Moxy Truck MT26 MT31 Service Training Manual
Brand: MOXY
Type of Manual: Service Training Manual, Hydraulic Diagram, Electrical Diagram
Model: MOXY MT26 MT31 Truck
List of Files:
01-Engine.pdf (35 Pages)
1 - Engine
Introduction
Electronic Engine Control, ECU
Young & Computerized
Emission Control
Emission Regulations
Intercooler, Charge Air Principle -Air to Air
BIO Fuel -Rape Methyl Ester (RME)
Power & Torque
Power & Torque, Comparison
Expansion Tank
Oil Filter & Centrifugal Oil Cleaner
Oil Cleaner System, Old Style
Saver Ring
Flex Coupling
Prepair for the Challange
Diagonostics and Fault Finding
Dip Switch Function and Setting
Component Specification
Potentiometer
Coolant Temperature, Boost Pressure & Oil Pressure
Software and Cable
Specifications Dec -2
Sensor Locations and Function
Tuning Dec 2
Governor Configuration Dec-2, Low & High Idle
Governor Calibration Dec-2
Timing Adjustment
Water scrubber
02-Transmission.pdf (71 Pages)
2 - Transmission
Driving controls
Speed sensors
Cooler connections
Pumps
General description
Layout 6 WG 260
Layout 6 WG 260
Converter & Retarder
Transmission pump
Clutch arrangement
Certrediff / Torque devider
Certrediff / diff lock
Certrediff / front diff
Emeregency steering pump
6 WG 260 control valves
Retarder valve
6 WG 260 oil circuit diagram
6 WG 260 oil circuit diagram, 1st. gear
6 WG 260 test points
6 WG 260 sensor values
6 WG 260 pressure values
Front view w/maintenance points
Display during operation
Control value settings on TCU
Test equipment for trasmission clutch calibration
TestMan equipment for transmission clutch calibration and diagnistics
Fault codes for EST-37
Introduction
Abbreviations
ZF - Display:
Display during AEB-Mode
definition of operating modes
table of fault codes
measuring of resistance at actuator/sensors and cable
actuator:
cable:
03-Drive Line.pdf (15 Pages)
3 - Drive Line
Content Driveline
Tandem bearing
Tandem Housing
Rear axle housing
Rear differential
Drive shafts
Drive shafts
Drive shafts
Front differential
Front wheel heads
Parking brake
How to adjust the parking brake
Manual release of parking brake
04-Air System.pdf (16 Pages)
4 - Air system
Air system supply
Air system distribution
Brake-fluid distribution
Reference&tech.data
Air system
Air system
Air circuit 1 and 2
Components at Cab Wall
Air system
Parking brake
Parking brake
Parking brake - manual release
Other air operated air system
Air circuits overview
Air circuit - pictorial view
05-Hydraulic System.pdf (25 Pages)
5 - Hydraulic System
Introduction
Bio-oil, Rape Methyl Ester (RME)
System Schematic
Steering Circuit, Hydraulics
Steering Circuit, Electrics
Steering Circuit, Component Locations
Steering Pressure Measuring / Adjustment
Steering Cylinder
Cooling Fan Circuit, Hydraulics
Cooling Fan Circuit, Electrics
Cooling Fan Circuit, Component Locations
Tilt Circuit, Hydraulics
Tilt Circuit, Electrics
Tilt Circuit, Component Locations
Tilt Pressure Measuring / Adjustment
Tilt valve
Tilt valve
Tilt Cylinder
Tilt & Steering Cylinder Repair
Maintenance
06-Electrical System.pdf (49 Pages)
6 - Electrical System
Description of electrical system
El. central
Instruments
Electrical circuit diagrams
Gauge circuits and instrument lights (1000606B)
Power supply and starting circuit (1000607B)
Extra high beam circuit (1000608C)
Rotating beacon (1000610B)
Radio circuit (100611B)
Central lubrication circuit (1000614B)
Wiper, washer and horn circuit (1000615B)
