[Linkbelt] Linkbelt Excavator 245X4 LC DZ Service Manual WLSM2457-07LX
Brand: Link-Belt
Type of Machine: Excavator
Type of Document: Service Manual
Model: Link-Belt 245X4 LC Hydraulic Excavator, Link-Belt 245X4 DZ Hydraulic Excavator
Number of Pages: 2155 Pages
Excavator
SAFETY
Safety, general information and standard torque data
Safety
ROPS
ROPS Judgment
Standard Torque Data For Cap Screws And Nuts
Bolt and Nut Tightening
Removal of Under Cover
Protection of Electric/Electronics System During Charging or Welding
A LOWER
Main Equipment Table
Lower Component
Travel Unit
Take-up roller
Upper Roller
Lower Roller
Recoil Spring
Shoe
Shoe
Center Joint
Center Joint (Blade)
Main Equipment Structure and Operation Explanation
Travel Motor
Travel motor operation explanation
Explanation of Component Device Operation
Double Counter Balance Valve
Crossover Relief Valve
Automatic 2-speed Switchover Mechanism
Parking Brake Function
Piston Motor
Reduction Gear
Port Diagram
Travel Motor
Center Joint
Basic Functions
Travel Speed Selection
Travel Alarm
Removal and Installation of Track
Removal and Installation of Shoe Assembly
Removal of Shoe Assembly
Removal and Installation of Shoe Plate
Removal of Shoe Plate
Precautions for Shoe Bolt Installation
Removal and Installation of Roller
Removal and Installation of Upper Roller
Removal of Upper Roller
Assembly and Disassembly of Upper Roller
Configuration Diagram
Dimension Diagram
Jig Dimension Diagram
Disassembly Procedures
Assembly Procedures
Removal and Installation of Lower Roller
Removal of Lower Roller
Assembly and Disassembly of Lower Roller
Dimension Diagram
Assembly Procedures
Removal and Installation of Drive Sprocket
Removal of Drive Sprocket
Removal and Installation of Take-up Roller
Removal of Take-up Roller
Assembly and Disassembly of Take-up Roller
Dimension Diagram
Assembly Procedures
Removal and Installation of Grease Cylinder
Removal of Grease Cylinder
Assembly and Disassembly of Tension Shock Absorber
Dimension Diagram
Disassembly procedures
Assembly procedures
Removal and Installation of Center Joint
Removal of Center Joint
Assembly and Disassembly of Center Joint
Dimension Diagram
Dimension Diagram (Blade)
Assembly Procedures
Removal and Installation of Travel Motor
Removal of Travel Motor
Assembly and Disassembly of Travel Motor
Tools for Assembly and Disassembly
Standard Tools
Secondary Materials
Special Tool (jig)
Measurement Device
Motor Disassembly Procedures
Precautions before Motor Disassembly
Tightening Torque
Maintenance Standards
Motor Parts Maintenance Standards
Reduction Gear Parts Maintenance Standards
Motor Assembly Procedures
Precautions before Motor Assembly
Assembly Procedure
Motor Installation
Inspection
Hydraulic Oil and Gear Oil Filling
Initial Pre-conditioning Operation
Troubleshooting
Structural Diagram
Internal Structure Diagram
Part Table
Drive sprocket
Take-up roller
Upper roller
Lower Roller
Track Shoe (Grouser Shoe)
Inspection Gauge
For Drive Sprocket
For Take-up Roller
For Upper Roller
For Lower Roller
Pressure Measurement and Adjustment Procedures
Main Pressure Measurement
B Travel Pressure Measurement
Drain Volume Measurement Procedures
Preparations
Travel Motor Drain Volume Measurement
Air Bleed Procedure
Travel Motor
B C SWING UNIT, COUNTERWEIGHT
Upper Component
Swing Unit
Swing Motor
Swing Motor Operation Explanation
Hydraulic Motor Section
Valve Casing Section
Brake Section
Relief Valve Operation Explanation (relief valve model: KRD22EK10)
Swing Motor Internal Structure Diagram
Port Diagram
Swing Motor
Basic Functions
Swing brake
Swing Lock
Swing Speed Limit
Swing Relief Cut
Removal and Installation of Swing Unit
Removal of Swing Unit
Assembly and Disassembly of Swing Motor
Troubleshooting
Maintenance Reference Table
Jig
Disassembling Instructions
Assembling Instructions
Assembly and Disassembly of Swing Reduction Gear
Disassembly
Assembly
Jig
Swing Reduction Gear Internal Structure Diagram
Removal and Installation of Counterweight
Removal of Counterweight
C Swing Pressure Measurement
Preparations
Swing Motor Drain Volume Measurement
Air Bleed Procedure
Swing motor
Check
H ENGINE
Engine-related
Air Cleaner (double element)
SCR
Basic Functions
Fuel Gauge
Coolant Temperature Gauge
SCR Gauge
Fuel Economy Gauge
Neutral start
Power-cut Delay
Preheat
Throttle
Throttle Volume Position Detection
Idle start
Auto Idle
One-touch Idle
Auto Warm-Up
Idle Shutdown
Idle up
Work Mode Control
Engine Emergency Stop
SCR RE-GEN
Inducement
Feed Pump Automatic Stop
Coolant Level Decrease
Air Filter Clogging
Fuel Filter Clogging
Battery Charge Abnormality
Horsepower Reduction Control (in Uplands)
Horsepower Reduction Control (at Engine Failure)
Main Data
Function, Structure, Operation
Function, structure, operation (SCR)
SCR Control System Inspection
Explanation of SCR Operation
Diagnosis for Each Symptom
Intermittent conditions of urea selective catalytic reduction system
Urea fluid consumption too high
Ammonia smell noticeable
White crystalline powder visible
Engine Start Problems
Engine Stalling
Engine Hunting, Rough Idling
Excess Amount of White Smoke in Exhaust Gas
Excess Amount of Black Smoke in Exhaust Gas
Abnormal Noise
High Fuel Consumption
High Oil Consumption
Engine Output Deficiency
Functional Inspection
Engine Compression Pressure Inspection
Fuel System Inspection
Lubrication system check
Air intake system inspection
Exhaust system inspection
Inspection of EGR Control System
Start System Inspection
Glow control system check
OBD system check
Inspection of the monitor warning light illumination circuit system
Inspection of the monitor warning light blinking circuit system
Inspection of the starter circuit system
Removal and Installation of Engine Assembly
Removal of Engine Assembly
Removal and Installation of Fuel Cooler, Engine Intercooler, Radiator, and Oil Cooler
Removal of Fuel Cooler
Removal and Installation of Engine Intercooler
Removal of Intercooler
Installation of Inter Cooler
Inspection of Intercooler
Removal and Installation of Radiator
Removal of Radiator
Inspection of Radiator
Removal and Installation of Oil Cooler
Removal of Oil Cooler
Removal and Installation of Turbo Charger
Removal of Turbo Charger
Inspection of Turbo Charger
Removal and Installation of EGR Valve (if equipped)
Removal of EGR Valve
Inspection of EGR Valve
Removal and Installation of Top Cover
Removal of Top Cover
Removal and Installation of SCR
Removal of SCR
Installation of SCR
Removal and installation of Silicon Controlled Rectifier Catalyst
Removal of Silicon Controlled Rectifier Catalyst
Installation of Silicon Controlled Rectifier Catalyst
Disassembly of Silicon Controlled Rectifier Catalyst
Assembly of Silicon Controlled Rectifier Catalyst
Inspection of Silicon Controlled Rectifier Catalyst
Removal and Installation of Cylinder Head Cover
