7,392
PowerBoss Sweeper AM9D-III AM9D-LH Parts Catalog Wiring Diagram 988750LHZH 2020
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss AM9D AM9D-III AM9D-LH Sweeper
Part Number: 988750LHZH
Publication Date: 2020
Number of Pages: 152 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Standard Abbreviations
Exploded Drawings And Parts Lists
Frame Assembly Am9d-Iii
Hydraulic Brake Assembly
Hydraulic Brake Assembly - Continued
Brake - 8” Arma L/H Pn-3321450
Brake - 8” Arma R/H Pn-3321471
Lh Parking Brake Group
Directional Lighting, Four Way Flashers, And Rear Mirrors
Steering Wheel, Gauges & Fuses
Steering Column
Side Broom Assembly - Drive Motor, Arm, And Mounting (Page 1 Of 2)
Side Broom Assembly - Drive Motor, Arm, And Mounting (Page 2 Of 2)
Side Broom Assembly - Adjustment Components
Engine Cover, Side Door, Latch & Rear Grill
Rear Drive Assembly
Directional Control Linkage Assembly
Console Assembly
Seat, Floor Pan & Tail Light
Lift & Rotation Cylinders, Hydraulic Hoses
Rtr Switch Detail Lift Arm
Hopper - Filter And Shaker Motor Components
Hopper - Cover And Latch Components
Front Bumper Assembly
Battery Components
Engine Pan, Hydraulic Hose Retainer & Latch
Fuel Tank Gasoline And Diesel
Hydraulic Reservoir Assembly
Hydraulic Control Valve Detail
Impeller Assembly
Main Broom Assembly
Side Broom & Main Broom
Vacuum Switch
Timer-Filter Shaker Sealed
Gasket Mount Assembly
Turbo Pre-Cleaner Group
Engine Air Cleaner Assembly
Engine Kubota V1505 Diesel - Fuse Box Details
Engine Kubota V1505 Diesel - Alternator, Water Pump, Fan, And Oil Pan
Engine Kubota V1505 Diesel - Flywheel, Starter, Head Cover, And Manifold
Engine Kubota V1505 Diesel - Fuel System And Speed Control
Engine Kubota V1505 Diesel - Motor Mounting
Engine Kubota V1505 Diesel - Exhaust Detail
Engine Kubota V1505 Diesel - Radiator Detail
Engine Kubota V1505 Diesel - Radiator Coolant Tank & Mount
Engine Kubota V1505 Diesel - Radiator Assembly & Mounting Brackets
Engine Kubota V1505 Diesel - Radiator Assembly, Clamps, Hoses & Senders
Engine Kubota V1505 Diesel - Lh Pump Centering Group 690485
Hydraulic Auxiliary Pump And Fittings
Options
OPT - Suspension Seat (600005)
OPT - Tires Pneumatic With Welded Nuts (660075)
OPT - Raise Hopper, Main Broom Shut Off (690100)
OPT - Key Latch 9x (690102)
OPT - Seat Switch Engine Shut Off (690147)
OPT - Hopper Pressure Bypass (690231)
OPT - Air Conditioning Unit Riser (690317)
OPT - Air Conditioning, Dsl (3316990)
OPT - Spotlight, Curb Broom (3316152)
OPT - Light, Amber, Led, Overhead Guard (690444)
OPT - Light, Amber, Led, Engine Cover (690444-1)
OPT - Light, Amber, Led, Cab (690444-3)
OPT - Overhead Guard (3317260)
OPT - Fan/Defroster (3317266)
OPT - Heater (690087)
OPT - Fire Extinguisher (3317268)
OPT - Hd Curb Broom, Right (3317302)
OPT - Hd Curb Broom, Left (3330752)
OPT - Backup Alarm & Neutral Safety Switch (3317306)
OPT - Powerflex (3322125)
OPT - Air Cleaner, Heavy Duty (3331034)
OPT - Air Cleaner, External Aux Overhead Guard (3331338)
OPT - Extreme Environment Dust Cover (3334437)
OPT - Vacuumized Side Broom (3338470)
OPT - Dual Side Broom (690751)
Assy- Actuator Rh 9x (690768)
Broom Assembly, Dsb Lh 9x Right Side (690769)
Hydraulic Schematic Am9d-Iii
Electrical Schematic With Kubota V1505
Warranty
