Minuteman Scrubber E17TD E20DTD H20DTD Traction Drive User Manual 988721UM 2016
- Download this document, you need 300 Gallons
Brand: Minuteman
Type of Machine: Walk-Behind Scrubber Disc Traction Drive
Type of Manual: User Manual
Model: Minuteman E17 E17TD ; E20 E20DTD ; H20 H20DTD Walk-Behind Scrubber Disc Traction Drive
Part Number: 988721UM
Publication Date: 2016
Number of Pages: 40 Pages
Preface
Technical Specifications
Table Of Contents
Notes
Safety Instructions
Inspection
Electrical
Batteries
Operator Responsibility
Unpacking Instructions
Machine Overview
Machine Overview - Front
Machine Overview - Rear
Control Panel
Bail Handle
Handle Adjustment Knobs
Key Switch
Direction Switch
Squeegee Lift Lever
Solution Control Lever
Battery / Fault Gauge
Speed Control
Charge Status Indicator
Circuit Breakers
Battery Compartment
Diagnostic Code Guide
Optional Hour Meter
Rear Squeegee
Cleaning The Squeegee
Changing The Squeegee Blades
Adjusting The Squeegee Blades
Angle Adjustment
Height Adjustment
Handle Adjustment
Angle Adjustment
Horizontal Adjustment
Aqua-Saver Solution Control
Solution Tank Drain Hose
Solution Level Indicator
Solution Fill Filter
Screened Float
Screened Float Removal
Recovery Tank Drain Hose
Deck Skirt Removal
In-Line Solution Filter Assembly
The E17/E20/H20
Machine Operation
To Turn On Machine
To Turn On Vacuum
To Turn On Brush Motor
To Turn On Cleaning Solution
Direction Switch
Speed Control
Driving
To Charge Batteries:
Solution Solenoid
Hour Meter (Optional):
Loading Brush
Unloading Brush
Care - After Use
Maintenance
Troubleshooting
Ce Declaration Of Conformity
Warranty
Brand: Minuteman
Preface
Table Of Contents
Notes
Safety Instructions
Inspection
Electrical
Batteries
Machine Overview
Control Panel
Bail Handle
Key Switch
Direction Switch
Squeegee Lift Lever
Speed Control
Circuit Breakers
Battery Compartment
Optional Hour Meter
Rear Squeegee
Angle Adjustment
Height Adjustment
Handle Adjustment
Angle Adjustment
Screened Float
Deck Skirt Removal
The E17/E20/H20
Machine Operation
To Turn On Machine
To Turn On Vacuum
Direction Switch
Speed Control
Driving
Solution Solenoid
Loading Brush
Unloading Brush
Care - After Use
Maintenance
Troubleshooting
Warranty
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
