118
6,911
PowerBoss Nautilus Sweeper PB45DSL To PB45LPGCE Parts Catalog 988749 08.2015
Brand: PowerBoss
Type of Machine: Rider Scrubber/Sweeper
Type of Manual: Parts Catalog, Hydraulic And Electrical Schematic
Model: PowerBoss Rider Scrubber/Sweeper
Nautilus: PB45DSL(Diesel), PB45GAS(Gas), PB45LPG(LPG)
Nautilus CE: PB45DSLCE(Diesel), PB45LPGCE(LPG)
Part Number: 988749
Publication Date: 08.2015
Number of Pages: 224 Pages
Preface
Technical Specifications
General Machine Specifications
Scrubbing System
Parts Breakdown
Frame Group (730100)
Brake Group (730101)
Rear Wheel Group (730105)
Front Wheel Group (730102)
Steering Fork Group (730103)
Console Group (730152)
Steering Column Group (730104)
Instrument Panel Group - Diesel (730108)
Instrument Panel Group - Gas (730107)
Instrument Panel Group - Lpg (730106)
Instrumentation Group (730109)
Electrical Box Group - Diesel (730156)
Directional Control Group (730110)
Pump Linkage Group (730111)
Scrub Head Group (730112)
Scrub Brush Lift Group (730113)
Scrub Brush Idler Group (730114)
Brush Door Group (730115)
Squeegee Lift Group (730119)
Squeegee Linkage Group (730158)
Squeegee Group (730118)
Side Squeegee Group - Rh (730120)
Side Squeegee Group - Lh (730157)
Solution Tank Group (730121)
Solution Control Group (730123)
Recovery Tank Group (730122)
Recovery Tank Drain Group (730155)
Hopper Group (730124)
Plastic Hopper Group (730173)
Hopper Cradle Group (730174)
Rear Bumper Group (730125)
Bumper Left Group (730159)
Impeller Group (730126)
Impeller Hydraulic Manifold Group (730172)
Hydraulic Reservoir Group (730127)
Hydraulic Pump Group (730136)
Hydraulic Valve Group (730137)
Hydraulic Manifold Components Group (730170)
Engine Mount Group - Diesel (730128)
Engine Mount Group - Gas (730164)
Engine Mount Group - Lpg (730163)
Air Cleaner Group - Diesel (730131)
Air Cleaner Group - Gas (730129)
Air Cleaner Group - Lpg (730130)
Radiator Group (730132)
Radiator Overflow Bottle Group (730133)
Oil Cooler Group (730134)
Exhaust Group - Diesel (730154)
Exhaust Group - Gas - Lpg (730135)
Fuel Tank Mount Group - Diesel (730140)
Fuel Tank Mount Group - Gas (730139)
Lpg Tank Mount Group (730138)
Fuel Line Group - Diesel (730153)
Fuel Component Group (730141)
Throttle Solenoid Group - Diesel (730151)
Battery Group (730142)
Front Cover Group (730143)
Top Cover Group (730144)
Side Door Group (730145)
Seat Door Group (730146)
Seat Mount Group (730147)
Hydraulic Hose Group (730148)
Hose Clamp Group (730149)
Decal Group (730150)
Electrical Group (730116)
Brush/Broom Group (730175)
Options - Parts Breakdown
Option - Side Brush Group (730000)
Option - Side Brush Lift Group (730001)
Option - Side Brush Solution Control Group (730002)
Option - Side Brush Hydraulic Hose Group (730011)
Option - Side Brush Scrub Head Group (730028)
Option - Side Brush Steering Column Group (730029)
Option - Ssb Hydraulic Manifold Group (730171)
Option - Overhead Guard Group (730003)
Option - Strobe Light Group (On Overhead Guard) (730004)
Option - Rotating Light Group (On Overhead Guard) (730005)
Option - Flashing Light Group (On Overhead Guard) (730006)
Option - Suspension Seat Group (730007)
Option - Backup Alarm Group (730008)
Option - Seat Belt (For Suspension Seat) Group (730009)
Option - Seat Belt (For Standard Seat) Group (730010)
Option - Strobe Light Group (On Solution Tank) (730012)
Option - Rotating Light Group (On Solution Tank) (730013)
Option - Flashing Light Group (On Solution Tank) (730014)
Option - Chemical Metering Group (730015)
Option - Fire Extinguisher Group (730016)
Option - Auto Fill Group (730017)
Option - Spray And Vac Wand Tool Group (730020)
Option - Spray And Vac Wand Hose Group (730021)
Option - Spray And Vac Wand Mount Group (730022)
Option - Spray And Vac Wand Pump Group (730023)
Option - Urethane Squeegee Blade Group (730024)
Option - Urethane Side Brush Squeegee Group (730025)
Option - Stainless Steel Hopper Group (730027)
Option - Seat Switch (730031)
Option - Side Broom Group (730032)
Option - Side Broom Lift And Adjustment Group (730033)
Option - Side Brush Hydraulic Hose Routing (730038)
Option - Low Lp Indicator Group (730042)
Option - Reserve Lpg Tank Group (730160)
Option - Strobe Light Group W/Chemical Metering (730166)
Option - Rotating Light Group W/Chemical Metering (730167)
Option - Flashing Light Group W/Chemical Metering (730168)
Option - Backup Alarm Group - Cm, Reserve Lpg In (730169)
Layouts - Electrical/Hydraulic
Electrical Schematic Layout
Notes
Hydraulic System Layout
Hydraulic System Layout With Optional Side Scrub Brush
Notes
Warranty
