118
6,911
Minuteman Automatic Scrubbers E17BD To E26ECO Service Manual 2022
Brand: Minuteman
Type of Machine: Automatic Scrubbers
Model: Minuteman Automatic Scrubber
E17BD, E17TD, E20S, E20BD, E20TD, E20C, H20BD, H20TD, E26ECOS, E26ECO
Publication Date: 2022
Number of Pages: 71 Pages
Safety
Technical Specifications
2.1 Dimensions E17BD & E20BD
2.2 Dimensions E17TD & E20TD Maintenance Intervals
3.1 Customer Maintenance
3.2 Maintenance I after every 125 hours of operation
3.3 Maintenance II after every 250 hours of operation
3.4 Maintenance S after every 500 hours of operation Batteries and Wiring
Recovery Float and Gasket Lubrication
Charge Indicator Version 1
On Board Chargers (957760 and 957761) (Ver. 1 & 2)
8.1 Programming the 957745 Charger
8.2 Charger Settings (957745)
8.3 Battery Charger Trouble Shooting
8.4 Battery Charger Error Codes 957745 (Ver. 1)
8.5 Programming The 957760 & 957761 Charger (Ver. 2)
8.6 Charger Error Codes 957760 & 957761
8.7 Prime Chargers
8.8 Prime Charging Status Indicator
8.9 Prime Charger Fault Codes
8.10 IEB Charger
8.11 IEB Charger Status Indicator
8.12 IEB Charging Profiles
8.13 IEB Programming
8.14 IEB Programming Continued Battery and Error Code Indicator
9.1 E17TD and E20TD Error Codes Trouble Brush Motor Circuit
10.1 Trouble Brush Motor Controller (Sport only) Squeegee Adjustment (Curved)
11.1 Squeegee Adjustment
11.2 Squeegee Caster Adjustment
11.3 Squeegee Caster Adjustment
11.4 Squeegee Caster Adjustment Maintaining Deep Cycle Wet Batteries Load Testing The Batteries
Hydrometer Testing
Transporting the Machine Key Switch
Solution Filter (Version 1)
17.1 Solution Filter (Version 2) Testing the Main Power Relay Trouble Shooting the Drive Circuit
19.1 Trouble Shooting The Traction Drive Switch
19.2 Trouble Shooting – Vacuum Motor Circuit
19.3 Trouble Shooting – Vacuum Relay
19.4 Testing the Drive System Potentiometer Currant Draw of Motors
Notes
