118
6,911
Minuteman Scrubbers Walk Behinds E28 E30 E33 User Instruction Manual
Brand: Minuteman
Type of Machine: Scrubbers Walk Behinds
Type of Manual: User Manual, Instruction Manual
Model: Minuteman E28 E30 E33 Scrubbers Walk Behinds
List of Files:
E28 E30 E33 7311.44 Instruction Manual 88-10-3006.pdf
Introduction
Preface
Acceptance of the machine
1 Safety information
1.1 Safety and Warning Symbols
1.2 General Provisions
1.3 Provisions for Operation
1.4 Maintenance instructions
1.5 Specific Hazards
1.6 Information for Protection of
Environment
1.7 Labels at the Machine
2 First Operation
2.1 Instruction
2.2 Initial charging procedure
2.3 Before Putting into Operation
2.4 Start Machine
2.5 Operation
2.6 Stop Machine
2.7 After Work
2.9 Tie-down points
3 Operation
3.1 Method of operation
3.1.1 Brush Deck
3.1.2 Solution Tank
3.1.3 Squeegee
3.1.4 Recovery Tank
3.1.5 Travel Drive
3.1.6 Batteries and Charger
3.1.7 Options
3.2 Operating and Indicating Elements
3.2.1 Operating Panel
3.2.2 At the machine
4 Technical Data
5 Maintenance and Care
5.1 Minuteman System Maintenance
5.2 Maintenance Document
5.3 Maintenance Schedule
5.4 Battery Systems
5.4.1 Charge Batteries
5.4.2 Low Discharge Signal
sender (LDS)
5.4.3 Maintenance of Drive
Batteries
5.4.4 Remove Batteries
5.4.5 Install Batteries
5.4.6 Disposal of Batteries
5.5 Solution Tank
5.5.1 Fill Solution Tank
5.5.2 Empty Solution Tank
5.5.3 Clean Solution Filter
5.6 Recovery Tank
5.6.1 Empty Recovery Tank
5.6.2 Clean Recovery Tank
5.6.3 Clean Suction Filter
5.7 Disc brush deck
5.7.1 Clean Brushes
5.7.2 Change Brushes
5.7.3 Change Deflector Roller
5.7.4 Change Sealing Strip
5.8 Cylindrical brush deck
5.8.1 Clean dirt hopper
5.8.2 Remove brushes
5.8.3 Clean brushes
5.8.4 Fit brushes
5.8.5 Change deflector roller
5.9 Squeegee
5.9.1 Cleaning the Squeegee
5.9.2 Changing the Sealing Strips
5.9.3 Adjusting the Sealing Strips
E28 E30 E33 User Manual 988745UM 2022.pdf
1 Safety Information
1.1 Safety And Warning Symbols
1.3 Provisions For Operation
1.4 Maintenance Instructions
1.6 Information For Protection Of Environment
1.7 Labels On The Machine
2 First Operation
2.1 Instruction
2.2 Initial Charging Procedure
2.3 Before Operation Of Machine
2.4 Start Machine
2.5 Operation
2.6 Stopping The Machine
2.7 After Work
2.8 Transport Mode
2.9 Tie Down Points
3 Operation
3.1 Method Of Operation
3.1.1 Scrub Head Assembly
3.1.2 Solution Tank
3.1.3 Squeegee
3.1.4 Recovery Tank
3.1.5 Drive System
3.1.6 Batteries And Charger
3.1.7 Options
3.2 Control Panel & Operation Indicators
3.2.2 At The Machine
4 Technical Data
5 Maintenance And Care
5.1 General
5.4 Battery Systems
5.4.1 Charging The Batteries
5.4.2 Low Discharge Signal Sender (Lds)
5.4.3 Removing Batteries
5.4.4 Installing Batteries
5.4.5 Disposal Of Batteries
5.5 Solution Tank
5.5.1 Filling The Solution Tank
5.5.2 Empty The Solution Tank
5.5.3 Cleaning Clear Water Filter
5.6.2 Cleaning The Recovery Tank
5.7 Scrub Head
5.7.1 Cleaning Brushes
5.7.2 Changing Brushes
5.7.3 Changing Deflector Roller
5.7.4 Changing Scrub Head Skirt
5.8 Cylindrical Brush Deck
5.8.1 Clean Dirt Hopper
5.8.2 Remove Brushes
5.8.3 Clean Brushes
5.8.4 Fit Brushes
5.8.5 Change Deflector Roller
5.9 Squeegee
5.9.1 Cleaning The Squeegee
5.9.2 Changing The Squeegee Blades
5.9.3 Adjusting The Blades Angle Adjustment
