Minuteman Walk-Behind Scrubber E30 Parts User Manual
- Download this document, you need 300 Gallons
Brand: Minuteman
Type of Machine: Walk-Behind Scrubber
Type of Manual: Parts Manual, User Manual
Model: Minuteman E30 7062.15 Walk-Behind Scrubber
List of Files:
E24 E26 E28 E30 Harness.pdf
E28 E30 E33 User Manual 8-10-2795.pdf
Introduction
Preface
Proper use
Notes of warranty
Acceptance of the machine
1 Safety information
1.1 Safety and Warning Symbols. 5
1.2 General Provisions
1.3 Provisions for Operation
1.4 Maintenance instructions
1.5 Specific Hazards
1.6 Information for Protection of Environment
1.7 Labels at the Machine
2 First Operation
2.1 Instruction
2.2 Initial charging procedure
2.3 Before Taking into Operation 10
2.4 Start Machine
2.5 Operation
2.6 Stop Machine
2.7 After Work
2.8 Transporting Machine
3 Operation
3.1 Method of operation
3.1.1 Brush Deck
3.1.2 Solution Tank
3.1.3 Squeegee
3.1.4 Recovery Tank
3.1.5 Traction Drive
3.1.6 Batteries and Charger
3.1.7 Options
3.2 Operating and Indicating Elements
3.2.1 Operating Panel
3.2.2 At the machine
4 Technical Data
5 Maintenance and Care
5.1 System Maintenance
5.2 Maintenance document
5.3 Maintenance Schedule
5.4 Battery Systems
5.4.1 Charge Batteries
5.4.2 Low Discharge Signal sender (LDS)
5.4.3 Maintenance of Drive
Batteries
5.4.4 Remove Batteries
5.4.5 Install Batteries
5.4.6 Disposal of Batteries
5.5 Solution Tank
5.5.1 Fill Solution Tank
5.5.2 Empty Solution Tank
5.5.3 Clean Solution Filter
5.6 Recovery Tank
5.6.1 Empty Recovery Tank
5.6.2 Clean Recovery Tank
5.6.3 Clean Suction Filter
5.7 Disc brush Deck
5.7.1 Clean Brushes
5.7.2 Change Brushes
5.7.3 Change Roller Bumper
5.7.4 Change Sealing Strip
5.8 Cylindrical brush deck
5.8.1 Clean dirt hopper
5.8.2 Remove brushes
5.8.3 Clean brushes
5.8.4 Fit brushes
5.8.5 Change roller bumper
5.9 Squeegee
5.9.1 Clean Squeegee
5.9.2 Change Squeegee Blades
5.9.3 Adjust Squeegee Blades
Minuteman Limited Warranty
E30 Parts Manual 988029 2008.pdf
Chassis Assembly I
Lift Pedal Subassembly
Brush Pressure Adjustment Subassembly
Chassis Assembly II
Traction Drive Motor Subassembly
Chassis Assembly III
Water Supply Subassembly I Water Supply Subassembly II
Squeegee Connection Subassembly I Squeegee Connection Subassembly II
Battery Tray Assembly Solution Tank Assembly
Recovery Tank Drain Hose Subassembly
Recovery Tank Assembly Vacuum Motor Assembly Squeegee Lift Handle Assembly Squeegee Lock Assembly
Squeegee Assembly I Squeegee Assembly II
Control Panel Assembly
Console Subassembly
Electrical Assembly I
Retainer Subassembly Electrical Assembly II Battery Charger Assembly Machine Labels
Disc Scrub Deck Assembly I Disc Scrub Deck Assembly II Disc Scrub Deck Assembly III
Brand: Minuteman
List of Files:
Introduction
Preface
Proper use
Notes of warranty
2 First Operation
2.1 Instruction
2.4 Start Machine
2.5 Operation
2.6 Stop Machine
2.7 After Work
3 Operation
3.1.1 Brush Deck
3.1.2 Solution Tank
3.1.3 Squeegee
3.1.4 Recovery Tank
3.1.7 Options
4 Technical Data
5.4 Battery Systems
Batteries
5.5 Solution Tank
5.6 Recovery Tank
5.7 Disc brush Deck
5.7.1 Clean Brushes
5.8.3 Clean brushes
5.8.4 Fit brushes
5.9 Squeegee
Chassis Assembly I
Chassis Assembly II
Console Subassembly
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
