mhhauto
19
25,728
Paccar ESA v4.3.1.121
Paccar ESA v4.3.1.121 11/7/2013
– New Features:
• No idle shutdown timer and override popup
• Vehicle speed limiter popup functionality
• HC burn popup for Peterbilt
• Tire pressure monitoring system (TPMS) popup
• Stability disabled due to front drive popup
• Tractor ABS lamp telltale with multiple addresses
• Non-diesel engine by disable DTC log and fuel economy related information display
• Exterior notification of regeneration
• Engine coolant level SPN and DM1
• Euro 4 DEF telltale
• Updated DEF popup functionality
• NAMUX3-096 MX DTC Pop-Ups (this popup will display the service call number such as 800 592 7747, 800 473 8372, 800 944 0251)
– Defects addressed:
• Made non-suppressible warning come back in driving mode after suppressed in parked mode
• Made CC set speed visible when cruise is active
• Made logic to display either protection timer or derate timer but not both
• Fix odometer not working
• Add the missing NOT logic which prevented CECU to log DTC
• Fixed PB retarder telltale in area 4 of highline
• Set the brake saver parameter default to off
• Derate Icon was not shown under Expected Conditions
• DEF Quality Popup was Suppressible
• Water In Fuel Warning did not Activate
http://paccar.httpsvc.vitalstreamcd...m_com/Application/ESA_Update_Announcement.doc
http://paccar.httpsvc.vitalstreamcd...ication/ESA_4.3_Installation_Instructions.doc
http://paccar.httpsvc.vitalstreamcdn.com/paccar_vitalstream_com/Application/VpdSetup.zip
http://paccar.httpsvc.vitalstreamcdn.com/paccar_vitalstream_com/Application/ESA43Hotfix.exe
