Man Mantis Update 491.Torrent.04.2013
MAN MANTIS EPC 04/2013..UPDATE 491.
Year : 2013
Version : 491
Language : Multilingual)
Description : Man Mantis electronic spare parts catalog presented spare
parts for trucks, tractors, buses Man, engines MAN.
This new version of the program allows to enter complete VIN of the
machine for identification, but defines by VIN only model and date of
manufacture.
There is a search of figure by original number of a detail and list of
automobiles, where the detail was applied, also replaced numbers of
details both new and old.
To search for a specific machine parts necessary to know VIN or
precisely to know model, wheel formula, spacing, type of suspension
and the cockpit, and the type and modification of the engine installed
on the machine.
The search by VIN in the program is implemented as follows.
You can enter complete VIN or to use with 4 till 6 symbols VIN to
determine the type (up to five characters to enter zero) and from 7 to 10
characters to determine the number of chassis, you can also choose the
type and chassis number from the list of possible options.
All other data indicate the need to search directly on the machine.
Abbreviation MAN - means Machine-Building Plants Augsburg and
Nuremberg.
The firm "MAN" was founded in 1915 and is one of the largest
manufacturers of vehicles, including buses and also components for
their assembly (axles, transmissions, engines, cabins)
How to install?
1. for x86 systems go in the folder MultiKey32, run install.cmd 2. for x64 systems go in the folder MultiKey64, run install.cmd 3. if once the problem starts with the date (departures, abuse) are starting to run the program to use MANStart.cmd, which if necessary, the right way, if you do not put in the C:
Year : 2013
Version : 491
manufacture.
on the machine.
Nuremberg.
How to install?
- MAN Workshop Infosystem MAN WIS 01.2015
- MAN-Cats II v14.01 2014 Diagnostic software
- MAN Workshop Infosystem (MAN WIS) 2009 Full Crack
- Man Truck & Bus Full Set Manual
- MAN Mantis v.522 EPC 10.2015 + Instruction Installation
- Man Mantis v557 EPC [02.2017] Full Actived + Instruction
- MAN Mantis v.541 EPC [07.2016] Full Actived + Instruction
- MAN Engines Service Manuals [09.2006] Full
- MAN Mantis EPC Update 511 [12.2014] Crack + Instruction
- Man Mantis v558 EPC [03.2017] Full Actived + Instruction
- Man ELTIS 3 [01.2013] Electronic Parts Catalogue
- Man Mantis v568 [08.2017] Full Actived + Instruction
- MAN Offline Programming Step by Step
- Man Mantis 495 Patch for Win7 64 bit
- MAN Mantis v.539 EPC [06.2016] Full Actived + Instruction
