[Linkbelt] Linkbelt Excavator 145X4 LC DZ Service Manual WLSM1457-04LX
Brand: Link-Belt
Type of Machine: Excavator
Type of Document: Service Manual
Model: Link-Belt 145X4 LC Hydraulic Excavator, Link-Belt 145X4 DZ Hydraulic Excavator
Number of Pages: 2100 Pages
Excavator
SAFETY
Safety, general information and standard torque data
Safety
ROPS
ROPS Judgment Method
Standard Torque Data For Cap Screws And Nuts
Bolt and Nut Tightening
Protection of Electric/Electronics System During Charging or Welding
A LOWER
Main Equipment Table
Lower Component
Travel Unit
Take-up Roller
Upper Roller
Lower Roller
Recoil Spring
Shoe (LC)
Shoe (Blade)
Center Joint (LC)
Center Joint (Blade)
Main Equipment Structure and Operation Explanation
Travel Motor
Safety Precautions
Data
Use of Product
Specifications
Type Indication
Outside Dimension Diagram and Hydraulic Circuit Diagram
Basic Structure and Drawing
Assembly Cross-Section Diagram
Part List
Exploded Views
Reduction Gear
Hydraulic Motor Section
Usage Precautions
Installation Instructions
Line
Hydraulic Fluid
Maintenance and Inspection
Daily Inspection
Replacement of Hydraulic Fluid
Lubricant
Table of Seals
Failure and Necessary Action
Storage of Travel Motor
Port Diagram
Travel Motor
Center Joint
Basic Functions
Travel speed selection
Travel Alarm
Removal and Installation of Track
Removal and Installation of Shoe Assembly
Removal of Shoe Assembly
Removal and Installation of Shoe Plate
Removal of Shoe Plate
Precautions for Shoe Bolt Installation
Removal and Installation of Roller
Removal and Installation of Upper Roller
Removal of Upper Roller
Assembly and Disassembly of Upper Roller
Configuration Diagram
Dimension Diagram
Jig Dimension Diagram
Disassembly Procedures
Assembly Procedures
Removal and Installation of Lower Roller
Removal of Lower Roller
Assembly and Disassembly of Lower Roller
Dimension Diagram
Assembly Procedures
Removal and Installation of Drive Sprocket
Removal of Drive Sprocket
Removal and Installation of Take-up Roller
Removal of Take-up Roller
Assembly and Disassembly of Take-up Roller
Dimension Diagram
Assembly Procedures
Removal and Installation of Grease Cylinder
Removal of Grease Cylinder
Installation of grease cylinder
Assembly and Disassembly of Tension Shock Absorber
Dimension Diagram
Jig dimension diagram
Disassembly procedures
Assembly procedures
Removal and Installation of Center Joint
Removal of Center Joint
Assembly and Disassembly of Center Joint
Dimension Diagram
Dimension Diagram (Blade)
Assembly Procedures
Removal and Installation of Travel Motor
Removal of Travel Motor
Assembly and Disassembly of Travel Motor (nabtesco)
Safety Precautions
Service Overview
Tools
Tightening Torque
Weight Table
Disassembly
Preparations
General Work Precautions
Maintenance Standards
Seals
Maintenance Standards for Worn Components
Assembly
Preparations
Assembly Procedure
Performance Check Test
Drive Sprocket
Take-up Roller
Upper roller
Lower Roller
Track Shoe (Grouser Shoe)
Inspection Gauge
For Drive Sprocket
For Take-up Roller
For Upper Roller
For Lower Roller
Pressure Measurement and Adjustment Procedures
Main Pressure Measurement
B Travel Pressure Measurement
Drain Volume Measurement Procedures
Preparations
Travel Motor Drain Volume Measurement
Air Bleed Procedure
Travel Motor
B C SWING UNIT, COUNTERWEIGHT
Upper Component
Swing Unit
Swing Unit
Explanation of Swing Reduction Gear
Swing Motor Operation Explanation
Hydraulic Motor
Mechanical Brake
Relief Valve
Make-up valve
Bypass Valve
Assembly cross-section diagram
Parts List
Disassembly and Assembly Diagram (Swing Motor)
Disassembly and Assembly Diagram (Reduction Gear)
Port Diagram
Swing motor
Basic Functions
Swing brake
Swing lock
Swing Speed Limit
Swing Relief Cut
Removal and Installation of Swing Unit
Removal of Swing Unit
Assembly and Disassembly of Swing Motor and Swing Reduction Gear
Causes of Failures, and Actions
