Hyundai
86
176,834
Mitsubishi Engine S12R Service Manual 99249-32E30
Brand: Mitsubishi
Model: Mitsubishi S12R Engine
Part Number: 99249-32E30
Number of Pages: 350 Pages
Chapter 1 GENERAL
1. External view 1-3​
2. System flow diagrams 1-11​
3. Content of plate and label 1-17​
4. Main specifications 1-18​
Chapter 2 SERVICE DATA
1. Maintenance service data 2-3​
2. Tightening torque table 2-20​
Chapter 3 SERVICE TOOLS
1. Special tools 3-3​
Chapter 4 OVERHAUL INSTRUCTIONS
1. Determining overhaul timing 4-3​
2. Compression pressure - Measure 4-4​
Chapter 5 DISASSEMBLY OF BASIC ENGINE
1. Cylinder heads and valve mechanisms - Disassemble and inspect 5-3​
2. Rear mechanism - Disassemble and inspect 5-8​
3. Front mechanism - Disassemble and inspect 5-13​
4. Cylinder liner, piston and connecting rod - Disassemble and inspect 5-19​
5. Crankcase, crankshaft and main bearing - Disassemble and inspect 5-24​
Chapter 6 INSPECTION AND REPAIR OF BASIC ENGINE
1. Cylinder head and valve mechanism - Inspect and repair 6-3​
2. Rear mechanism - Inspect and repair 6-11​
3. Front mechanism - Inspect and repair 6-14​
4. Piston and connecting rod - Inspect and repair 6-17​
5. Crankcase and crankshaft - Inspect and repair 6-25​
Chapter 7 ASSEMBLY OF BASIC ENGINE
1. Crankshaft and main bearing - Install 7-3​
2. Cylinder liner, piston and connecting rod - Assemble 7-8​
3. Front mechanism - Assemble 7-18​
4. Rear mechanism - Assemble 7-24​
5. Cylinder head and valve mechanism - Assemble 7-30​
Chapter 8 FUEL SYSTEM
1. Fuel system - Remove and inspect 8-3​
2. Fuel system - Disassemble and inspect 8-15​
3. Fuel system - Install 8-30​
Chapter 9 LUBRICATION SYSTEM
1. Lubrication system - Remove and inspect 9-3​
2. Lubrication system - Disassemble, inspect and assemble 9-7​
3. Lubrication system - Install 9-21​
Chapter 10 COOLING SYSTEM
1. Cooling system - Remove and inspect 10-3​
2. Cooling system - Disassemble, inspect and assemble 10-15​
3. Cooling system - Install 10-42​
Chapter 11 INLET AND EXHAUST SYSTEMS
1. Inlet and exhaust systems - Remove and inspect 11-3​
2. Inlet and exhaust systems - Disassemble, inspect and assemble 11-13​
3. Inlet and exhaust systems - Install 11-16​
Chapter 12 AIR START SYSTEM
1. Air start system - Remove 12-3​
2. Air start system - Disassemble, inspect and assemble 12-6​
3. Air start system - Install 12-13​
Chapter 13 ADJUSTMENT AND OPERATION
1. Engine - Adjust 13-3​
2. Break-in operation 13-8​
3. Engine-Test and adjustment 13-10​
Engine inspection record sheet
