Mitsubishi Lancer X Pinout Engine ECU engine family 4B11-Turbo
CONTROL UNIT
ENGINE-ECU
The structure and operation is basically the same as that of 4A91 engine. Refer to GROUP 13A - Multipoint Fuel Injection (MPI) - Control Unit
ENGINE-ECU CONNECTOR INPUT/OUTPUT PIN ARRANGEMENT
1
Inlet oil feeder control valve
2
No. 1 injector
3
No. 2 injector
4
No. 1 ignition coil
5
No. 2 ignition coil
6
Starter active signal
7
Exhaust camshaft position sensor
8
Crank angle sensor
9
Sensor supplied voltage
10
Throttle position sensor (main)
11
Throttle position sensor (sub)
12
Power supply voltage applied to throttle position sensor
13
Throttle position sensor earth
14
Inlet camshaft position sensor
15
Throttle valve control servo (+)
16
Throttle valve control servo (-)
17
Exhaust oil feeder control valve
18
No. 3 injector
19
No. 4 injector
20
No. 3 ignition coil
21
No. 4 ignition coil
23
Exhaust camshaft position sensor earth
24
Crank angle sensor earth
25
Detonation sensor (+)
26
Engine coolant temperature sensor
27
Engine coolant temperature sensor earth
30
Inlet camshaft position sensor earth
34
Oxygen sensor (front) heater
35
Oxygen sensor (rear) heater
36
Oil pressure switch
37
Purge control solenoid valve
38
39
Oxygen sensor (front) offset voltage
40
41
Oxygen sensor (rear) offset voltage
42
Detonation sensor (-)
44
Power supply voltage applied to manifold absolute pressure sensor
45
Manifold absolute pressure sensor
46
Manifold absolute pressure sensor earth
51
No. 1 fuel pump relay
52
Waste gate solenoid valve
58
Power steering fluid pressure switch
60
Alternator G terminal
61
Alternator FR terminal
62
Alternator L terminal
71
Throttle valve control servo earth
72
Power supply voltage applied to throttle valve control servo
73
Engine control relay
74
Accelerator pedal position sensor (main)
75
Power supply voltage applied to accelerator pedal position sensor (main)
76
Accelerator pedal position sensor (main) earth
77
Accelerator pedal position sensor (sub)
78
Power supply voltage applied to accelerator pedal position sensor (sub)
79
Accelerator pedal position sensor (sub) earth
81
Engine-ECU earth
82
Power supply
83
84
Throttle valve control servo relay
87
Air flow sensor
88
Air flow sensor earth
89
No. 1 intake air temperature sensor
90
CAN interface (high)
91
CAN interface (low)
92
Ignition switch-IG
93
Engine-ECU earth
96
No. 2 fuel pump relay
97
No. 2 intake air temperature sensor earth
98
102
A/C compressor relay
103
Flash EP-ROM data rewriting power supply
104
Backup power supply
105
Ignition switch-ST
106
Starter relay
ENGINE-ECU
1
2
No. 1 injector
3
No. 2 injector
4
No. 1 ignition coil
5
No. 2 ignition coil
6
7
8
Crank angle sensor
9
10
11
12
13
14
15
16
17
18
No. 3 injector
19
No. 4 injector
20
No. 3 ignition coil
21
No. 4 ignition coil
23
24
25
26
27
30
34
35
36
Oil pressure switch
37
38
39
40
41
42
44
45
46
51
52
58
60
61
62
71
72
73
74
75
76
77
78
79
81
Engine-ECU earth
82
Power supply
83
84
87
Air flow sensor
88
89
90
91
CAN interface (low)
92
Ignition switch-IG
93
Engine-ECU earth
96
97
98
102
103
104
Backup power supply
105
Ignition switch-ST
106
Starter relay
- Mitsubishi 4G15 Engine Manual
- Mitsubishi L200 2015 Service Manual CD (Triton)
- Mitsubishi Canter Engine 4M51 Workshop Manual Rus
- Mitsubishi Canter 4D34T3 Diesel Engine Shop Manual
- Mitsubishi ASX 2011 Workshop Manual
- Mitsubishi L200 2005 Wiring Diagram
- Mitsubishi Pajero 2001-2006 Service Manual
- Mitsubishi L200 2012 Workshop Manual
- Mitsubishi Mirage 2015 Workshop Manual
- Mitsubishi Pajero 2011 Workshop Manual
- Mitsubishi ASX 2015 Service Manual CD
- Mitsubishi Outlander 2007 Owner Manual
- Mitsubishi Canter URO3 For Australia Shop Manual Electrical
- Mitsubishi L200 Pinout Engine ECU engine 4D56
- Mitsubishi Colt 2004 Wiring Diagram