Tools
Jig
Tightening torque
Weight Table
Disassembly
Disassembly of Swing Unit
Disassembly of Swing Reduction Gear
Assembly
Assembly of Swing Reduction Gear
Assembly of Swing Motor
Assembly of Swing Unit
Parts List
Removal and Installation of Counterweight
Removal of Counterweight
C Swing Pressure Measurement
Preparations
Swing Motor Drain Volume Measurement
Air Bleed Procedure
Swing Motor
Check
H ENGINE
Engine-related
Air Cleaner (double element)
SCR
Basic Functions
Fuel Gauge
Coolant Temperature Gauge
SCR Gauge
Fuel economy gauge
Neutral start
Power-cut Delay
Preheat
Throttle
Throttle volume position detection
Idle start
Auto idle
One-touch idle
Auto Warm-up
Idle shut down
Idle up
Work mode control
Engine Emergency Stop
SCR RE-GEN
Inducement
Feed Pump Automatic Stop
Coolant Level Decrease
Air Filter Clogging
Fuel Filter Clogging
Battery Charge Abnormality
Horsepower Reduction Control (in Uplands)
Horsepower Reduction Control (at Engine Failure)
Primary specifications
Function, Structure, Operation
Function, structure, operation (SCR)
SCR Control System Inspection
Explanation of SCR Operation
Diagnosis for Each Symptom
Intermittent conditions of urea selective catalytic reduction system
Urea fluid consumption too high
Ammonia smell noticeable
White crystalline powder visible
Engine start failure
Engine stalling
Engine Hunting, Rough Idling
Excess Amount of White Smoke in Exhaust Gas
Excessive Black Smoke in Exhaust Gas
Abnormal Noise
High Fuel Consumption
High Oil Consumption
Insufficient engine output
Functional Inspection
Engine compression pressure inspection
Fuel System Inspection
Lubrication system check
Suction air system inspection
Exhaust system inspection
Inspection of EGR Control System
Starting system check
Glow control system check
OBD system check
Inspection of the monitor warning light illumination circuit system
Inspection of the monitor warning light blinking circuit system
Inspection of the starter circuit system
Removal and Installation of Engine Assembly
Removal of Engine Assembly
Removal and Installation of Fuel Cooler, Engine Intercooler, Radiator, and Oil Cooler
Removal of Fuel Cooler
Removal and Installation of Engine Intercooler
Removal of Intercooler
Installation of Inter Cooler
Inspection of Intercooler
Removal and Installation of Radiator
Removal of Radiator
Inspection of Radiator
Removal and Installation of Oil Cooler
Removal of Oil Cooler
Installation of oil cooler
Removal and Installation of Turbo Charger
Turbocharger assembly Removal
Turbocharger assembly Installation
Inspection of Turbocharger assembly
Removal and Installation of EGR Valve (if equipped)
Removal of EGR Valve
Inspection of EGR Valve
Removal and Installation of EGR Cooler
Removal of EGR Cooler
Inspection of EGR Cooler
Removal and Installation of Engine Hood
Removal of Top Cover
Removal and Installation of SCR
Removal of SCR
Installation of SCR
Removal and Installation of SCR Catalyst
Removal of SCR Catalyst
Disassembly of SCR Catalyst
Assembly of SCR Catalyst
Inspection of SCR Catalyst
Removal and Installation of Cylinder Head Cover
Cylinder head cover Removal
Removal of Cylinder Head
Disassembly of Cylinder Head
Assembly of Cylinder Head
Inspection of Cylinder Head
Removal and Installation of Cylinder Block
Removal of Cylinder block
Installation of Cylinder block
Inspection of Cylinder Block
Lubrication System
Removal and Installation of Oil Pan and Crank Case
Removal of Oil pan and crank case
Installation of Oil pan and crank case
Disassembly of Crankcase
Assembly of Crankcase
Removal and Installation of Oil Level Switch
Removal of Oil Level Switch
Removal and Installation of Oil Pump Assembly
Removal of Oil pump assembly
Installation of Oil pump assembly
Inspection of Oil Pump Assembly
Engine oil Inspection
Removal and Installation of Oil Port Cover
Removal of Oil Port Cover
Removal and Installation of Water Pump Assembly
