OBD II Connector
The OnBoard Diagnostics vehicle plug has 16 pins.
Normally this female plug is only equipped with the metal pins that the car needs in order to satisfy the protocols that it’s Electronic Controller Units (ECUs) “speak”.
Therefore, it is possible (within a reasonable limit),to “guess” which protocol(s) a car complies to, just by looking at those pins.
The pins are numbered as follows:
Examples (may be incorrect!):
An ISO9141-2 car needs pins 5,7,16, and may need 15.
An ISO14230-4 car needs pins 5,7,16, and may need 15.
An SAE-J1850 (VPW) car needs pins 2,5,16.
An SAE-J1850 (PWM) car needs pins 2,5,10,16.
An ISO-15765-4 car needs pins 5,6,14,16.
NOTE-1: It seems the L-line is “optional” for both ISO9141-2 and ISO14230-4,
and that probably only older cars will need it…
NOTE-2: It is possible that a car suports more than one “official” protocol,
and so it will have a combination of these options. They normally will
also sport a few of those “discretionary” pins… (there’s a lot to hack
NOTE-3: Be advised that ALL the pins (except 4,5,16) can have non-standard
allocation!!! This means that (for example) an ISO9141-2/ISO14230-4 car can
use the SAE-J1850 pins for whatever they want (and vice-versa)!!!! The only
rule stated in the specs is that when this happens, those pins cannot confuse
or damage a specification-compliant tool!…
NOTE-4: You may or may not use pin 4 (chassis ground). If you draw power from
the plug, then it’s a good idea to use it (max power = 12Vx4A = 48W).
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