Cylinder head cover Removal
Removal of Cylinder Head
Disassembly of Cylinder Head
Assembly of Cylinder Head
Inspection
Removal and Installation of Cylinder Block
Removal of Cylinder Block
Inspection
Lubrication System
Removal and Installation of Oil Pan
Removal of Oil Pan
Removal and Installation of Oil Level Switch
Removal of Oil Level Switch
Removal and Installation of Oil Pump Assembly
Removal of Oil Pump Assembly
Disassembly of Oil Pump Assembly
Assembly of Oil Pump Assembly
Inspection
Engine oil Inspection
Removal and Installation of Oil Port Cover
Removal of Oil Port Cover
Removal and Installation of Water Pump Assembly
Removal of Water Pump Assembly
Inspection of Water Pump Assembly
Removal and Installation of Thermostat
Removal of Thermostat
Inspection
Inspection of Coolant
Inspection of Cooling Fan Belt
Removal and Installation of Overheat Switch
Removal of Overheat Switch
Induction System
Inspection of Air Cleaner Element
Exhaust System
Removal and installation of Oxidation Catalyst Assembly
Removal of Oxidation Catalyst Assembly
Installation of Oxidation Catalyst Assembly
Aux Emission Control Devices System
Removal and installation of Dosing Module
Removal of Dosing Module
Disassembly of Dosing Module
Assembly of Dosing Module
Installation of Dosing Module
Removal and installation of DEF Supply Module
Removal of DEF supply module
Disassembly of DEF Supply Module
Assembly of DEF Supply Module
Installation of DEF Supply Module
Removal and installation of Coolant Control Valve
Removal of Coolant Control Valve
Installation of Coolant Control Valve
Removal and installation of DEF Supply Module Filter
Removal of DEF Supply Module Filter
Installation of DEF Supply Module Filter
Removal and Installation of Exhaust Manifold
Removal of Exhaust Manifold
Inspection
Removal and Installation of Fuel Tank
Removal of Fuel Tank
Installation of fuel tank
Removal and Installation of Urea Pump
Removal of Urea Pump
Removal and Installation of Urea Solution Tank
Removal of Urea Tank
Removal and Installation of Fuel Supply Pump
Removal of Fuel Supply Pump
Removal and Installation of Common Rail Assembly
Removal of Common Rail Assembly
Removal and Installation of Injector
Removal of Injector
Removal and installation of Idle Gear
Removal of Idle Gear
Installation of Idle Gear
Inspection of Idle Gear
Removal and installation of Inlet Cover
Removal of Inlet Cover
Installation of Inlet Cover
Removal and installation of Crankshaft
Removal of Crankshaft
Installation of Crankshaft
Disassembly of Crankshaft
Assembly of Crankshaft
Inspection of Crankshaft
Removal and installation of Piston
Removal of Piston
Installation of Piston
Disassembly of Piston
Assembly of Piston
Inspection of Piston
Removal and installation of Camshaft
Removal of Camshaft
Installation of Camshaft
Disassembly of Camshaft
Assembly of Camshaft
Inspection of Camshaft
Removal and installation of Flywheel
Removal of Flywheel
Installation of Flywheel
Inspection of Flywheel
Removal and installation of Crankshaft Front Oil Seal
Removal of Crankshaft Front Oil Seal
Installation of Crankshaft Front Oil Seal
Removal and installation of Crankshaft Rear Oil Seal
Removal of Crankshaft Rear Oil Seal
Installation of Crankshaft Rear Oil Seal
Removal and installation of Rocker Arm Shaft
Removal of Rocker Arm Shaft
Installation of Rocker Arm Shaft
Disassembly of Rocker Arm Shaft
Assembly of Rocker Arm Shaft
Inspection of Rocker Arm Shaft
Removal and installation of Valve Spring
Removal of Valve Spring
Installation of Valve Spring
Inspection of Valve Spring
Removal and installation of Valve Stem Oil Seal
Removal of Valve Stem Oil Seal
Installation of Valve Stem Oil Seal
Removal and installation of Front Cover
Removal of Front Cover
Installation of Front Cover
Removal and installation of Intake Throttle Valve
Removal of Intake Throttle Valve
Installation of Intake Throttle Valve
Removal and Installation of Starter Motor
Removal of Starter Motor
Disassembly of Starter Motor
Assembly of Starter Motor
Inspection of Starter Motor
Removal and Installation of Alternator
Removal of Alternator
Disassembly of Alternator
Assembly of Alternator
Inspection of Alternator
Removal and Installation of Glow Plug
Removal of Glow Plug
Glow plug Inspection
Removal and Installation of Suction Control Valve
Removal of Suction Control Valve
Removal and installation of Fuel Filter
Removal of Fuel Filter
Installation of Fuel Filter
Removal and installation of Relief Valve
Removal of Relief Valve
Installation of Relief Valve
Removal and installation of Fuel Filter Element
Removal of Fuel Filter Element
Installation of Fuel Filter Element
Removal and Installation of Fuel filter pressure
Fuel filter pressure sensor Removal
Fuel filter pressure sensor Installation
Removal and Installation of Engine coolant temperature sensor
Engine coolant temperature sensor Removal
Engine coolant temperature sensor Installation
Engine coolant temperature sensor Inspection
Removal and Installation of CKP sensor
CKP sensor Removal
CKP sensor Installation
CKP sensor Inspection
Removal and Installation of CMP sensor
CMP sensor Removal
CMP sensor Installation
CMP sensor Inspection
Removal and Installation of Oil pressure sensor
Oil pressure sensor Removal
Oil pressure sensor Installation
Oil pressure sensor Inspection
Removal and installation of Pressure Sensor/Boost Temperature Sensor
Removal of Pressure Sensor/Boost Temperature Sensor
Installation of Pressure Sensor/Boost Temperature Sensor
Inspection of Pressure Sensor/Boost Temperature Sensor
Removal and Installation of IMT sensor
Removal of IMT sensor
Removal and installation of Charge Air Cooler Temperature Sensor 1
Removal of Charge Air Cooler Temperature Sensor 1
Installation of Charge Air Cooler Temperature Sensor 1
Inspection of Charge Air Cooler Temperature Sensor 1
Sampling Procedure
Sampling of Engine Oil
Removal and Installation of Exhaust gas temperature sensor
Removal of Exhaust gas temperature sensor
Inspection of Exhaust gas temperature sensor
Removal and installation of EGR Gas Temperature Sensor 1
Removal of EGR Gas Temperature Sensor 1
Installation of EGR Gas Temperature Sensor 1
Inspection of EGR Gas Temperature Sensor 1
Removal and installation of EGR Gas Temperature Sensor 2
Removal of EGR Gas Temperature Sensor 2
Installation of EGR Gas Temperature Sensor 2
Inspection of EGR Gas Temperature Sensor 2
Removal and installation of NOx Sensor
Removal of NOx Sensor
Installation of NOx Sensor
Removal and Installation of Exhaust gas temperature sensor 3
Removal of Exhaust gas temperature sensor 3
Removal and installation of DEF Sensor
Removal of DEF Sensor
Installation of DEF Sensor
Engine-related Diagnostic Trouble Code List
Engine-side Trouble
ECM Trouble
DTC P0016 Crankshaft Position – Camshaft Position Correlation Error
