118
6,911
PowerBoss Rider Sweeper Armadillo 6X AM7D-III User Manual 4100043UM 2020
Brand: PowerBoss
Type of Machine: Rider Sweeper
Type of Manual: User Manual
Model:
PowerBoss Armadillo 6X SW6XKDSL ; SW6XKGAS ; SW6XKLPG ; SW6XKDSL-CE ; SW6XKLPG-CE Rider Sweeper
PowerBoss AM7D-III (Diesel) Rider Sweeper
Part Number: 4100043UM
Publication Date: 2020
Number of Pages: 84 Pages
Preface
Technical Specifications
Dimensions & Weight
Sweeping System
Features
Air-Moving System
Ergonomics System
Debris-Handling System
Drive-Train System
Chassis System
PowerBoss Innovations
Environmental Friendly Features
Clean Air
Lower Emissions
Safer Work Environment
Clean Energy
Safety Information
Important Safety Instructions
For Safety During Operation
Environmental Conditions For Safety
During Operation And Storage
For Safety When Servicing Or Maintaining
Machine
Safety Symbols
Safety Decals
Basic PowerBoss Safety
Machine Operation
Basic Operating Controls & Indicators
Ignition Switch
Light Switch
Horn
Fuel Level Gauge
Voltmeter Amp Gauge
Hour Meter
Engine Oil Pressure
Engine Coolant Temperature Gauge
Throttle / Glow Plug
Directional Control Pedal
Tilt Steering Release
Seat Adjustment
Brake Pedal
Sweeping Controls
Main Broom Switch
Side Broom Switch
Debris Hopper Dump Controls
Filter Shaker/Vacuum Control Switch
High Dump
Raise/Lower Hopper Lever
Hopper Dump Lever
RTR Lights 1 & 2
Operating Procedures
Pre-Operation Checks
Starting
Traveling
Slowing And Stopping
Operating On Grades
Sweeping
Empty Hopper With High Dump Feature
Using Rotary Trash Relocator (RTR)
Transporting The Machine
Using A Trailer Or Transport Vehicle
Pushing The Machine
Preventative Maintenance
Introduction
Scheduled Maintenance Chart
Preventative Maintenance Instructions
Air Intake System
Check Air Filter Service Indicator
Air Filter Element Removal
Air Filter Cleaning
Air Filter Inspection
Air Filter Installation
Battery Cleaning
Battery Replacement
Circuit Breakers
Fuses
Fuel System
Checking The Lpg Fuel Fi Lter Locks
Coolant System
Blowing Out Radiator Fins
Reverse Flow Flushing
Changing Engine Oil
Steering
Steering Cylinder
Steering Fork Assembly And Rod End
Lubrication Points
Latches & Hinges
Hydraulics System
Filling The Fluid Reservoir
Mobil Dte 10 Excel 32 - Viscosity, Astm D 445
Changing The Hydraulic Fluid
Changing The Hydraulic Fluid Filter
Sweep Components
Broom Door Flap Inspection
Broom Door Flap Replacement And Adjustment
Main Broom Adjustment
Main Broom Height Adjustment
Main Broom Taper Adjustment
Main Broom Replacement
Side Broom Height (Wear) Adjustment
Side Broom Lift Cable Adjustment
Side Broom Replacement
Hopper
Hopper Removal
Hopper Replacement
Floor Clearance And Dump Angle Adjustment 60
Filter Removal
Filter Cleaning
Filter Replacement
Vacuum Gasket Mount Adjustment
Flap Replacement
Frame Seal Replacement
Front Frame Seal
Side Frame Seal
Adjusting The Parking Brake Cable Length
Tires
Changing Solid Tires
Changing Pneumatic Tires
Miscellaneous Adjustments
Anti-Static Chain Adjustment
Latch And Hinge Maintenance
Cables
Troubleshooting
Troubleshooting Chart
Hydraulic Manifold Solenoids
Warranty
EC Declaration Of Conformity
