118
6,911
PowerBoss Nautilus Sweeper PB45DSL To PB45LPUK Parts Catalog 988749 2021
Brand: PowerBoss
Type of Machine: Rider Scrubber/Sweeper
Model: PowerBoss Rider Scrubber/Sweeper
Nautilus: PB45DSL, PB45GAS, PB45LP, PB45DSLCE, PB45GASCE, PB45LPCE
Nautilus CE: PB45DSL-D, PB45GAS-D, PB45LP-D, PB45DSLUK, PB45GASUK, PB45LPUK
Part Number: 988749
Publication Date: 2021
Number of Pages: 280 Pages
Preface
Technical Specifications
Parts Breakdown
Frame Group (730100)
Brake Group (730101)
Rear Wheel Group (730105)
Front Wheel Group (730102)
Steering Fork Group (730103)
Console Group (730152)
Steering Column Group (730104)
Instrument Panel Group - Diesel (730108)
Instrument Panel Group - Gas (730107)
Instrument Panel Group - Lpg (730106)
Instrumentation Group (730109)
Electrical Box Group - Diesel (730156)
Directional Control Group (730110)
Pump Linkage Group (730111)
Cylindrical Scrub Head Group (730112)
Disc Scrub Head Group (730191)
Cylindrical Scrub Brush Lift Group (730113)
Disc Scrub Brush Lift Group (730192)
Disc Scrub Head Solution Control Group (730194)
Scrub Brush Idler Group (730114)
Brush Door Group (730115)
Squeegee Lift Group (730119)
Cylindrical Squeegee Linkage Group (730158)
Disc Squeegee Linkage Group (730158-D)
Disc Side Squeegee Mount Group (730193)
Squeegee Group (730118)
Cylindrical Side Squeegee Group - Rh (730120)
Disc Side Squeegee Group - Rh (730120-D)
Cylindrical Side Squeegee Group - Lh (730157)
Disc Side Squeegee Group - Lh (730157-D)
Solution Tank Group (730121)
Solution Control Group (730123)
Recovery Tank Group (730122)
Recovery Tank Drain Group (730179)
Plastic Hopper Group (730173)
Hopper Cradle Group (730174)
Cylindrical Rear Bumper Group (730125)
Disc Rear Bumper Group (730125-D)
Rear Step Group (730055)
Bumper Lift Group (730159)
Impeller Group (730126)
Impeller Hydraulic Manifold Assembly (730790-1)
Hydraulic Reservoir Group (730127)
Hydraulic Pump Group (730136)
Hydraulic Valve Group (730137)
Hydraulic Manifold Components Group (730170)
Engine Mount Group - Diesel (730128)
Engine Mount Group - Gas (730164)
Engine Mount Group - Lpg (730163)
Air Cleaner Group - Diesel (730131)
Air Cleaner Group - Gas (730129)
Air Cleaner Group - Lpg (730130)
Radiator Group (730132)
Radiator Overflow Bottle Group (730133)
Oil Cooler Group (730134)
Exhaust Group - Diesel (730154)
Exhaust Group - Gas / Lp (730178)
Fuel Tank Mount Group - Diesel (730140)
Fuel Tank Mount Group - Gas (730139)
Cylindrical Lpg Tank Mount Group (730138)
Ce Cylindrical Lpg Tank Mount Group (730138-Ce)
Disc Lpg Tank Mount Group (730138-D)
Fuel Line Group - Diesel (730153)
Fuel Component Group - Gas (730141)
Throttle Solenoid Group - Diesel (730151)
Battery Group (730142)
Front Cover Group (730143)
Top Cover Group (730144)
Side Door Group (731914)
Seat Door Group (731913)
Seat Mount Group (730147)
Cylindrical Hydraulic Hose Group (730148)
Disc Hydraulic Hose Group (730195)
Hose Clamp Group (730149)
Decal Group (730150)
Electrical Group (730116)
Brush/Broom Group (730175)
Options - Parts Breakdown
Option - Side Brush Group (730000)
Option - Side Brush Lift Group (730001)
Option - Side Brush Solution Control Group (730002)
Option - Side Brush Hydraulic Hose Group (730011)
Option - Side Brush Scrub Head Group (730028)
Option - Side Brush Steering Column Group (730029)
Option - Ssb Hydraulic Manifold Group (730171)
Option - Overhead Guard Group (730003)
Option - Suspension Seat Group (730007)
Option - Backup Alarm Group (730008)
Standard On Ce And Uk Models
Option - Chemical Metering Group (730015)
Option - Fire Extinguisher Group (730016)
Option - Auto Fill Group (730017)
Option - Spray And Vac Wand Tool Group (730021 - Part 1)
Option - Spray And Vac Wand Hose Group (730021 Part 2)
Option - Spray And Vac Wand Mount Group (730022)
Option - Spray And Vac Wand Pump Group (730023)
Option - Urethane Squeegee Blade Group (730024)
Option - Urethane Side Brush Squeegee Group (730025)
Option - Stainless Steel Hopper Group (730027)
Option - Seat Switch (730031)
Option - Side Broom Group (730032)
Option - Side Broom Lift And Adjustment Group (730033)
Option - Side Broom Hydraulic Hose Group (730034)
Option - Side Brush Hydraulic Hose Routing (730038)
Option - Spray And Wash Group (730040)
Option - Pressure Washer Pump Group (730041-1)
Option - Pressure Washer Hose And Wand Group (730041-2)
Option - Pressure Washer Hydraulic Hose Group (730041-3)
Option - Low Lp Indicator Group (730042)
Option - Side Broom Water Mist Group (730043)
Option - Rear Squeegee Guard (730048)
Option - Pvc Free Components (730049)
Option - Tie Downs (730026)
Option - Front Wheel Fender (730052)
Option - Dry Sweep - Pump (730053-1)
Option - Dry Sweep - Skirt (730053-2)
Option - Dry Sweep - Water Mist (730053-4)
Option - Cylindrical Heated Sol Group, Coil Type, Lp (730057)
Option - Disc Heated Sol Group, Coil Type, Lp (730057-D)
Option - Heated Sol Group, Coil Type, Dsl (730058)
Option - Constant Solution (731910)
Option - Heated Solution, Constant Solution, Lp (731995)
Option - Magnetic Sweeper Bar (731918)
Option - Reserve Lpg Tank Group (730160)
Option - Backup Alarm Group - Cm, Reserve Lpg In (730169)
Option - Pressure Washer (731457)
Option - Disinfectant Spray Bar (731950)
Disinfectant Spray Bar With Rear Squeegee Guard (731955)
Solution Supply Assembly (731963)
Option - Dust Suppression (731482)
Option - Light Groups (On Overhead Guard)
Option - Light Groups (On Solution Tank)
Option - Light Groups When Chemical Metering And
Reserve Lpg Tank Installed
Miscellaneous Additional Options
Layouts - Electrical/Hydraulic
Electrical Schematic Layout
Electrical Schematic Layout (Point To Point Wiring)
Hydraulic System Layout
Hydraulic System Layout With Optional Side Scrub Brush
Timer Dip-Switch Settings
