118
6,911
Minuteman Scrubber Disc Brush Drive E20DTDQP-FC E20DTDQPG-FC User Manual 988721UMFC 2009
Brand: Minuteman
Type of Machine: Floor Scrubber Traction Drive
Type of Manual: User Manual
Model: Minuteman E20DTDQP-FC E20DTDQPG-FC Floor Scrubber Traction Drive
Part Number: 988721UMFC
Publication Date: 2009
Number of Pages: 40 Pages
Technical Specifications
Safety Instructions
Important Safety Instructions
For Safety During Operation
For Safety When Servicing Or Maintaining Machine
Unpacking Instructions
Inspection
Electrical
Batteries
Operator Responsibility
Machine Overview
Machine Overview - Front
Machine Overview - Rear
Control Panel
Bail Handle
Handle Adjustment Knobs
Key Switch
Direction Switch
Squeegee Lift Lever
Solution Control Lever
Battery / Fault Gauge
Speed Control
Charge Status Indicator
Optional Hour Meter
Optional Pump Kit
Circuit Breakers
Battery Compartment
Diagnostic Code Guide
Machine Overview
Handle Adjustment
Angle Adjustment
Horizontal Adjustment
Solution Tank Drain Hose
Solution Level Indicator
Solution Fill Filter
Screened Float
Screened Float Removal
In-Line Solution Filter Assembly
Rear Squeegee
Cleaning The Squeegee
Changing The Squeegee Blades
Adjusting The Squeegee Blades
Angle Adjustment
Height Adjustment
The Floor Scrubber
Machine Operation
To Turn On Machine:
To Turn On Vacuum:
To Turn On Brush Motor:
To Turn On Cleaning Solution:
Direction Switch:
Speed Control:
Driving:
To Charge Batteries:
Solution Solenoid:
Hour Meter (Optional):
Loading Brush
Unloading Brush
After Use
Maintenance
Troubleshooting