Emergency steering circuit (1000617B)
Reverse and working light circuit (1000621B)
Cab light circuit (1000627B)
Direction and hazard light circuit (1000629B)
Flame start (1000658B)
Brake light circuit (1000713B)
Lighter circuit (100762B)
Heated seat and mirrors, and air dryer circuit (1000800B)
Hydraulic oil warning circuit (1001012B)
Holding magnet circuit for tilting down (1001990B)
Cooling fan circuit (1001992B)
Engine brake circuit (1002372C)
Retarder and Emergency retarder circuit (1002373)
Diff. lock circuit (1002374)
Location of electrical components on the fire wall (1003248)
Engine wiring diagram (1000612B)
Transmission wiring diagram (1000616B)
Fan and air conditioner circuit (1000628B)
Fan and air conditioner circuit from s/n.710125 (1003255)
Brake warning light circuit (1000763B)
Head light circuit (1000799B)
Electrical system - engine (1002201)
Location of electrical components - external (1003246)
Instrument panel
Gear selector from AMP to MNL
Parts List - Electrical Components
07-Front chassis.pdf (6 Pages)
7 - Front chassis
View
LH view of suspension
RH view of suspension
View of articulation
Cross section of articulation bearing
09-AC and Autolube.pdf (12 Pages)
9 - Air conditioner and Automatic lubrication system
Ventilation and AC
AC Compressor
Heater and AC unit
Expansion valve
Condenser
Ventilation
Filling of AC system
Monitoring
Automatic Central lubrication system
GINA software
Lubrication block, front chassis
Lubrication block, front LHS, rear chassis
Lubrication block, rear, rear chassis
Brand: MOXY
List of Files:
1 - Engine
Introduction
Emission Control
Power & Torque
Expansion Tank
Saver Ring
Flex Coupling
Potentiometer
Software and Cable
Tuning Dec 2
Timing Adjustment
Water scrubber
2 - Transmission
Driving controls
Speed sensors
Cooler connections
Pumps
General description
Layout 6 WG 260
Layout 6 WG 260
Transmission pump
Clutch arrangement
Retarder valve
Introduction
Abbreviations
ZF - Display:
actuator:
cable:
3 - Drive Line
Content Driveline
Tandem bearing
Tandem Housing
Rear axle housing
Rear differential
Drive shafts
Drive shafts
Drive shafts
Front differential
Front wheel heads
Parking brake
4 - Air system
Air system supply
Reference&tech.data
Air system
Air system
Air circuit 1 and 2
Air system
Parking brake
Parking brake
Introduction
System Schematic
Steering Cylinder
Tilt valve
Tilt valve
Tilt Cylinder
Maintenance
El. central
Instruments
Instrument panel
7 - Front chassis
View
Ventilation and AC
AC Compressor
Heater and AC unit
Expansion valve
Condenser
Ventilation
Monitoring
GINA software
- Doosan Operation and Maintenance Manual Diesel Engine DB58, DB58S, DB58T ,DB58TI , DB58TIS
- Error codes doosan
- Doosan DX225LCA Operation and Maintenance Manual
- Doosan Diesel Engine Workshop Manual
- Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
- Doosan DX225LC Shop Manual
- Daewoo Doosan Solar 140LC-V Excavator Service Shop Manual
- Doosan Wheel Excavator ZF 2HL100 Transmission
- Doosan Maintenance Manual Diesel Engine DE12,DE12T,DE12TI,DE12TIS
- Doosan Common Rail Engines DL06,DL08 & DV11 Service Training
- Daewoo Doosan DB58,DB58T & DB58TI Diesel Engine Shop Manual
- Doosan E Doctor + Installation Manual
- Doosan DX140W/DX160W Operation and Maintenance Manual
- Doosan G424 Gasoline,LP Engine G424 LP Engine (Low Emission Version) G20E-3,G25E-3,G30 Service Manua
- Doosan MST M542 Spare Part Catalogue
