PowerBoss Sweeper 75E Operation Maintenance Manual
Brand: PowerBoss
Type of Machine: Sweeper
Type of Manual: Operation Maintenance Manual
Model: PowerBoss 75E Sweeper
Number of Pages: 122 Pages
Introduction
Introducing The SW 75 PowerBoss Sweeper
Special Features
Safety
Safety Symbols
Safety Decals
Basic PowerBoss Safety
Specifications
Component Descriptions
The Electrical System
The Lubrication System
The Hydraulics Systems
The Vacuum System
Sweep Components
Hoppers
Steering, Brakes, And Tires
Operation
Basic Operating Controls
Sweeping Controls
Debris Hopper Damp Controls
Operating Procedures
Pre—Operation Checks
Starting
Slowing And Stopping
Operating On Grades
Sweeping
Emptying The Hopper
Relocating The Trash In The Hopper
Transporting The Machine
Maintenance
Introducing
Preventive Maintenance Chart
Electrical Schematic
Battery Cleaning
Battery Replacement
Fuel System
Lubrication Chart
Hydraulics System
Filling The Fluid Reservoir
Maintaining Cooling Coil Efficiency
Changing The Hydraulic Fluid
Changing The Hydraulic Fluid Filter
Adjusting The Directional Control Return Spring
Adjusting Machine Speed
Hydraulic Schematic
Vacuum System
Belt Tensioning
Pulley Realignment
Lubrication Of Impeller Bearing Housing
Sweep Components
Broom Door Flap Inspection
Broom Door Flap Replacement And Adjustment
Main Broom Adjustment Test
Main Broom Taper Adjustment
Side Broom Adjustment Inspection
Side Broom Height (Wear) Adjustment
Side Broom Angie Adjustment
Sweep Components (Cont.)
Side Broom Lift Cable Adjustment
Main Broom Replacement
Side Broom Replacement
Hoppers
Hopper Removal And Replacement
Filter Removal
Filter Cleaning
Filter Replacement
Hopper Floor Clearance And Dump Adjustments
Hopper Vacuum Gasket Mount Adjustment
Hopper Flap Replacement
Hopper/Frame Seal Replacement
Steering
Parking/Emergency Brake
Parking Brake Adjustment
Tires
Changing Rear Solid Tires
Changing Front Press-On Tires
Miscellaneous Adjustments
Troubleshooting
Basic Machine Operating Problems
Sweeping Problems
Hydraulic System Problems
Parts
To Order Parts And Supplies
Frame
Rear Clip
Drive System
Hydraulic Reservoir
Hydraulic Valve
Directional Control
Cooling Carl
Impeller
Gasket Mount
Main Broom
Side Broom
Hopper
High Dump Arm Assembly
High Dump Safety Arm
Steering
Axle, Brakes And Wheel
