 Diesel - LH Pump Centering Group 690485
Hydraulic Auxiliary Pump And Fittings
Options
Opt - Air Conditioning, DSL (3316990)
Opt - Overhead Guard (690840lh)
Opt - Heater (690087)
Opt - Hd Curb Broom, Right (3317302)
Opt - Hd Curb Broom, Left (3330752)
Opt - Backup Alarm & Neutral Safety Switch (3317306)
Opt - Dual Side Broom (690751)
Assy- Actuator Rh 9X (690768)
Broom Assembly, DSB LH 9x Right Side (690769)
Opt - Directional Lighting, Four Way Flashers And Rear Mirrors (690540) 118
Hydraulic Schematic AM9D-LH
Electrical Schematic With Kubota V1505
