118
6,911
Minuteman Scrubber Disc Traction Drive E20S Sport User Manual 988721UMS 2016
Brand: Minuteman
Type of Machine: Walk-Behind Scrubber Disc Traction Drive
Type of Manual: User Manual
Model: Minuteman E20S Sport E20S Walk-Behind Scrubber Disc Traction Drive
Part Number: 988721UMS
Publication Date: 2016
Number of Pages: 44 Pages
Safety Instructions
Unpacking Instructions
Inspection
Electrical
Batteries
Operator Responsibility
Machine Overview
Front
Rear
Controls
Bail Handle
Handle Adjustment Knobs
Key Switch
Direction Switch
Squeegee Lift Lever
Solution Control Lever
Battery / Fault Gauge
Speed Control
Charge Status Indicator
Brush Speed Keyswitch & Circuit Breakers
Aqua-Saver Solution Control
Battery Compartment
Diagnostic Code Guide
Optional Hour Meter
Brush Pressure Adjustment
Handle Adjustment
Angle Adjustment
Horizontal Adjustment
Solution Tank Drain Hose
Solution Level Indicator
Solution Fill Filter
Screened Float
Screened Float Removal
Recovery Tank Drain Hose
Deck Skirt Removal
In-Line Solution Filter Assembly
Rear Squeegee
Cleaning The Squeegee
Changing The Squeegee Blades
Adjusting The Squeegee Blades
Angle Adjustment
Height Adjustment
The E20 Sport
Machine Operation
Turn On Machine
Turn On Vacuum
Turn On Brush Motor
Turn On Cleaning Solution
Direction Switch
Speed Control
Driving
Charging The Batteries
Solution Solenoid
Hour Meter (Optional)
Loading Brush
Unloading Brush
Maintenance
Troubleshooting
Warranty