DTC P0045 Turbocharger Boost Control VNT Error
DTC P0087 Fuel Rail/System Pressure – Too Low
DTC P0089 Fuel Pressure Regulator Performance
DTC P0091 Fuel Pressure Regulator Control Circuit Low
DTC P0092 Fuel Pressure Regulator Control Circuit High
DTC P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
DTC P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage
DTC P0102 Mass Air Flow Sensor Circuit Low Input
DTC P0103 Mass Air Flow Sensor Circuit High Input
DTC P0112 Intake Air Temperature Sensor Circuit Low
DTC P0113 Intake Air Temperature Sensor Circuit High
DTC P0117 Engine Coolant Temperature Sensor Circuit Low
DTC P0118 Engine Coolant Temperature Sensor Circuit High
DTC P0122 Throttle Position Sensor Circuit Low
DTC P0123 Throttle Position Sensor Circuit High
DTC P0182 Fuel Temperature Sensor Circuit Low
DTC P0183 Fuel Temperature Sensor Circuit High
DTC P0192 Fuel Rail Pressure Sensor Circuit Low
DTC P0193 Fuel Rail Pressure Sensor Circuit High
DTC P0201 Injector Circuit Open – Cylinder 1
DTC P0202 Injector Circuit Open – Cylinder 2
DTC P0203 Injector Circuit Open – Cylinder 3
DTC P0204 Injector Circuit Open – Cylinder 4
DTC P0217 Engine Coolant Over Temperature Condition
DTC P0219 Engine Overspeed Condition
DTC P0234 Turbocharger Overboost Condition
DTC P0237 Turbo Charger Boost Sensor Circuit Low
DTC P0238 Turbo Charger Boost Sensor Circuit High
DTC P0335 Crankshaft Position Sensor Circuit
DTC P0336 Crankshaft Position Sensor Circuit Range/Performance
DTC P0340 Camshaft Position Sensor Circuit
DTC P0380 Glow Relay Circuit Error
DTC P0401 EGR Flow Insufficient Detected
DTC P0404 EGR Control Circuit Range/Performance
DTC P0409 EGR Sensor Circuit
DTC P041C EGR Cooler Outlet 1 Temp Sensor Circuit Low
DTC P041D EGR Cooler Outlet 1 Temp Sensor Circuit High
DTC P0427 Catalyst Temperature Sensor Circuit Low Sensor 1
DTC P0428 Catalyst Temperature Sensor Circuit High Sensor 1
DTC P042C Catalyst Temperature Sensor Circuit Low Sensor 2
DTC P042D Catalyst Temperature Sensor Circuit High Sensor 2
DTC P0522 Engine Oil Pressure Sensor Circuit Low Input
DTC P0523 Engine Oil Pressure Sensor Circuit High Input
DTC P0545 EGR Cooler Inlet 1 Temp Sensor Circuit Low
DTC P0546 EGR Cooler Inlet 1Temp Sensor Circuit High
DTC P0560 12 Volt Circuit Error
DTC P0563 System Voltage High
DTC P0601 Internal Control Module Memory Check Sum Error
DTC P0602 Internal Control Module QR Code Error
DTC P0604 Internal Control Module RAM Error
DTC P0606 Internal Control Module CPU Error
DTC P060A Internal Control Module CPU IC Error
DTC P060C Internal Control Module A/D Processing Performance
DTC P0615 Starter Relay Circuit Error
DTC P0638 Throttle Actuator Control Range/Performance
DTC P0685 ECM Power Relay Control Circuit Open
DTC P0687 ECM Power Relay Control Circuit High
DTC P06A6 Sensor Reference Voltage 1 Circuit
DTC P06A7 Sensor Reference Voltage 2 Circuit
DTC P06A8 Sensor Reference Voltage 3 Circuit
DTC P06A9 Sensor Reference Voltage 4 Circuit
DTC P06AF Torque Management System – Forced Engine Shutdown
DTC P06D5 Sensor Reference Voltage 5 Circuit
DTC P1076 Charge Air Cooler (CAC) Temperature Sensor 1 Circuit Low Voltage
DTC P1077 Charge Air Cooler (CAC) Temperature Sensor 1 Circuit High Voltage
DTC P1093 Fuel Rail Pressure Too Low
DTC P1097 Compressor Outlet Temperature Sensor Circuit High
DTC P1098 Compressor Outlet Temperature Sensor Circuit High
DTC P1236 Charge Air Cooler Performance Failure
DTC P1261 Injector Positive Voltage Control Circuit Group 1
DTC P1262 Injector Positive Voltage Control Circuit Group 2
DTC P1404 EGR Position Fault
DTC P1606 SW-IC Internal failure
DTC P160B AD-IC Failure Error
DTC P160C AD-IC2 Failure Error
DTC P1621 Control Module Long Term Memory Performance
DTC P1622 Control Module Long Term Memory Hardware
DTC P1669 DPD Lamp Control Circuit
DTC P204F SCR System Error (No Inducement)
DTC P207F Urea Fluid Concentration Too Low
DTC P20C9 SCR System Error
DTC P2122 Pedal Position Sensor 1 Circuit Low Input
DTC P2123 Pedal Position Sensor 1 Circuit High Input
DTC P2127 Pedal Position Sensor 2 Circuit Low Input
DTC P2128 Pedal Position Sensor 2 Circuit High Input
DTC P2138 Pedal Position Sensor 1 – 2 Voltage Correlation
DTC P2146 Fuel Injector Group 1 Supply Voltage Circuit
DTC P2149 Fuel Injector Group 2 Supply Voltage Circuit
DTC P2228 Barometric Pressure Sensor Circuit Low
DTC P2229 Barometric Pressure Sensor Circuit High
DTC P2457 Exhaust Gas Recirculation (EGR) Cooling System Performance
DTC P2458 Purge time Out Error
DTC P2BA7 Urea Fluid Quantity Too Low
DTC P2BAA SCR System Error (Inducement, No Purge)
DTC P3093 Fuel Rail Pressure Too Low
DTC U0001 CAN Bus Error (ISO-CAN)
DTC U0073 Control Module Communication Bus Off
DTC U0101 Lost Communication With CAN
DTC U010E Lost Communications With Dosing Control Module
DTC U0110 Lost Communication With VNT System
DTC U2106 Lost CAN Communications With Wheel Loader Transmission Control System
DTC U0411 Lost CAN Communications With VNT Control Module
DCU Trouble
Diagnostic Trouble Code_P0607: Control Module Characteristic Abnormality
Diagnostic trouble code_P060B: Control Module A/D Conversion Processing Device Abnormality
Diagnostic trouble code_P062F: Control Module EEPROM Abnormality
Diagnostic trouble code_P0641: Sensor Reference Voltage Abnormality
Diagnostic trouble code_P0658: Actuator Supply Power Feed System Abnormality
Diagnostic trouble code_P0659: Actuator Supply Power Feed System Abnormality
Diagnostic trouble code_P1462: Urea Solution Quality Sensor Time-Out Abnormality
Diagnostic trouble code_P1464: Main Relay Abnormality (Early OPEN Error/Sticking Error of Main Relay)
Diagnostic trouble code_P1468: Urea Solution Injection Control Module (DCM) High Temperature Abnormality
Diagnostic trouble code_P1491: Urea Solution High Pressure Abnormality
Diagnostic trouble code_P1493: Urea Solution Injection Control Module (DCM) Screwdriver High Temperature Abnormality
Diagnostic trouble code_P149C: Urea Solution Reducing Pressure Abnormality
DTC P149D Urea Fluid Tank Overtemperature
Diagnostic trouble code_P2000: Cleaning Ratio Abnormality
Diagnostic trouble code_P203B: Urea Solution Tank Level Sensor
Diagnostic trouble code_P203C: Urea Solution Tank Level Sensor Low Voltage Potential
Diagnostic trouble code_P203D: Urea Solution Tank Level Sensor High Voltage Potential
Diagnostic trouble code_P2048: Urea Solution Injector System Low Voltage Potential
Diagnostic trouble code_P2049: Urea Solution Injector System High Voltage Potential
Diagnostic trouble code_P204B: Urea Solution Pressure Sensor System Characteristic Abnormality
Diagnostic trouble code_P204C: Urea Solution Pressure Sensor System Low Voltage Potential
Diagnostic trouble code_P204D: Urea Solution Pressure Sensor System High Voltage Potential
Diagnostic trouble code_P205B: Urea Solution Tank Temperature Sensor Characteristic Abnormality
