Moxy Truck MT26 MT31 Trouble Shooting Manual
Brand: MOXY
Type of Manual: Trouble Shooting Manual, Hydraulic Diagram, Electrical Diagram
Model: MOXY MT26 MT31 Truck
List of Files:
00-General Information.pdf (35 Pages)
MT26/MT31 Trouble Shooting Manual
General Info New Trucks
MT26
MT31
Operator Comfort
Instrument Panels
Operator Controls
Tandem Swing
Tilting Cab
New Drivetrain
01-Engine.pdf (65 Pages)
Scania DC9 51A
Engine Specifications
DEC2 Engine Controls
Engine Emission
Regulations
Charge Air Cooler
Power & Torque
Oil Filter & Centrifugal Cleaner
Cylinder Blocks
Saver Ring
Crankshaft & Flex Coupling
Camshaft
Engine Performance Checks
Tachometer Adjusting
Speedometer Adjusting
DEC2 Monitoring System
Control Unit
Dip Switches
LED Normal Functions
Sensors
Sensors (Page 2)
Sensors (Page 3)
Sensors (Page 4)
Location MT26/MT31 DEC2
Location MT36 DEC2
Location MT40B DEC2
Engine Warning Light
Fault Finding
Chart for Fault Codes
Location of Sensors DEC2
Sensor Boost, Coolant
Oil Pressure, Engine Speed
Trouble Shooting Guide
DEC2 Tuning and Calibration
Start Up Procedure
Main Menu
Tuning
Explanation of Parameters
Explanation of Function Keys
Fault Log
Governor Configuration
Governor Calibration
Start Procedure
Failed Calibration
Saving Calibration
New Screens in 7.0/8.1
PC Software Configuration
OEM Information
02-Transmission.pdf (54 Pages)
ZF 6WG260 Transmission
6WG260 Layout
Front View 6WG260
Left Side View
Rear View
Electrical Connections
Digital Display
Definition of Operating Modes
Fault Codes (11-26)
Fault Codes (27-35)
Fault Codes (36-65)
Fault Codes (66-76)
Fault Codes (77-84)
Fault Codes (85-92)
Fault Codes (93-6F)
Fault Codes (9A-A4)
Fault Codes (A5-B5)
Fault Codes (B6-BF)
Fault Codes (D3-F6)
EST-37 Pin Designation
Testman Program
Start - Screen 1
Start - Screen 2 & 3
Running Screen 1 & 2
Running Screen 3 & 4
Running Screen 5 & 6
Running Screen 7
Error Memory - Example
Read ID Block
Input and Output Circuits
Test Inputs - Outputs
Start Vehicle Configuration
Start AEB Testing
Inductive Transmitters
Measuring
Installing Transmitter
Calculation for Shims
AEB Starter
Meaning of Codes - During Test
Code Chart - Gear Ranges
Measuring and Connection Points
Control Valve - Exploded
Main Oil Circuit
03-Brake system.pdf (5 Pages)
Location of Components
Master Cylinders
Parking Brake Caliper
Air Chamber Parking Brake
04-Air system.pdf (4 Pages)
Air System
Legend for Drawing
Air System Specifications
Air Drier
05-Hydraulic system.pdf (25 Pages)
Specifications
Hydraulic Schematic
Steering System Circuit
Pressure Switch - Main Hyd. Pump
Pressure Switch - Emergency Steering
Measuring & Adjusting
Relief Valve
Electrics
Steering Cylinder Breakdown
Cooling Fan Circuit
Component Locations
Electric Circuit
Tilt Circuit
Electrics
Pressure Testing & Adjusting
Adjusting Pressure
Tilt Valve, Cut Away
Tilt Cylinder
Tilt & Steering Cylinder Repair
Assemblying Cylinders
Completion of Assembly
06-Electrical system.pdf (60 Pages)
Electrical Schematics
Power Supply
Gauges & Instrument Lights
VTS-3 Gear Selector
Optional High Beam
Rotary Beacon
Radio
Windshield Wipers
Cab Light
