118
6,911
PowerBoss Nautilus Sweeper PB45HDSL To PB45HLPUK Parts Catalog 988752 04.2023
Brand: PowerBoss
Type of Machine: Rider Scrubber/Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss Nautilus Hi-Dump & Nautilus Hi-Dump CE Rider Scrubber/Sweeper
PB45HDSL, PB45HGAS, PB45HLP, PB45HDSLCE, PB45HGASCE,
PB45HLPCE, PB45HDSLUK, PB45HGASUK, PB45HLPUK
Part Number: 988752
Publication Date: 04.2023
Number of Pages: 256 Pages
Preface
Technical Specifications
General Machine Specifications
Scrubbing System
Ce Declaration Of Conformance
Parts Breakdown
Frame Group (770105)
Brake Group (730101)
Rear Wheel Group (770109)
Front Wheel Group (730102)
Steering Fork Group (730103)
Console Group (730152)
Steering Column Group (730104)
Instrument Panel Group - Diesel (770108)
Instrument Panel Group - Gas (770107)
Instrument Panel Group - Lpg (770106)
Hi-Dump Instrumentation Group One (770122)
Timer Assembly Box (748438)
Hi-Dump Instrumentation Group Two (770123)
Electrical Box Group - Diesel (730156)
Directional Control Group (730110)
Pump Linkage Group (730111)
Scrub Head Group (730112)
Scrub Brush Lift Group (730113)
Scrub Brush Idler Group (730114)
Brush Door Group (730115)
Squeegee Lift Group (770100)
Squeegee Linkage Group (770101)
Squeegee Group (730118)
Side Squeegee Group - Rh (730120)
Side Squeegee Group - Lh (730157)
Solution Tank Group (770104)
Solution Control Group (770114)
Recovery Tank Group (770102)
Recovery Tank Drain Group (770124)
Hopper Group (770113)
Hopper Lift Group (770111)
Hopper Dump Door Group (770112)
Rear Bumper Group (770115)
Bumper Lift Group (770110)
Impeller Group (770674)
Impeller Hydraulic Manifold Group (770116)
Hydraulic Reservoir Group (730127)
Hydraulic Pump Group (770675)
Hydraulic Valve Group (730137)
Hydraulic Manifold Components Group (730170)
Engine Mount Group - Diesel (730128)
Engine Mount Group - Gas (730164)
Engine Mount Group - Lpg (730163)
Air Cleaner Group - Diesel (730131)
Air Cleaner Group - Gas (730129)
Air Cleaner Group - Lpg (730130)
Radiator Group (730132)
Radiator Overflow Bottle Group (730133)
Oil Cooler Group (730134)
Exhaust Group - Diesel (730154)
Exhaust Group - Gas / Lp (730178)
Fuel Tank Mount Group - Diesel (730140)
Fuel Tank Mount Group - Gas (730139)
Lpg Tank Mount Group (730138)
Ce Lpg Tank Mount Group (730138-Ce)
Fuel Line Group - Diesel (730153)
Fuel Component Group - Gas (730141)
Throttle Solenoid Group - Diesel (730151)
Battery Group (730142)
Front Cover Group (730143)
Top Cover Group (730144)
Side Door Group (731914)
Seat Door Group (731913)
Seat Mount Group (730147)
Rear Step Group, Hd (770139)
Hydraulic Hose Group (730148)
Hydraulic Hi-Dump Hose Group (770118)
Hydraulic Hi-Dump Hose Routing (770119)
Hose Clamp Group One (770120)
Hose Clamp Group Two (770120)
Decal Group (770121)
Electrical Group (730116-Hd)
Brush/Broom Group (730175)
Options - Parts Breakdown
Option - Side Brush Group (730000)
Option - Side Brush Lift Group (730001)
Option - Side Brush Solution Control Group (730002)
Option - Side Brush Hydraulic Hose Group (730011)
Option - Side Brush Scrub Head Group (730028)
Option - Side Brush Steering Column Group (730029)
Option - Overhead Guard Group (730003)
Option - Light Group On Overhead Guard
Option - Light Group On Solution Tank
Option - Light Group When Chemical Metering And
Reserve Lpg Tank Installed
Option - Magnetic Sweeper Bar (731918)
Option - Suspension Seat Group (730007)
Option - Backup Alarm Group (730008)
Option - Chemical Metering Group (730015)
Option - Fire Extinguisher Group (730016)
Option - Auto Fill Group (730017)
Option - Constant Solution (731910)
Option - Urethane Squeegee Blade Group (730024)
Option - Urethane Side Brush Squeegee Group (730025)
Option - Seat Switch (730031)
Option - Side Broom Group (730032)
Option - Side Broom Lift And Adjustment Group (730033)
Option - Side Broom Hydraulic Hose Group (730034)
Option - Side Brush Hydraulic Hose Routing (730038)
Option - Spray And Vac Wand Tool Group (730021 - Part 1)
Option - Spray And Vac Wand Hose Group (730021 Part 2)
Option - Spray And Vac Wand Mount Group (730022)
Option - Spray And Vac Wand Pump Group (730023)
Option - Spray And Wash Group (730040)
Option - Pressure Washer Pump Group (730041-1)
Option - Pressure Washer Hose And Wand Group (730041-2)
Option - Pressure Washer Hydraulic Hose Group (730041-3)
Option - Low Lp Indicator Group (730042)
Option - Side Broom Water Mist Group (730043)
Option - Rear Squeegee Guard (730048)
Option - Front Wheel Fender (730052)
Option - Reserve Lpg Tank Group (730160)
Option - Backup Alarm Group - Cm, Reserve Lpg In (730169)
Option - Dust Supression (731482)
Option - Dry Sweep (770002)
Pump Sub Group (770002-1)
Skirt Sub Group (770002-2)
Water Mist Sub Group (770002-4)
Miscellaneous Additional Options
Layouts - Electrical/Hydraulic
Electrical Schematic Layout
Electrical Schematic Layout (Point To Point Wiring)
Hydraulic System Layout
Hydraulic System Layout With Optional Side Scrub Brush
Timer Dip-Switch Settings