Removal of Water Pump Assembly
Inspection of Water Pump Assembly
Removal and Installation of Thermostat
Removal of Thermostat
Inspection of Thermostat
InspectionInspection of Coolant
Inspection of Cooling Fan Belt
Removal and Installation of Overheat Switch
Removal of Overheat switch
Installation of Overheat switch
Induction System
Inspection of Air Cleaner Element
Exhaust System
Removal and installation of Oxidation Catalyst Assembly
Removal of Oxidation Catalyst Assembly
Installation of Oxidation Catalyst Assembly
Aux Emission Control Devices System
Removal and installation of Dosing Module
Removal of Dosing Module
Disassembly of Dosing Module
Assembly of Dosing Module
Installation of Dosing Module
Removal and installation of DEF Supply Module
Removal of DEF Supply Module
Disassembly of DEF Supply Module
Assembly of DEF Supply Module
Installation of DEF Supply Module
Removal and installation of Coolant Control Valve
Removal of Coolant Control Valve
Installation of Coolant Control Valve
Removal and Installation of DCU
Removal of DCU
Installation of DCU
Removal and installation of DEF Supply Module Filter
Removal of DEF Supply Module Filter
Installation of DEF Supply Module Filter
Removal and Installation of Exhaust Manifold
Removal of Exhaust Manifold
Inspection of Exhaust Manifold
Removal and Installation of Fuel Tank
Removal of Fuel Tank
Installation of fuel tank
Removal and Installation of Urea Pump
Removal of Urea Pump
Removal and Installation of Urea Solution Tank
Removal of Urea Tank
Removal and Installation of Fuel Supply Pump
Removal of Fuel Supply Pump
Removal and Installation of Common Rail Assembly
Removal of Common Rail Assembly
Removal and Installation of Injector
Removal of Injector
Removal and Installation of Crankshaft
Removal of Crankshaft
Disassembly of Crankshaft
Assembly of Crankshaft
Inspection of Crankshaft
Removal and Installation of Piston and Connecting Rod
Removal of Piston and connecting rod
Installation of Piston and connecting rod
Disassembly of Piston and Connecting Rod
Assembly of Piston and Connecting Rod
Inspection of Piston and Connecting Rod
Removal and Installation of Camshaft
Removal of Camshaft
Inspection of Camshaft
Removal and Installation of Flywheel
Removal of Flywheel
Inspection of Flywheel
Removal and Installation of Crankshaft front oil seal
Removal of Crankshaft front oil seal
Removal and Installation of Crankshaft rear oil seal
Removal of Crankshaft Rear Oil Seal
Installation of Crankshaft Rear Oil Seal
Removal and Installation of Timing Chain
Removal of Timing chain
Installation of Timing chain
Removal and Installation of Timing Gear Train
Removal of Timing gear train
Installation of Timing gear train
Inspection of Timing Gear Train
Removal and Installation of Timing Gear Case
Removal of Timing gear case
Installation of Timing gear case
Removal and Installation of Inlet Manifold
Removal of Inlet manifold
Installation of Inlet manifold
Removal and Installation of Rocker Arm Shaft
Removal of Rocker arm shaft assembly
Installation of Rocker arm shaft assembly
Removal and Inspection of Valve Stem Oil Seal and Valve Spring
Removal of Valve stem oil seal and valve spring
Installation of Valve stem oil seal and valve spring
Inspection of Valve Spring
Removal and installation of Intake Throttle Valve
Removal of Intake throttle valve
Installation of Intake throttle valve
Removal and Installation of Starter Motor
Removal of Starter Motor
Inspection of Starter Motor
Removal and Installation of Alternator
Removal of Alternator
Inspection of Alternator
Removal and Installation of Glow Plug
Removal of Glow Plug
Inspection of Glow Plug
Removal and Installation of Suction Control Valve
Removal of Suction Control Valve
Removal and installation of Fuel Filter
Removal of Fuel Filter
Installation of Fuel Filter
Removal and installation of Relief Valve
Removal of Relief valve