Diagnostic trouble code_P205C: Urea Solution Tank Temperature Sensor Low Voltage Potential
Diagnostic trouble code_P205D: Urea solution tank temperature sensor high voltage potential
DTC P206A Urea Fluid Quality Sensor Circuit
Diagnostic trouble code_P206B: Urea Sensor High Temperature Abnormality
DTC P206C Urea Fluid Quality Sensor Circuit Low Voltage
DTC P206D Urea Fluid Quality Sensor Circuit High Voltage
Diagnostic trouble code_P207F: Urea Solution Concentration Low
Diagnostic trouble code_P208A: Urea Solution Pump Control System
Diagnostic trouble code_P208B: Urea Solution Pump Characteristic Abnormality
Diagnostic trouble code_P208C: Urea Solution Pump Control System Low Voltage Potential
Diagnostic trouble code_P208D: Urea Solution Pump Control System High Voltage Potential
Diagnostic trouble code_P208E: Urea Solution Injector Attachment
Diagnostic trouble code_P20A0: Urea Solution Reverting Valve System Disconnection
Diagnostic trouble code_P20A2: Urea Solution Reverting Valve System Low Voltage Potential
Diagnostic trouble code_P20A3: Urea Solution Reverting Valve System High Voltage Potential
Diagnostic trouble code_P20AC: Urea Solution Pump Temperature Sensor Characteristic Abnormality
DTC P20AD Urea Fluid Pump Module Temperature Sensor Performance
DTC P20B1 Urea Fluid Tank Heater Coolant Control Valve Circuit Open
Diagnostic trouble code_P20B3: Urea Solution Tank Heater Coolant Control Valve System Low Voltage Potential
Diagnostic trouble code_P20B4: Urea solution tank heater coolant control valve system high voltage potential
Diagnostic trouble code_P20E8: Urea Solution Low Pressure Abnormality
Diagnostic trouble code_P20E9: Urea Solution High Pressure Abnormality
Diagnostic trouble code_P20EA: Urea Solution Reducing Pressure Abnormality
Diagnostic trouble code_P20FE: Urea Solution Build-Up Abnormality
Diagnostic trouble code_P2201: NOx Sensor Upstream Function
Diagnostic trouble code_P2206: Ft NOx Sensor Disconnection
Diagnostic trouble code_P2207: Ft NOx Sensor Short-Circuit
Diagnostic trouble code_P2210: Rr NOx Sensor Disconnection
Diagnostic trouble code_P2211: Rr NOx Sensor Short-Circuit
Diagnostic trouble code_P242B: Exhaust Gas Temperature (EGT) Sensor 3 System Function
Diagnostic trouble code_P242C: Exhaust Gas Temperature (EGT) Sensor 3 System Low Voltage Potential
Diagnostic trouble code_P242D: Exhaust Gas Temperature (EGT) Sensor 3 System High Voltage Potential
DTC U0002 CAN Bus Off
DTC U0100 Lost Communication With ECM
Diagnostic trouble code_U029D: CAN Communication Error Between DCU-Ft NOx Sensors
Diagnostic trouble code_U029E: CAN Communication Error Between DCU-Rr NOx Sensors
Data Reference Values
Idle Speed
Two Pump Relief
J HYDRAULIC EQUIPMENT (PUMP, OPERATION SYSTEM VALVE)
Hydraulic Device
Control-related
Control valve
Control valve (Blade)
Solenoid Valve (5 Stack)
Remote Control Valve for Left/Right Operations
Remote Control Valve for Travel Operation
Valve for Blade Operation
Remote Control Valve Characteristic Diagram
Operation Remote Control Valve Control Diagram
Travel Remote Control Valve Control Diagram
Blade Remote Control Valve Control Diagram
Reducing Valve (6 Stack Proportional Valve)
Cushion Valve (heat circuit, with shuttle valve)
Selector Valve
Basic Functions
Oil temperature gauge
Static Horsepower Control
Overload Warning (Function for Europe Only)
Pressure Boost Control
Stroke Control
Boom Down Energy Save
Pump Horsepower Boost Control
Arm 1 Semi-parallel Control
Arm 2 Semi-parallel Control
Hot Shutdown Warning
Gate Lock
Breaker Mode
Crusher Mode
Quick coupler
Hydraulic Fluid Filter Clogging
Solenoid Sticking Prevention
Port Diagram
Hydraulic Pump (Standard Model)
Hydraulic Pump (Blade)
Control Valve
Relief Valve
Relief Valve (Blade)
5 stack solenoid valve
2 stack solenoid valve
Remote Control Valves (upper, travel)
Remote Control Valves (left-right)
Remote control valve (travel)
Remote Control Valve (blade)
Cushion Valve
2-way Selector Valve
Direction Valve
Relief Valve (electromagnetic proportional)
Manifold Under Cab
Manifold (accumulator section)
Hydraulic Tank
Hydraulic Pump Internal Structure Diagram
Overall View
Drive Shaft Front Side
Drive Shaft Rear Side
Development Diagram
Component Table
Regulator
Regulator Operation Explanation
Regulator Operation Explanation Diagram
Internal Configuration Diagram of Regulator
Development Diagram of Regulator
Component Table
Operation Outline of Electronically-Controlled Pump
Control Valve
Basic Configuration
Operation
Operation of Main Unit
Activation of Relief Valve
5 Stack Solenoid Valve Operation Explanation
External Shape Diagram and Components
Upper Pilot Valve (remote control valve)
Structure
Function
Operation
Structural Diagram
Travel Pilot Valve (remote control valve)
Operation
Pressure Reducing Valve Section
Damping Mechanism in Operation Section
Structural Diagram
Cushion Valve
structure
Selector Valve (2-way)
Structure
Development Diagram
Direction Valve (3-direction)
Structure
6 Stack Proportional Valve (Pilot)
structure
operation principle
Electromagnetic Relief Valve
Structure
Operation of Check Valve
Operation of Electromagnetic Relief Valve
Removal and Installation of Hydraulic Reservoir
Removal of Hydraulic Reservoir
Installation of Hydraulic Oil Tank
Removal and Installation of Hydraulic Pump
Removal of Hydraulic Pump
Removal and Installation of Pump coupling
Removal of Pump Coupling
Installation of Pump Coupling
Removal and Installation of Control Valve
Removal of Control Valve
Removal and Installation of Travel Remote Control Valve
Removal of Travel Remote Control Valve
Removal and Installation of Operation Remote Control Valve
Removal of Operation Remote Control Valve (left side)
Installation of Operation Remote Control Valve (left side)
Removal of Operation Remote Control Valve (right side)
Installation of Operation Remote Control Valve (right side)
Removal and Installation of 5 Stack Solenoid
Removal of 5 Stack Solenoid
Installation of 5 Stack Solenoid Valve
Removal and Installation of Cushion Valve
Removal of Cushion Valve
Procedures for Assembly and Disassembly of Hydraulic Pump Main Unit
Tools
Assembly Procedures
Development Diagram
Component Table
Pump Main Unit Maintenance Standards
Replacement Standard of Wear Component
Correction Standard of Cylinder, Valve Plate, and Sash Plate (Shoe Plate)
Tightening torque
Overall View
Development Diagram
Component Table
Regulator Maintenance Standards
Regulator Adjustment
Appendix Table and Drawings
Regulator Assembly and Disassembly Procedures
Tools
Preparations for Disassembly
Assembly Procedures
Component Table
Assembly and Disassembly of Control Valve
Disassembly
Caution for Disassembly
Removal of Long Cap and Pulling Out of Main Spool
