PowerBoss Nautilus Sweeper PB45DSLH Parts Catalog 988749H 03.2020
- Download this document, you need 300 Gallons
Brand: PowerBoss
Type of Machine: Rider Scrubber/Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss Nautilus Diesel PB45DSLH Rider Scrubber/Sweeper
Part Number: 988749H
Publication Date: 03.2020
Number of Pages: 250 Pages
Preface
Technical Specifications
Parts Breakdown
Frame Group (730100)
Brake Group (730101)
Rear Wheel Group (730105)
Front Wheel Group (730102)
Steering Fork Group (730103)
Console Group (730152)
Steering Column Group (730104)
Instrument Panel Group - Diesel (730108)
Instrument Panel Group - Gas (730107)
Instrument Panel Group - LPG (730106)
Instrumentation Group (730109)
Electrical Box Group - Diesel (730156)
Directional Control Group (730110)
Pump Linkage Group (730111)
Scrub Head Group (730112)
Scrub Brush Lift Group (730113)
Scrub Brush Idler Group (730114)
Brush Door Group (730115)
Squeegee Lift Group (730119)
Squeegee Linkage Group (730158)
Squeegee Group (730118)
Side Squeegee Group - Rh (730120)
Side Squeegee Group - Lh (730157)
Solution Tank Group (730121)
Solution Control Group (730123)
Recovery Tank Group (730122)
Recovery Tank Drain Group (730179)
Plastic Hopper Group (730173)
Hopper Cradle Group (730174)
Rear Bumper Group (730125)
Rear Step Group (730055)
Bumper Lift Group (730159)
Impeller Group (730126)
Impeller Hydraulic Manifold Assembly (730790-1)
Hydraulic Reservoir Group (730127)
Hydraulic Pump Group (730136)
Hydraulic Valve Group (730137)
Hydraulic Manifold Components Group (730170)
Engine Mount Group - Diesel (730128)
Engine Mount Group - Gas (730164)
Engine Mount Group - LPG (730163)
Air Cleaner Group - Diesel (730131)
Air Cleaner Group - Gas (730129)
Air Cleaner Group - LPG (730130)
Radiator Group (730132)
Radiator Overflow Bottle Group (730133)
Oil Cooler Group (730134)
Exhaust Group - Diesel (730154)
Exhaust Group - Gas / LP (730178)
Fuel Tank Mount Group - Diesel (730140)
Fuel Tank Mount Group - Gas (730139)
LPG Tank Mount Group (730138)
Ce LPG Tank Mount Group (730138-Ce)
Fuel Line Group - Diesel (730153)
Fuel Component Group - Gas (730141)
Throttle Solenoid Group - Diesel (730151)
Battery Group (730142)
Front Cover Group (730143)
Top Cover Group (730144)
Side Door Group (731914)
Seat Door Group (731913)
Seat Mount Group (730147)
Hydraulic Hose Group (730148)
Hose Clamp Group (730149)
Decal Group (730150)
Electrical Group (730116)
Brush/Broom Group (730175)
Options - Parts Breakdown
Option - Side Brush Group (730000)
Option - Side Brush Lift Group (730001)
Option - Side Brush Solution Control Group (730002)
Option - Side Brush Hydraulic Hose Group (730011)
Option - Side Brush Scrub Head Group (730028)
Option - Side Brush Steering Column Group (730029)
Option - SSB Hydraulic Manifold Group (730171)
Option - Overhead Guard Group (730003)
Option - Light Group (On Overhead Guard) (730189)
Option - Suspension Seat Group (730007)
Option - Backup Alarm Group (730008)
Standard On Ce And UK Models
Option - Seat Belt (For Suspension Seat) Group (730009)
Option - Seat Belt (For Standard Seat) Group (730010)
Option - Light Group (On Solution Tank) (730189-4)
Option - Chemical Metering Group (730015)
Option - Fire Extinguisher Group (730016)
Option - Auto Fill Group (730017)
Option - Spray And Vac Wand Tool Group (730021 - Part 1)
Option - Spray And Vac Wand Hose Group (730021 Part 2)
Option - Spray And Vac Wand Mount Group (730022)
Option - Spray And Vac Wand Pump Group (730023)
Option - Urethane Squeegee Blade Group (730024)
Option - Urethane Side Brush Squeegee Group (730025)
Option - Stainless Steel Hopper Group (730027)
Option - Seat Switch (730031)
Standard On Ce And Uk Models
Option - Side Broom Group (730032)
Option - Side Broom Lift And Adjustment Group (730033)
Option - Side Broom Hydraulic Hose Group (730034)
Option - Side Brush Hydraulic Hose Routing (730038)
Option - Spray And Wash Group (730040)
Option - Pressure Washer Pump Group (730041-1)
Option - Pressure Washer Hose And Wand Group (730041-2)
Option - Pressure Washer Hydraulic Hose Group (730041-3)
Option - Low LP Indicator Group (730042)
Option - Side Broom Water Mist Group (730043)
Option - Rear Squeegee Guard (730048)
Option - PVC Free Components (730049)
Option - Tie Downs (730026)
Option - Front Wheel Fender (730052)
Option - Dry Sweep - Pump (730053-1)
Option - Dry Sweep - Skirt (730053-2)
Option - Dry Sweep - Radiator Grille (730053-3)
Option - Dry Sweep - Water Mist (730053-4)
Option - Heated Sol Group, Coil Type, LP (730057)
Option - Heated Sol Group, Coil Type, DSL (730058)
Option - Reserve LPG Tank Group (730160)
Option - Light Group When Chemical Metering And
Reserve LPG Tank Installed (730189-5)
Option - Backup Alarm Group - Cm, Reserve LPG In (730169)
Option - Pressure Washer (731457)
Option - Dust Suppression (731482)
Miscellaneous Additional Options
Layouts - Electrical/Hydraulic
Electrical Schematic Layout
Electrical Schematic Layout (Point To Point Wiring)
Hydraulic System Layout
Hydraulic System Layout With Optional Side Scrub Brush
Timer Dip-Switch Settings
Brand: PowerBoss
Preface
Parts Breakdown
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
