118
6,911
PowerBoss Nautilus Sweeper PB45DSL To PB45LPGCE User Manual 988749UM 2015
Brand: PowerBoss
Type of Machine: Rider Scrubber/Sweeper
Type of Manual: User Manual
Model: PowerBoss Rider Scrubber/Sweeper
Nautilus: PB45DSL(Diesel), PB45GAS(Gas), PB45LPG(LPG)
Nautilus CE: PB45DSLCE(Diesel), PB45LPGCE(LPG)
Part Number: 988749UM
Publication Date: 2015
Number of Pages: 100 Pages
Preface
Technical Specifications
General Machine Specifications
Scrubbing System
Features
Air-Moving System
Ergonomics System
Drive-Train System
Chassis System
Environmental Friendly Features
Lower Emissions
Safer Work Environment
Safety Information
Important Safety Instructions
For Safety During Operation
Safety When Servicing Or Maintaining
Safety Symbols
Safety Decals
Basic Powerboss® Safety
Machine Operation
Operating Controls And Indicators
Ignition Switch
Throttle / Glow Plug Switch
Murphy Switch
Light Switch
Horn Button
Fuel Level Gauge
Circuit Breaker
Idle Button
Hour Meter
Indicator Lights
Check Engine Indicator
Engine Oil Pressure Indicator
Engine Coolant Temperature Indicator22
Recovery Tank Full Indicator
Solution Tank Empty Indicator
Directional Control Pedal
Brake / Parking Brake
Tilt Steering Lever
Seat Adjustment
Nstrument Panel Control Switches
Green “One-Touch” Switch
Squeegee Switch
Scrub Brush Switch
Side Scrub Brush Switch - Option
Main Brush Scrub Pressure Knob
Side Brush Scrub Pressure
Solution Control Knob
Basic Scrubbing/Filling/Emptying
Information
Choosing The Correct Type Of Brush
Filling The Solution Tank
Normal Scrubbing
Double Scrubbing
Stop Scrubbing
Water Pick Up Mode (Squeegee Only)
Stop Water Pick Up
Draining/Cleaning The Recovery Tank
Emptying/Cleaning The Debris Hopper
Draining The Solution Tank
Operating Procedures
Pre-Operation Checks
Starting
Driving
Slowing And Stopping
Inclines Or Slippery Surfaces
Stop The Machine
Transporting The Machine
Using A Trailer Or Transport Vehicle 43
Pushing Or Towing The Machine
Options
Chemical Metering
Auto-Fill
Neutral Start Sensor (Ce)
Operator Seat Sensor (Ce)
Key Locked Entry Doors (Ce)
Spray And Vacuum Wand
Preventative Maintenance
Scheduled Maintenance Chart
Preventative Maintenance Instructions 52
Air Intake System
Battery Cleaning
Circuit Breaker
Fuses
Fuel System
Coolant System
Lubrication
Lubrication Points
Steering Fork Bearings
Rear Wheel Bearings
Squeegee Caster Bearings
Scrub Head Lift Arm Bearings
Latches & Hinges
Static Strap
Hydraulic Fluid Reservoir
Hydraulic Fluid Viscosity Specifications
Changing The Hydraulic Fluid
Hydraulic Fluid Filter
Changing The Hydraulic Fluid Filter
Maintaining Hydraulic Oil Cooler Efficiency
Adjusting The Propulsion Pump Neutral Setting 64
Drive Motor
Scrubbing Components
Scrub Brushes
Replace Or Rotate The Cylindrical Scrub Brushes 67
Checking The Scrub Brush Pattern
Adjusting The Scrub Brush Pattern (Taper)
Adjusting The Scrub Brush Pattern (Equal Width) 71
Side Scrub Brush (Option)
Replacing The Side Scrub Brush
Squeegees
Lowering Squeegee For Adjustment (Engine Off) 73
Checking The Rear Squeegee Blade Flare
Adjusting The Rear Squeegee Blade Flare
Leveling The Rear Squeegee
Turning Or Replacing The Rear Squeegee Blades 76
Side Squeegees
Replacing Side Squeegee Blades
Side Scrub Brush Squeegee (Option) 79
Replacing Side Scrub Brush Squeegee Blade 79
Skirts And Seals
Scrub Deck Front Skirt
Scrub Deck Rear Skirt
Hopper Vacuum Seal
Cover Seals
Brakes
Service Brakes
Adjusting The Brake System
Tires
Changing Solid Tires
Front Tires
Rear Tires
Sensing Switches
Adjusting The Neutral Sensing Switch
Neutral Sensing Switch Adjustment:
Adjusting The Nautilus Reverse Sensing Switch 85
Nautilus Reverse Sensing Switch Adjustment: 86
Covers
Seat Mount Adjustment:
Solution Delivery Bar & Filter System 88
Solution Filter
Troubleshooting
Ce Declaration Of Conformity
Warranty