Disassembly of Arm 1, 2 Parallel-Tandem Spool, Neutral Cut Spool, Arm Regeneration Release Spool Section
Disassembly of Load Check Valve Section
Disassembly of Antidrift Valve Section (Sub Component in Assembly is Expressed by (Min Number – Sub Number) )
Disassembly of Relief Valve
Disassembly of Option Section
Disassembly of Add-On Section
Disassembly of Valve Housing Coalescence Bolt
Cleaning
Inspection
assembly
Caution for Assembly
Caution for Handling O-ring
Caution for Handling Spool
Method to Apply Adhesive Agent (Male and Female Thread Section of Components Requiring Bonding)
Assembly Procedure of Sub-Assembly
Assembly of Spool Assembly (Main Spool)
Assembly of Arm 1, 2 Parallel-Tandem Spool, Neutral Cut Spool, Arm Regeneration Release Spool Assembly
Assembly of Antidrift Valve Assembly
Assembly Procedure of Control Valve Main Unit
Assembly of Relief Valve
Assembly of Load Check Valve
Assembly of Option Section
Assembly of Arm 1 Parallel-Tandem Spool
Assembly of Arm 2 Parallel-Tandem Spool, Neutral Cut Spool, Arm Regeneration Release Spool
Assembly of Main Spool
Assembly of Add-On Section
Assembly of Other Plugs
Internal Structural Diagram
Part List
Relief Valve
Assembly and Disassembly Procedure of Main Relief Valve
Assembly and Disassembly Procedures of Overload Relief
Assembly and Disassembly Procedure of Low-Pressure Relief Valve
Assembly and Disassembly Procedure of Main Relief Valve for Add-On
Adjustment of Relief Valve
Installation
Operation
Malfunction and Countermeasure
Procedures for Assembly and Disassembly of Operation Remote Control Valve
Maintenance Procedures
Required Tools and Tightening Torque
Assembly Procedures
Causes of Trouble and Countermeasures
Procedures for Assembly and Disassembly of Travel Remote Control Valve
Assembly Procedures
Causes of Trouble and Countermeasures and Cross-section Diagram
Assembly and Disassembly of Cushion Valve
Reverse Operation Spool Section
Check Plunger Section with Throttle
Shuttle Valve Section
Assembly Procedures
Written Materials
Procedures for Assembly and Disassembly of 6 Stack Proportional Valve (Pilot)
Development Diagram
Assembly and disassembly procedures
Precautions
Replacement of Proportional Solenoid
Disassembly
Assembly
Replacement of Sleeve and Spool
Disassembly
Assembly
Replacement of Poppet (Check Valve for Normally Open)
Disassembly
assembly
Troubleshooting
Procedures for Pressure Measurement from the Monitor Display
Monitor and Switch Panel
Pressure Measurement Method
Operating Method
PROCEDURES FOR MEASURING HYDRAULIC OIL TEMPERATURE FROM THE MONITOR DISPLAY
Hydraulic Oil Temperature Measurement Method
Operating Method
Procedures for Pressure Measurement by Installing Pressure Gauge
Preparations
Items to Prepare
Pressure Measurement Port
Control Valve
Location of Relief Valves
Pressure Measurement Preparations
A Attachment Pressure Measurement
Boom-down Pressure Measurement
D Option Line Pressure Measurement
Pilot Pressure Measurement
Pressure Gauge Installation
Negative Control Pressure Measurement
Pressure Adjustment
Main Pressure Adjustment
Pressure Measurement and Adjustment Preparations
Main Relief Pressure Adjustment
Overload Relief Pressure Adjustment
Adjustment of Swing Relief Pressure
Pilot Pressure Adjustment
Hydraulic Pump Flow Measurement Procedures
Preparations
Items to Prepare
Work Preparations
Flow Measurement
Air Bleed Procedure
Sampling Procedure
Sampling of Hydraulic Fluid
Hydraulic Equipment Layout
Overall View
Pump Chamber Hydraulic Equipment Layout
Swing Body Center Section Hydraulic Equipment Layout
Housing Left Side Hydraulic Equipment Layout
Layout of Hydraulic Equipment in Cab
J HYDRAULIC EQUIPMENT-OVERSIZED PAGES
001_J_Explanation of Hydraulic Circuit and Operations (standard model)_245X4
J
Travel Circuit
Travel Low-speed Circuit
Travel High-speed Circuit
Straight Travel Circuit (with HBCV)
Swing Circuit
Swing Speed Limit Control Circuit
Swing Relief Cut Control Circuit
Swing Brake Circuit
Swing Parking Circuit (lever in neutral)
Swing Parking Circuit (brake release)
Swing Parking Circuit (machine stop)
Boom Circuit
Boom-up Circuit (for independent operation) (with HBCV)
Boom-up Spool Stroke Control Circuit (for compound operation) (boom-up + arm-in operations) (with HBCV)
Boom-down Regenerative Circuit (arm-out + boom-down operations) (with HBCV)
Boom-down Load Holding Valve Circuit (with HBCV)
Arm Circuit
Arm-out Circuit (with HBCV)
Arm Semi-parallel 1 Circuit (for independent operation) (with HBCV)
Arm Semi-parallel 1 Circuit (for compound operation) (ex : arm-out + right swing operations) (with HBCV)
Arm Semi-parallel 1 Circuit (for compound operation) (ex : arm-in + boom-up operations) (with HBCV)
Arm Semi-parallel 2 Circuit (for independent operation) (with HBCV)
Arm Semi-parallel 2 Circuit (for compound operation) (ex : arm-in + boom-up operations) (with HBCV)
Arm-in Regenerative Circuit (with HBCV)
Arm-in Load Holding Valve Circuit (with HBCV)
Bucket Circuit
Bucket-open Circuit
Bucket-close Regenerative Circuit
Bucket-close Spool Stroke Control Circuit
Negative Control Circuit
Other Circuits
Cushion Circuit (arm-out operation)
Cushion Circuit (when stopping arm-out operation)
Cushion Circuit (arm-out → arm-in operation)
Heat Circuit (lever in neutral)
Auto Pressure Boost Circuit (arm in)
002_J_Explanation of Hydraulic Circuit and Operations (option)_245X4
J
Option Circuits
Single Breaker Circuit (pedal type)
Single Double-acting Circuit (proportional control type) (1 pump hydraulic fork)
Multi-purpose Circuit (proportional control type) (breaker)
Multi-purpose Circuit (proportional control type) (2 pumps flow crusher)
Multi-purpose Circuit (proportional control type) (electromagnetic relief) (breaker)
Multi-purpose Circuit (proportional control type) (electromagnetic relief) (crusher)
2nd Option Circuit (proportional control type) (hydraulic rotation fork)
N CAB
Removal and Installation of Operator’s Seat
Removal of Operator’s Seat
Removal and Installation of Cab Assembly
Removal of Cab Assembly
Removal and Installation of Wiper
Removal of Wiper
Installation of wiper
Removal and Installation of Cab Windshield
Removal of Cab Windshield
Installation of Cab Front Glass
Window Lock Adjustment Procedure
Window Lock (front side)
Window Lock (rear side)
Removal and Installation of Housing Guardrail
Removal of Housing Guardrail
Tightening torque
R ELECTRICAL PARTS
Basic Functions
Monitor Control
Monitor Display Dimming
Diagnostic Trouble Code Indicator
Clock
Basic Operation
Battery save
Working Light
LED Light
Room Lamp
Radio Mute
Wiper and Washer
Safety
Horn
Back/Side View Monitor
Precautions for Camera Installation
Maintenance
Anti-theft
Manual Lock
Service Support Screen Lock
Customer-specific System Information Screen Lock
Maintenance Information Screen Lock
Option Line Setting Screen Lock
Setting
Clock Adjustment
