Minuteman Rider Scrubber E-Ride 21 Service Parts Manual And Wiring Diagram
Brand: Minuteman
Type of Machine: Rider Scrubber
Type of Manual: Service Manual, Parts List
Model: Minuteman E Ride 21 ; E Ride 21-Micro Rider Scrubber
List of Files:
ER21 Micro Rider Parts List.pdf
General View
Chassis System - Rear Wheel Group
Drive System
Brush Group
Squeegee Group
Electrical Components Group
Battery Charger System
Cowlings Group
Solution System (Disc)
Cylindric Deck Group
Squeegee Group
Solution System (Cylindrical)
With Vacuum
Recommended Spare Parts
ER21 Micro Rider Service Manual 2016.pdf
Chapter 1 General Information
1.1 Operators Postion
1.2 Lifting The Machine
1.3 Transporting The Machine
1.4 Other Refference Manuals
Chapter 2 Safety
2.1 Symbols Used
2.2 General Instructions
Chapter 3 Machine Description
3.1 Technical Characteristics
3.2 Description
Chapter 4 Scheduled Maintenance
4.1 Scheduled Maintenance Plan
Chapter 5 Cleaning Solution
5.1 Tank Cleaning & Cleaning Solution
5.2 Cleaning Solution Filter
5.3 Disassembly/Assembly Solution Filter
5.4 Removal/Installation Solution Pump
5.5 Cleaning Spray Nozzle On Disk Brush Decks
5.6 Cleaning Spray Nozzle On Cylindrincal Brush Decks
5.7 Trouble Shooting
Chapter 6 Chemical Mixing System
6 1 Cleaning Chemical Tank & Valve .1 Cleaning Chemical Tank & Valve
6.2 Disassembly/Assembly Chemical Pump & Check Valve
6.3 Trouble Shooting
Chapter 7 Brush System
7.1 Cleaning The Brushes
7.2 Removing Brush Head
7.3 Brush Motor Test
7 4 Brush Motor Carbon Brushes .4 Brush Motor Carbon Brushes
7.5 Brush Drive Belt
7.6 Brush Actuator
7.7 Trouble Shooting
Chapter 8 Recovery System
8.1 Cleaning The Recovery Water Tank And Grates
8.2 Check Amperage Of The Vacuum Motor
8.3 Check And Replacement Of Suction Motor Carbons
8.4 Disassembly/Assembly Of The Suction Motor
8.5 Cleaning/Check Of The Squeegee And Possible Replacement Of The Blades
8.6 Disassembly/Assembly And Cleaning/Replacing The Suction Filter
8.7 Disassembly/Assembly Electric Squeegee Raise/Lower Actuator
8.8 Troubleshooting
Chapter 9 Drive System
9 1 Procedure To Change The Maximum Drive Speed Of The .1 Procedure To Change The Maximum Drive Speed Of The Machine
9.2 Disassembly/Assembly Of The Drive Wheel
9.3 Disassembly/Assembly Of The Drive Chain
9.4 Drive Motor Electrical Absorption Check
9.5 Check And Replacement Of Drive Motor Carbon Brushes
9 6 Disassembly/Assembly Of The Drive Motor .6 Disassembly/Assembly Of The Drive Motor
9.7 Disassembly/Assembly Of The Drive Pedal
9.8 Functionality And Adjustment Of Micro Safety Switch In The Seat
9.9 Troubleshooting
Chapter 10 Miscellaneous Systems
10.1 Tightening Screws And Nuts Check
10.2 Disassembly/Assembly Control Panel Keyboard
10.3 Steering Wheel Disassembly/Assembly
10.4 Steering Column Disassembly/Assembly
10.5 Disassembly/Assembly Of Detergent Solution (Or Washing Water) Dipstick
10.6 Disassembly/Assembly Drain Hose For The Clean Water Tank
10.7 Disassembly/Assembly Recovery Water Drain Hose
Chapter 11 Electrical System
11.1 Battery Charging
11.2 Battery Disassembly/Assembly
11.3 Adjusting The Machine For Different Battery Types
11.4 Checking / Replacing Fuses
11.5 Disassembly/Assembly Drive Electronic Board
11.6 Disassembly/Assembly Functions Electronic Board
11.7 Replacing The Key Switch
11 8 Troubleshooting .8 Troubleshooting
11.9 Alarm Codes
11.10 Wiring Diagram
12. Relays
13. Notes
ER21 Wiring Diagram Mod-2016 W-NOTES.pdf
ER21 Wiring Diagram.pdf
Setting The Battery Type ER21.pdf
Brand: Minuteman
List of Files:
General View
Drive System
Brush Group
Squeegee Group
Cowlings Group
Squeegee Group
With Vacuum
Chapter 2 Safety
2.1 Symbols Used
3.2 Description
7.6 Brush Actuator
8.8 Troubleshooting
9.9 Troubleshooting
11.9 Alarm Codes
12. Relays
13. Notes
- Hako Electrical Symbols Training On Basic Principles 2010 EN DE
- Minuteman Back Pack Vacuum C47185-00 To C47190-01CE Operation Service Parts Care 999221 2003
- Minuteman Hospital Vacuum C81415-01 C81415-03 Operation Service Parts 987834 2002
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2012
- Hako Italsea Driving Control 7CH4E201 Technical Manual 90574005
- Minuteman Back Pack Vacuum V10115P V10115PP User Manual Parts Guide
- PowerBoss Scrubber PHX26ECO User Manual 988737UMPB 2016
- Hako Minuteman Burnishers 1100 1500 2000 Operation Service Parts Care
- Minuteman Battery Chargers 957761‐1 957761‐2 957761‐3 957761G‐4 Service Manual 2016
- PowerBoss Scrubber PHX28 PHX30 PHX33 Parts Catalog 988745PB 2022
- Hako Minuteman Scrubbers MC833465-24B-S To MC833935-24B-F Operation Service Parts Care 983506
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2001
- PowerBoss Scrubber RoboScrub 20 MR20-AIQP-PB Operation Manual 988767UMPB 2020
- Hako Minuteman Sweeper Battery Version SW5X Instruction Manual Wiring Diagram
- Minuteman Bio-Haz Vacuum C82907-00 C82907-02 Operation Service Parts 987815-1 2004
