garage
80
39,478
Mitsubishi Outlander EUR 2016 Service Manual CD
If you download this document, you will be lost 1000 Gallons
Type: html & pdf
Pass: Thanks + Reply to get pass
00 -GENERAL
00E-GENERAL <ELECTRICAL>
11A-ENGINE MECHANICAL<4B1-Except PHEV>
11B-ENGINE OVERHAUL<4B1-Except PHEV>
11C-ENGINE MECHANICAL<4J1>
11D-ENGINE OVERHAUL<4J1>
11E-ENGINE MECHANICAL<4N1>
11F-ENGINE OVERHAUL<4N1>
11G-ENGINE MECHANICAL<4B1-PHEV>
11H-ENGINE OVERHAUL<4B1-PHEV>
12 -ENGINE LUBRICATION
13A-MULTIPOINT FUEL INJECTION (MPI)<4B1-Except PHEV>
13B-FUEL SUPPLY
13C-MULTIPOINT FUEL INJECTION (MPI)<4J1>
13D-DIESEL FUEL<4N1>
13E-MULTIPOINT FUEL INJECTION (MPI)<4B1-PHEV>
14A-ENGINE COOLING
14B-EV COOLING SYSTEM<PHEV>
15 -INTAKE AND EXHAUST
16 -ENGINE ELECTRICAL
17 -ENGINE, MOTOR AND EMISSION CONTROL
21A-CLUTCH
21B-CLUTCH OVERHAUL<F5MBB>
21C-CLUTCH OVERHAUL<F6MBA, W6MBA>
22A-MANUAL TRANSMISSION (FF)
22B-MANUAL TRANSMISSION OVERHAUL<F5MBB>
22C-MANUAL TRANSMISSION OVERHAUL<F6MBA, W6MBA>
22D-TRANSAXLE
23B-CONTINUOUSLY VARIABLE TRANSMISSION OVERHAUL
23C-AUTOMATIC TRANSMISSION (FF)
23D-AUTOMATIC TRANSMISSION OVERHAUL
25 -PROPELLER SHAFT
26 -FRONT AXLE
27A-REAR AXLE<2WD>
27B-REAR AXLE<4WD>
27C-ELECTRONICALLY CONTROLLED 4WD
31 -WHEEL AND TYRE
32 -POWER PLANT MOUNT
33 -FRONT SUSPENSION
34 -REAR SUSPENSION
35A-BASIC BRAKE
35B-ANTI-SKID BRAKING SYSTEM (ABS)
35C-ACTIVE STABILITY CONTROL SYSTEM (ASC)<Except PHEV>
35C-ACTIVE STABILITY CONTROL SYSTEM (ASC)<PHEV>
36 -PARKING BRAKES
37 -ELECTRIC POWER STEERING (EPS)<Except PHEV>
37 -ELECTRIC POWER STEERING (EPS)<PHEV>
42A-BODY<EXCEPT PHEV>
42A-BODY<PHEV>
42B-KEYLESS OPERATION SYSTEM (KOS)<EXCEPT PHEV>
42B-KEYLESS OPERATION SYSTEM (KOS)<PHEV>
51 -EXTERIOR<EXCEPT PHEV>
51 -EXTERIOR<PHEV>
52A-INTERIOR<EXCEPT PHEV>
52A-INTERIOR<PHEV>
52B-SUPPLEMENTAL RESTRAINT SYSTEM (SRS)<EXCEPT PHEV>
52B-SUPPLEMENTAL RESTRAINT SYSTEM (SRS)<PHEV>
54A-CHASSIS ELECTRICAL<EXCEPT PHEV>
54A-CHASSIS ELECTRICAL<PHEV>
54B-LOCAL INTERCONNECT NETWORK (LIN)
54C-CONTROLLER AREA NETWORK (CAN)<EXCEPT PHEV>
54C-CONTROLLER AREA NETWORK (CAN)<PHEV>
54D-ELECTRIC MOTOR UNIT AND DRIVE BATTERY
55 -HEATER, AIR CONDITIONER AND VENTILATION<EXCEPT PHEV>
55 -HEATER, AIR CONDITIONER AND VENTILATION<PHEV>
70 -COMPONENT LOCATIONS
80 -CONFIGURATION DIAGRAMS
90 -CIRCUIT DIAGRAMS<EXCEPT PHEV>
90 -CIRCUIT DIAGRAMS<PHEV>