Screen Brightness Setting
Battery disconnect switch
Explanation of Controller
Service Support
Screen Operations
Screen Display List
Service Monitor Structure
CHECK Screen List
MACHINE STATUS
HYDRAULIC STATUS
ENGINE STATUS
FAULT HISTORY
WORK HISTORY
HYDRAULIC HISTORY
ENGINE HISTORY
DEVICE TEST
ECM/DCU Memory Clear
SCR RE-GEN
Urea Line Leak Test
CCV Operation Test
Dosing Test
Reverting Valve Operation Test
Common Rail Pressure Test
Idle Speed Test / Injector Test
EGR Valve Control Test
VG Turbo Control Test
Intake Throttle Control Test
CONTROL UNIT Screen List
MCM-MAIN
MCM-SUB
COMMU TERMINAL
SETUP Screen List
MACHINE SELECT
DIMENSIONS
PARAMETERS
ENGINE INFORMATION
ENGINE INFORMATION
Data Confirmation
Data Transfer (Copy)
QR (INJECTOR) CODE
Injector number
Screen Layout
Data Source Selection
Manual Input
CAMERA
PASSWORD
CALIBRATE Screen List
THROTTLE VOLUME
OPT LINE RELIEF
PUMP FLOW
RESET Screen List
Connection Connector Pin Layout
Main Controller
Monitor
Sequence Circuit Diagram
Code table
Overall
Block diagram
Main controller
DCU
ECM
Monitor
Air conditioner
Gate Lock
Option
Others
Electrical Symbol List
Electrical Equipment Layout Diagram
Main Unit Left-side Layout Diagram
Engine Section Layout Diagram
Main Unit Right Side Layout Diagram
Cab Layout Diagram 1
Cab Layout Diagram 2
Layout Around Operator Seat
Stand Alone Parts Diagram
Removal and Installation of Wiper Controller
Removal of Wiper Controller
Installation of wiper controller
Removal and Installation of Wiper Motor
Removal of Wiper Motor
Installation of wiper motor
Removal and Installation of ECM
Removal of ECM
Installation of ECM
Removal and Installation of Main Controller
Main controller Removal
Removal and Installation of DCU
Removal of DCU
Installation of DCU
Removal and Installation of Monitor
Removal of Monitor
Removal and Installation of Rear View Camera
Removal of Rear View Camera
Removal and Installation of Side Camera (right)
Removal of Side Camera (Right)
Installation of Side Camera (Right)
Removal and Installation of Side Camera (Left)
Removal of Side Camera (Left)
Removal and Installation of WAVES Controller
Removal of WAVES Controller
How to Set WAVES
Air Conditioner Overall Diagram
Frame
Circuit Diagram
Air Conditioner Circuit Diagram
Explanation of Functions
Air Mix Motor Actuator Control
Blow Mode Motor Actuator Control
Refresh/Recirculate Switch Motor Actuator Control
Blower Amp Control
Compressor Clutch Control
COOLMAX Control and HOTMAX Control
Abnormality Detection and Control after Abnormality Detected
Monitor Mode
Door Switch Control
Actuator Inspection
Air Mix Motor Actuator Inspection
Refresh/Recirculate Switch Motor Actuator Inspection
Mode Motor Actuator Inspection
Self-diagnosis Function with Panel Display
Abnormality Display and Self-check Procedures
Abnormality Display Position
Explanation of Abnormality Display
Motor Actuator Abnormality
Sensor Abnormality
Explanation of Monitor Mode
Monitor Mode Display Position
Monitor Mode Display Operating Method
Display Contents in Monitor Mode
Air Conditioner Troubleshooting
Part Function and Good/Poor Judgment
Control Panel
Blower Amp
Relay
Air Mix Actuator
Refresh/Recirculate Actuator
Mode switch actuator
Evaporator Sensor
Dual Pressure Switch
Solar Radiation Sensor
Inside Air Sensor
Assembly and Disassembly of Unit
Removal of Blower Unit
Replacement of Blower Motor
Replacement of Blower Amp
Removal of Heater Core
Removal of Switchover BOX
Replacement of Evaporator and Expansion Valve
Installation of Evaporator Sensor
Replacement of Motor Actuator
Removal and Installation of Compressor
Removal of Compressor
Removal and Installation of Condenser
Removal of Condenser
Removal and Installation of Receiver Dryer
Removal of Receiver Dryer
Work Precautions
Work Procedures
Air Conditioner Refrigerant Filling is Divided into the “Vacuum Operation” and “Gas Filling Operation”
Operation Chart
Tools
Filling Procedures
Charging Hose Connection Position
Connecting Gauge Manifold
Vacuuming
Gas Filling Operation, High-pressure Side
Gas Filling Work, Low Pressure Side
R ELECTRICAL PARTS-OVERSIZED PAGES
004_R_Electrical Parts and Wiring Assembly Diagram_245X4
R
Frame (main unit right side, main unit center section)
Frame (main unit left side)
Engine and Pump
Battery
Cab 1
Cab 2
003_R_Electrical Connector Wiring Diagram_245X4
R
Frame Main Harness
Control Valve Harness
SCR Harness
Light Harness (boom light)
Light Harness (cab light)
Cab Light Harness (with guard)
1-pedal Travel Harness
Cab Main Harness
Indicator Jumper
Indicator Jumper
Jumper Harness
Console Harness
GPS Harness
GPS Harness
Computer S Harness
Feed Pump Harness
WAVES Harness
Camera Harness [700 mm (27 559 in )]
Camera Harness [1200 mm (47 244 in )]
Camera Intermediate Harness [6500 mm (255 906 in )]
Camera Harness
Quick Coupler Harness
Option Harness (pedal)
Option Harness (proportional control)
2nd Option Harness (proportional control)
V ATTACHMENTS
Backhoe Attachment
Cylinder
Attachment (Backhoe)
1 Boom and Swing Frame Installation Section
2 Boom Cylinder and Swing Frame Installation Section
3 Boom and Boom Cylinder Installation Section
4 Boom and Arm Cylinder Installation Section
5 Boom and Arm Installation Section
6 Arm and Arm Cylinder Installation Section
7 Arm and Bucket Cylinder Installation Section
8 Arm and Arm Link Installation Section
9 Bucket and Bucket Link Installation Section
10 Bucket Link and Bucket Cylinder Installation Section
11 Bucket and Arm Installation Section
Dozer Blade
1 Blade Cylinder Installation Section
2 Lower Frame and Blade Cylinder Installation Section
3 Lower Frame and Blade Installation Section
Removal and Installation of Bucket Cylinder
Removal of Bucket Cylinder
Removal and Installation of Arm Cylinder
Removal of Arm Cylinder
Removal and Installation of Boom Cylinder
Removal of Boom Cylinder
Removal and Installation of Blade Cylinder
Removal of Blade Cylinder
Procedures for Operation/Assembly and Disassembly of Hydraulic Cylinder
Specifications and Structure Diagram (including the assembly diagram and parts table)
Basic Functions
Function of Each Location
Cylinder Head Assembly (made by KYB)
Piston Assembly (made by KYB)
Pipe Assembly (made by KYB)
Handling Precautions
Precautions for Installing the Cylinder on the Machine Body
Usage Cautions
Maintenance and Inspection Cautions
Maintenance Inspection and Service
Trouble Diagnostics
Storage Standards
Storing Parts Individually (In principle, store indoors )
When Mounted on Vehicle Body
Recommended Anti-rust Oil
Preparations ····· Prepare the Following before Starting Disassembly
General Work Precautions
Inspection after Assembly
Required Tool
General Tool
Special Jig (made by KYB)
Special Jig Parts Number List (made by KYB)
Disassembly Procedures (made by KYB)
Assembly Procedures (made by KYB)
Test Operation
Usage Limits
Structural Diagram (made by KYB)
