118
6,911
Minuteman Scrubber H20DTD H20DTDCE H20DTDQP H20DTDQPG User Manual 988735UM 2009
Brand: Minuteman
Type of Machine: Walk-Behind Scrubber Disc Traction Drive
Type of Manual: User Manual
Model: Minuteman H20 H20DTD ; H20DTDCE ; H20DTDQP ; H20DTDQPG Walk-Behind Scrubber Disc Traction Drive
Part Number: 988735UM
Publication Date: 2009
Number of Pages: 40 Pages
Technical Specifications
Table Of Contents
Safety Instructions
For Safety During Operation
When Servicing / Maintaining Machine
Unpacking Instructions
Inspection
Electrical
Batteries
Operator Responsibility
Machine Overview
Front
Rear
Control Panel
Bail Handle
Handle Adjustment Knobs
Key Switch
Direction Switch
Squeegee Lift Lever
Solution Control Lever
Battery / Fault Gauge
Speed Control
Charge Status Indicator
Optional Hour Meter
Circuit Breakers
Battery Compartment
Diagnostic Code Guide
Handle Adjustment
Angle Adjustment
Horizontal Adjustment
Solution Tank Drain Hose
Solution Level Indicator
Solution Fill Filter
Screened Float
Screened Float Removal
In-Line Solution Filter Assembly
Rear Squeegee
Cleaning The Squeegee
Changing The Squeegee Blades
Adjusting The Squeegee Blades
Angle Adjustment
Height Adjustment
The H20
Machine Operation
To Turn On Machine
To Turn On Vacuum
To Turn On Brush Motor
To Turn On Cleaning Solution
Direction Switch
Speed Control
Driving
To Charge Batteries
Solution Solenoid
Hour Meter (Optional)
Loading Brush
Unloading Brush
After Use
Maintenance
Troubleshooting
Minuteman International Limited Warranty