Reverse Lights, Mirror, Work Lights
Heater, Fan, AC
Heater, Fan, AC - 2
Directional Lights, Hazard
Emergency Steering
Brake Lights
Lighter Circuit
Brake Warning Light
Headlights
Heated Seat, Mirrors, Air Dryer
Engine Brake
Interaxle Lock
Auto Lube System
Connectors 1001-1020
Location Chart Electrical Components
Engine Control Components
Transmission Electrical Components
Component Location
Component Location - 2
Component Location - 3
07-Turning ring-Tandem bearing.pdf (2 Pages)
Turning Ring/Tandem Bearing
Measurements
09-Autolube .pdf (128 Pages)
Groeneveld Twin Auto Lube System
System Overview
Twin GINA User's manual
Table of contents
Introduction
Installation
Starting the program
Functions
Parameters
Reports
Workshop Manual
Brand: MOXY
List of Files:
MT26
MT31
Operator Comfort
Instrument Panels
Operator Controls
Tandem Swing
Tilting Cab
New Drivetrain
Scania DC9 51A
Engine Emission
Regulations
Charge Air Cooler
Power & Torque
Cylinder Blocks
Saver Ring
Camshaft
Control Unit
Dip Switches
Sensors
Sensors (Page 2)
Sensors (Page 3)
Sensors (Page 4)
Location MT36 DEC2
Location MT40B DEC2
Fault Finding
Start Up Procedure
Main Menu
Tuning
Fault Log
Start Procedure
Failed Calibration
Saving Calibration
OEM Information
6WG260 Layout
Front View 6WG260
Left Side View
Rear View
Digital Display
Fault Codes (11-26)
Fault Codes (27-35)
Fault Codes (36-65)
Fault Codes (66-76)
Fault Codes (77-84)
Fault Codes (85-92)
Fault Codes (93-6F)
Fault Codes (9A-A4)
Fault Codes (A5-B5)
Fault Codes (B6-BF)
Fault Codes (D3-F6)
Testman Program
Start - Screen 1
Running Screen 7
Read ID Block
Start AEB Testing
Measuring
AEB Starter
Main Oil Circuit
Master Cylinders
Air System
Legend for Drawing
Air Drier
Specifications
Hydraulic Schematic
Relief Valve
Electrics
Cooling Fan Circuit
Component Locations
Electric Circuit
Tilt Circuit
Electrics
Adjusting Pressure
Tilt Cylinder
Power Supply
VTS-3 Gear Selector
Optional High Beam
Rotary Beacon
Radio
Windshield Wipers
Cab Light
Heater, Fan, AC
Heater, Fan, AC - 2
Emergency Steering
Brake Lights
Lighter Circuit
Brake Warning Light
Headlights
Engine Brake
Interaxle Lock
Auto Lube System
Component Location
Measurements
System Overview
Table of contents
Introduction
Installation
Functions
Parameters
Reports
Workshop Manual
- Doosan Operation and Maintenance Manual Diesel Engine DB58, DB58S, DB58T ,DB58TI , DB58TIS
- Error codes doosan
- Doosan DX225LCA Operation and Maintenance Manual
- Doosan Diesel Engine Workshop Manual
- Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
- Doosan DX225LC Shop Manual
- Daewoo Doosan Solar 140LC-V Excavator Service Shop Manual
- Doosan Wheel Excavator ZF 2HL100 Transmission
- Doosan Maintenance Manual Diesel Engine DE12,DE12T,DE12TI,DE12TIS
- Doosan Common Rail Engines DL06,DL08 & DV11 Service Training
- Daewoo Doosan DB58,DB58T & DB58TI Diesel Engine Shop Manual
- Doosan E Doctor + Installation Manual
- Doosan DX140W/DX160W Operation and Maintenance Manual
- Doosan G424 Gasoline,LP Engine G424 LP Engine (Low Emission Version) G20E-3,G25E-3,G30 Service Manua
- Doosan MST M542 Spare Part Catalogue