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Blade Cylinder
HBCV
structure
Function
Port Diagram
HBCV
Air Bleed Procedure
HBCV
Boom Cylinder HBCV
Arm Cylinder HBCV
Removal and Installation of HBCV
Removal and Installation of Arm HBCV
Removal of Arm HBCV
Installation of arm HBCV
Removal and Installation of Boom HBCV
Removal of Boom HBCV
Removal of Bucket
Removal and Installation of Bucket Link
Removal of Bucket Link
Removal of Arm
Installation of Arm
Removal of Boom
Removal of Blade
Z OTHER
Change from Type 6
Overall Layout
Lower
Hydraulic-related Data
Hydraulic Control
Cab, House
Electrical Data
Electric Control
Specifications
245X4
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
OPERATOR ENVIRONMENT
UNDERCARRIAGE
MASS
DIGGING FORCE (with 0 9 m3 Sumitomo Bucket) (ISO 6015)
DIMENSIONS
WORKING RANGES
SYSTEM FLUID CAPACITIES AND SPECIFICATIONS
245X4 (BB)
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
UNDERCARRIAGE
DOZER BLADE
MASS
DIMENSIONS
WORKING RANGES
Arm Dimension
Standard Arm [2 94 m (9 65 ft )]
Short Arm [2 40 m (7 87 ft )]
Main Unit Weight
Divided Weight (standard specifications)
Divided Weight (Blade Specifications)
Stand Alone Part Weight (standard specifications)
Stand Alone Part Weight (Blade Specifications)
Shoe Weight (per Side)
Shoe Weight (per Side) (Blade Specifications)
Arm Weight
Bolt Size and Torque Table
Special Torque Setting
Overall View
245X4 (Grouser Shoe)
Standard Arm [2 94 m (9 6457 ft )]
Short Arm [2 40 m (7 8740 ft )]
245X4 (Link Chain)
245X4 (BB) (Grouser Shoe)
245X4 (BB) (Link Chain)
WORK RANGE DIAGRAM
245X4
245X4 (BB)
New Machine Performance Judgment Table
Table of Standards
Measurement Method
Engine speed
Pressure at Each Part
Pump Command Displacement
Cylinder Down Amount
Attachment Speed
Swing Speed
Swing (180°) Brake Angle
Travel Speed
Off Travel Amount
Travel Sprocket Speed
Shoe Tension Amount
Swing Ball Race Bearing Movement Amount and Bucket Tip Movement Amount
FLUIDS AND LUBRICANTS
HYDRAULIC FLUID
Engine Oil
Fuel
Conditions applicable to diesel fuel
Recommended conditions applicable to diesel fuels
Main-Unit-related Diagnostic Trouble Code List
Main Unit-side Trouble
Diagnostic Trouble Code: 7000 Pressure Sensor P1 Abnormality
Diagnostic Trouble Code: 7001 Pressure Sensor P2 Abnormality
Diagnostic Trouble Code: 7002 Pressure Sensor N1 Abnormality
Diagnostic Trouble Code: 7003 Pressure Sensor N2 Abnormality
Diagnostic Trouble Code: 7004 Pressure sensor boom cylinder bottom abnormality
Diagnostic Trouble Code: 7007 Pressure sensor arm cylinder rod abnormality
Diagnostic Trouble Code: 7021 Pressure sensor swing pilot abnormality
Diagnostic Trouble Code: 7023 Pressure sensor arm-in pilot abnormality
Diagnostic Trouble Code: 7040 Level sensor fuel abnormality
Diagnostic Trouble Code: 7041 Temperature sensor hydraulic oil abnormality
Diagnostic Trouble Code: 7065 Pressure sensor boom-up pilot abnormality
Diagnostic Trouble Code: 7067 Pressure sensor bucket-close pilot abnormality
Diagnostic Trouble Code: 7068 Pressure sensor boom-down pilot abnormality
Diagnostic Trouble Code: 7069 Pressure sensor arm-out pilot abnormality
Diagnostic Trouble Code: 7070 Pressure sensor bucket-open pilot abnormality
Diagnostic Trouble Code: 7071 Pressure Sensor Travel Right Pilot Abnormality
Diagnostic Trouble Code: 7072 Pressure Sensor Travel Left Pilot Abnormality
Diagnostic Trouble Code: 7073 Pressure Sensor Travel 1 Pedal Abnormality
Diagnostic Trouble Code: 7074 Pressure Sensor 1st Option Pilot (Common/Front Press) Abnormality
Diagnostic Trouble Code: 7075 Pressure Sensor Arm Cylinder Bottom Abnormality
Diagnostic Trouble Code: 7078 Pressure Sensor 1st Option Pilot (Back Press) Abnormality
Diagnostic Trouble Code: 7200 Swing Brake Solenoid Abnormality
Diagnostic Trouble Code: 7201 Travel 2nd Speed Switchover Solenoid Abnormality
Diagnostic Trouble Code: 7202 Pressure Boost Solenoid Abnormality
Diagnostic Trouble Code: 7203 Travel Alarm Buzzer Abnormality
Diagnostic Trouble Code: 7206 Option Return Line Switchover Solenoid Abnormality
Diagnostic Trouble Code: 7207 Free Swing Solenoid Abnormality
Diagnostic Trouble Code: 7213 Quick Coupler Buzzer Abnormality
Diagnostic Trouble Code: 7214 Quick Coupler Solenoid Abnormality
Diagnostic Trouble Code: 7247 Boom 2-Down Pilot Proportional Valve Abnormality
Diagnostic Trouble Code: 7249 Bucket-Close Pilot Proportional Valve Abnormality
Diagnostic Trouble Code: 7250 Option Relief Pressure Proportional Valve Abnormality
Diagnostic Trouble Code: 7265 Arm 1 Semi-Parallel Proportional Valve Abnormality
Diagnostic Trouble Code: 7266 Arm 2 Semi-Parallel Proportional Valve Abnormality
Diagnostic Trouble Code: 7267 Arm 1 Regeneration Release Proportional Valve Abnormality
Diagnostic Trouble Code: 7270 Tilting 1 Proportional Valve Abnormality
Diagnostic Trouble Code: 7271 Tilting 2 Proportional Valve Abnormality
Diagnostic Trouble Code: 7273 Straight Travel Proportional Valve Abnormality
Diagnostic Trouble Code: 7400 Coolant Temperature Overheating 1
Diagnostic Trouble Code: 7401 Coolant Temperature Overheating 2
Diagnostic Trouble Code: 7404 Oil Temperature Overheating
Diagnostic Trouble Code: 7405 Boost Temperature Overheating 1
Diagnostic Trouble Code: 7406 Boost Temperature Overheating 2
Diagnostic Trouble Code: 7420 Alternator Power Generation Defect
Diagnostic Trouble Code: 7421 Decrease in Coolant Level
Diagnostic Trouble Code: 7422 Decrease in Engine Oil Pressure
Diagnostic Trouble Code: 7423 Air Cleaner Clogging
Diagnostic Trouble Code: 7424 Return Filter Clogging
Diagnostic Trouble Code: 7426 Fuel Filter Clogging 1
Diagnostic Trouble Code: 7427 Fuel Filter Clogging 2
Diagnostic Trouble Code: 7428 Inducement (Remaining Urea Level Low) – Warning
Diagnostic Trouble Code: 7429 Inducement (Remaining Urea Level Low) – Early
Diagnostic Trouble Code: 7430 Inducement (Remaining Urea Level Low) – Final
Diagnostic Trouble Code: 7602: ECM Communication Abnormality
Diagnostic Trouble Code: 7605 ECM Not Matched
Diagnostic Trouble Code: 7606 EEPROM Abnormality
Diagnostic Trouble Code: 7608 Camera Abnormality
Diagnostic Trouble Code: 7612 Air Conditioner Communication Abnormality
Diagnostic Trouble Code: 7613 Monitor communication (CAN) abnormality
Diagnostic Trouble Code: 7618 DCU Communication Abnormality
List of special tools
NUMERICAL VALUE CONVERSION TABLE
Unit Conversion Ratio
Length
Area
Volume
Weight
Pressure
Torque
Temperature
A
Take-up Roller Special Tool
245X4
Upper Roller Special Tool
210X4/210X4 LF/245X4/250X4
Lower Roller Special Tool
C
Swing Motor Special Tool
H
Engine Oil Filter Special Tool
Fuel Filter Special Tool
Injector Special Tool
Circuit Test Special Tool
Valve Guide Special Tool
Cylinder Head Special Tool
Head Bolt Special Tool
Crankshaft Special Tool
Valve Spring Special Tool
J
