PowerBoss Nautilus Sweeper SM45CQP User Manual 988768UM 2020
- Download this document, you need 300 Gallons
Brand:
Type of Machine: Nautilus E Battery Operated Cylindrical Rider Scrubber\Sweeper
Type of Manual: User Manual
Model: PowerBoss Nautilus E SM45CQP, SM45CQP-CE Battery Operated Cylindrical Rider Scrubber\Sweeper
Part Number: 988768UM
Publication Date: 2020
Number of Pages: 84 Pages
Preface
Technical Specifications
Ce Declaration Of Conformity
Features
Air-Moving System
Ergonomics System
Chassis System
Environmental Friendly Features
Safer Work Environment
Safety Information
Important Safety Instructions
For Safety During Operation
Safety When Servicing Or Maintaining
Safety Symbols
Safety Decals
Basic Powerboss® Safety
Machine Operation
Operating Controls And Indicators
Key Switch
Light Switch
Horn Button
Circuit Breaker
Hour Meter
Indicator Lights
Recovery Tank Full Indicator
Solution Tank Empty Indicator
Battery Discharge Indicator
Directional Control Switch
Brake / Parking Brake
Seat Adjustment
Control Pedal
Instrument Panel Control Switches
Green “One-Touch” Switch
Squeegee Switch
Scrub Brush Switch
Side Scrub Brush Switch - Option
Main Brush Scrub Pressure Switch
Solution Control Knob
Basic Scrubbing/Filling/Emptying
Information
Choosing The Correct Type Of Brush
Filling The Solution Tank
Normal Scrubbing
Double Scrubbing
Stop Scrubbing
Water Pick Up Mode (Squeegee Only)
Stop Water Pick Up
Raising The Bumper
Draining/Cleaning The Recovery Tank
Emptying/Cleaning The Debris Hopper
Draining The Solution Tank
Operating Procedures
Pre-Operation Checks
Starting
Driving
Slowing And Stopping
Inclines Or Slippery Surfaces
Stop The Machine
Transporting The Machine
Using A Trailer Or Transport Vehicle 43
Options
Chemical Metering
Auto-Fill
Operator Seat Sensor (Ce)
Spray And Vacuum Wand
Suspension Seat
Side Scrub Brush
Seat Belts
Lights
Preventative Maintenance
Battery Cleaning
Circuit Breaker
Lubrication Points
Steering Fork Bearings
Rear Wheel Bearings
Squeegee Caster Bearings
Scrub Head Lift Arm Bearings
Latches & Hinges
Static Strap
Hydraulic Fluid Reservoir
Changing The Hydraulic Fluid
Scrubbing Components
Scrub Brushes
Replace Or Rotate The Cylindrical Scrub Brushes 59
Checking The Scrub Brush Pattern
Adjusting The Scrub Brush Pattern (Taper)
Adjusting The Scrub Brush Pattern (Equal Width) 63
Side Scrub Brush (Option)
Replacing The Side Scrub Brush
Squeegees
Lowering Squeegee For Adjustment
Checking The Rear Squeegee Blade Flare
Adjusting The Rear Squeegee Blade Flare
Leveling The Rear Squeegee
Turning Or Replacing The Rear Squeegee Blades 68
Side Squeegees
Replacing Side Squeegee Blades
Side Scrub Brush Squeegee (Option) 71
Replacing Side Scrub Brush Squeegee Blade 71
Skirts And Seals
Scrub Deck Front Skirt
Cover Seals
Brakes
Service Brakes
Adjusting The Brake System
Drive Wheel Motor
Rear Tires
Changing Solid Tires
Seat Mount Adjustment
Solution Delivery Bar & Filter System 75
Solution Filter
Troubleshooting
Brand:
Preface
Features
Air-Moving System
Ergonomics System
Chassis System
Safety Information
Safety Symbols
Safety Decals
Machine Operation
Key Switch
Light Switch
Horn Button
Circuit Breaker
Hour Meter
Indicator Lights
Seat Adjustment
Control Pedal
Squeegee Switch
Scrub Brush Switch
Information
Normal Scrubbing
Double Scrubbing
Stop Scrubbing
Stop Water Pick Up
Raising The Bumper
Starting
Driving
Stop The Machine
Options
Chemical Metering
Auto-Fill
Suspension Seat
Side Scrub Brush
Seat Belts
Lights
Battery Cleaning
Circuit Breaker
Lubrication Points
Rear Wheel Bearings
Latches & Hinges
Static Strap
Scrub Brushes
Squeegees
Side Squeegees
Skirts And Seals
Cover Seals
Brakes
Service Brakes
Drive Wheel Motor
Rear Tires
Solution Filter
Troubleshooting
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