Remote Control Valve Special Tool
R
Gas Filling Special Tool
V
Attachment Special Tool (for Cylinder Assembly)
Special Jigs Part Number List
Paint Colors
Abbreviation
Brand: Link-Belt
Excavator
SAFETY
Safety
ROPS
ROPS Judgment
A LOWER
Lower Component
Travel Unit
Take-up roller
Upper Roller
Lower Roller
Recoil Spring
Shoe
Shoe
Center Joint
Travel Motor
Piston Motor
Reduction Gear
Port Diagram
Travel Motor
Center Joint
Basic Functions
Travel Alarm
Dimension Diagram
Assembly Procedures
Dimension Diagram
Assembly Procedures
Dimension Diagram
Assembly Procedures
Dimension Diagram
Assembly procedures
Dimension Diagram
Assembly Procedures
Standard Tools
Secondary Materials
Special Tool (jig)
Measurement Device
Tightening Torque
Assembly Procedure
Motor Installation
Inspection
Troubleshooting
Structural Diagram
Part Table
Drive sprocket
Take-up roller
Upper roller
Lower Roller
Inspection Gauge
For Drive Sprocket
For Take-up Roller
For Upper Roller
For Lower Roller
Preparations
Air Bleed Procedure
Travel Motor
Upper Component
Swing Unit
Swing Motor
Brake Section
Port Diagram
Swing Motor
Basic Functions
Swing brake
Swing Lock
Swing Speed Limit
Swing Relief Cut
Troubleshooting
Jig
Disassembly
Assembly
Jig
Preparations
Air Bleed Procedure
Swing motor
Check
H ENGINE
Engine-related
SCR
Basic Functions
Fuel Gauge
SCR Gauge
Fuel Economy Gauge
Neutral start
Power-cut Delay
Preheat
Throttle
Idle start
Auto Idle
One-touch Idle
Auto Warm-Up
Idle Shutdown
Idle up
Work Mode Control
SCR RE-GEN
Inducement
Air Filter Clogging
Main Data
Engine Stalling
Abnormal Noise
OBD system check
Removal of Radiator
Removal of SCR
Installation of SCR
Inspection
Inspection
Lubrication System
Removal of Oil Pan
Inspection
Inspection
Induction System
Exhaust System
Inspection
Removal of Injector
Removal of Piston
Assembly of Piston
Removal of Camshaft
Removal of Flywheel
CKP sensor Removal
CMP sensor Removal
Sampling Procedure
Engine-side Trouble
ECM Trouble
DCU Trouble
Idle Speed
Two Pump Relief
Hydraulic Device
Control-related
Control valve
Selector Valve
Basic Functions
Stroke Control
Gate Lock
Breaker Mode
Crusher Mode
Quick coupler
Port Diagram
Control Valve
Relief Valve
Cushion Valve
Direction Valve
Manifold Under Cab
Hydraulic Tank
Overall View
Development Diagram
Component Table
Regulator
Component Table
Control Valve
Basic Configuration
Operation
Structure
Function
Operation
Structural Diagram
Operation
Structural Diagram
Cushion Valve
structure
Structure
Development Diagram
Structure
structure
operation principle
Structure
Tools
Assembly Procedures
Development Diagram
Component Table
Tightening torque
Overall View
Development Diagram
Component Table
Tools
Assembly Procedures
Component Table
Disassembly
Cleaning
Inspection
assembly
Part List
Relief Valve
Installation
Operation
Assembly Procedures
Assembly Procedures
Assembly Procedures
Written Materials
Development Diagram
Precautions
Disassembly
Assembly
Disassembly
Assembly
Disassembly
assembly
Troubleshooting
Operating Method
Operating Method
Preparations
Items to Prepare
Control Valve
Pressure Adjustment
Preparations
Items to Prepare
Work Preparations
Flow Measurement
Air Bleed Procedure
Sampling Procedure
Overall View
J
Travel Circuit
Swing Circuit
Swing Brake Circuit
Boom Circuit
Arm Circuit
Bucket Circuit
Bucket-open Circuit
Other Circuits
J
Option Circuits
N CAB
Removal of Wiper
Tightening torque
R ELECTRICAL PARTS
Basic Functions
Monitor Control
Clock
Basic Operation
Battery save
Working Light
LED Light
Room Lamp
Radio Mute
Wiper and Washer
Safety
Horn
Maintenance
Anti-theft
Manual Lock
Setting
Clock Adjustment
Service Support
Screen Operations
Screen Display List
CHECK Screen List
MACHINE STATUS
HYDRAULIC STATUS
ENGINE STATUS
FAULT HISTORY
WORK HISTORY
HYDRAULIC HISTORY
ENGINE HISTORY
DEVICE TEST
SCR RE-GEN
Urea Line Leak Test
CCV Operation Test
Dosing Test
MCM-MAIN
MCM-SUB
COMMU TERMINAL
SETUP Screen List
MACHINE SELECT
DIMENSIONS
PARAMETERS
ENGINE INFORMATION
ENGINE INFORMATION
Data Confirmation
QR (INJECTOR) CODE
Injector number
Screen Layout
Manual Input
CAMERA
PASSWORD
THROTTLE VOLUME
OPT LINE RELIEF
PUMP FLOW
RESET Screen List
Main Controller
Monitor
Code table
Overall
Block diagram
Main controller
DCU
ECM
Monitor
Air conditioner
Gate Lock
Option
Others
Removal of ECM
Installation of ECM
Removal of DCU
Installation of DCU
Removal of Monitor
How to Set WAVES
Frame
Circuit Diagram
Blower Amp Control
Monitor Mode
Door Switch Control
Actuator Inspection
Sensor Abnormality
Control Panel
Blower Amp
Relay
Air Mix Actuator
Evaporator Sensor
Inside Air Sensor
Work Precautions
Work Procedures
Operation Chart
Tools
Filling Procedures
Vacuuming
R
Engine and Pump
Battery
Cab 1
Cab 2
R
Frame Main Harness
SCR Harness
Cab Main Harness
Indicator Jumper
Indicator Jumper
Jumper Harness
Console Harness
GPS Harness
GPS Harness
Computer S Harness
Feed Pump Harness
WAVES Harness
Camera Harness
V ATTACHMENTS
Backhoe Attachment
Cylinder
Dozer Blade
Basic Functions
Usage Cautions
Trouble Diagnostics
Storage Standards
Required Tool
General Tool
Test Operation
Usage Limits
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Blade Cylinder
HBCV
structure
Function
Port Diagram
HBCV
Air Bleed Procedure
HBCV
Boom Cylinder HBCV
Arm Cylinder HBCV
Removal of Arm HBCV
Removal of Bucket
Removal of Arm
Installation of Arm
Removal of Boom
Removal of Blade
Z OTHER
Change from Type 6
Overall Layout
Lower
Hydraulic Control
Cab, House
Electrical Data
Electric Control
Specifications
245X4
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
UNDERCARRIAGE
MASS
DIMENSIONS
WORKING RANGES
245X4 (BB)
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
UNDERCARRIAGE
DOZER BLADE
MASS
DIMENSIONS
WORKING RANGES
Arm Dimension
Main Unit Weight
Arm Weight
Overall View
245X4 (Link Chain)
WORK RANGE DIAGRAM
245X4
245X4 (BB)
Table of Standards
Measurement Method
Engine speed
Attachment Speed
Swing Speed
Travel Speed
Off Travel Amount
Shoe Tension Amount
HYDRAULIC FLUID
Engine Oil
Fuel
Length
Area
Volume
Weight
Pressure
Torque
Temperature
A
245X4
C
H
J
R
V
Paint Colors
Abbreviation
- Linkbelt LS108C Parts, Operation Maintenance and Load Chart Manuals
- Linkbelt Greer BBTM-508/BB-509 ANTI TWO-BLOCK ALARM SYSTEM – HYDRAULIC CRANE SYSTEM LAYOUT
- Link Belt 350X3 Excavator Schematic Service Manual
- Linkbet LS 118 Operator's Manual
- Link Belt 145X3 Hydraulic Excavators Operator's Manual
- Link Belt 3400 Quantum Excavator Schematic Shop Manual
- Link Belt HTC86100 Operator's Manual
- Link Belt RTC80130 Parts Manual
- Linkbelt RTC-8065 II Operator's Manual (Spanish)
- Link Belt 2800 Quantum Excavator Shop Manual
- Link Belt RTC-80130 II Operator's Manual
- Linkbelt LS 98 Operator's Manual
- Link Belt 210X2-EX Excavators Parts Manual
- MicroGuard 404 Trouble Shooting Manual
- Linkbelt LS-278 Rated Capacity Limiter Operators Manual