Installation of Relief valve
Removal and installation of Fuel Filter Element
Removal of Fuel filter element
Installation of Fuel Filter Element
Removal and installation of Fuel temperature sensor
Removal of Fuel temperature sensor
Installation of Fuel temperature sensor
Inspection of Fuel temperature sensor
Removal and installation of Pressure limiter
Removal of Pressure limiter
Installation of Pressure limiter
Removal and installation of Fuel pressure sensor
Removal of Fuel pressure sensor
Installation of Fuel pressure sensor
Removal and Installation of Fuel filter pressure
Fuel filter pressure sensor Removal
Fuel filter pressure sensor Installation
Removal and Installation of Engine coolant temperature sensor
Engine coolant temperature sensor Removal
Engine coolant temperature sensor Installation
Inspection of Engine coolant temperature sensor
Removal and Installation of CKP sensor
CKP sensor Removal
CKP sensor Installation
Inspection of CKP sensor
Removal and Installation of CMP sensor
CMP sensor Removal
CMP sensor Installation
Inspection of CMP sensor
Removal and Installation of Oil pressure sensor
Oil pressure sensor Removal
Oil pressure sensor Installation
Inspection of Oil pressure sensor
Removal and installation of Boost Sensor
Removal of Boost sensor
Installation of Boost sensor
Inspection of Boost sensor
Removal and installation of Boost Temperature Sensor
Removal of Boost temperature sensor
Installation of Boost temperature sensor
Removal and installation of Turbocharger control solenoid
Removal of Turbocharger control solenoid
Installation of Turbocharger control solenoid
Inspection of Turbocharger control solenoid
Removal and Installation of IMT sensor
IMT sensor Removal
IMT sensor Installation
Removal and installation of MAF and IAT sensor
Removal of MAF and IAT sensor
Installation of MAF and IAT sensor
Inspection of MAF and IAT sensor
Removal and installation of Charge Air Cooler Temperature Sensor 1
Removal of Charge Air Cooler Temperature Sensor 1
Installation of Charge Air Cooler Temperature Sensor 1
Inspection of Charge Air Cooler Temperature Sensor 1
Sampling Procedure
Sampling of Engine Oil
Removal and Installation of Exhaust gas temperature sensor
Removal of Exhaust gas temperature sensor
Inspection of Exhaust gas temperature sensor
Removal and installation of EGR Gas Temperature Sensor 1
Removal of EGR Gas Temperature Sensor 1
Installation of EGR Gas Temperature Sensor 1
Inspection of EGR Gas Temperature Sensor 1
Removal and installation of EGR Gas Temperature Sensor 2
Removal of EGR Gas Temperature Sensor 2
Installation of EGR Gas Temperature Sensor 2
Inspection of EGR Gas Temperature Sensor 2
Removal and installation of NOx Sensor
Removal of NOx Sensor
Installation of NOx Sensor
Removal and installation of EGR Gas Temperature Sensor 3
Removal of EGR Gas Temperature Sensor 3
Installation of EGR Gas Temperature Sensor 3
Removal and Installation of Urea sensor
Removal of Urea Sensor
Installation of Urea Sensor
Engine-related Diagnostic Trouble Code List
Engine-side Trouble
ECM Trouble
DTC P0016 Crankshaft Position – Camshaft Position Correlation Error
DTC P0045 Turbocharger Boost Control VNT Error
DTC P0047 Turbocharger EVRV Control Circuit High
DTC P0087 Fuel Rail/System Pressure – Too Low
DTC P0089 Fuel Pressure Regulator Performance
DTC P0091 Fuel Pressure Regulator Control Circuit Low
DTC P0092 Fuel Pressure Regulator Control Circuit High
DTC P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
DTC P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage
DTC P0102 Mass Air Flow Sensor Circuit Low Input
DTC P0103 Mass Air Flow Sensor Circuit High Input
DTC P0112 Intake Air Temperature Sensor Circuit Low
DTC P0113 Intake Air Temperature Sensor Circuit High
DTC P0117 Engine Coolant Temperature Sensor Circuit Low
DTC P0118 Engine Coolant Temperature Sensor Circuit High
DTC P0122 Throttle Position Sensor Circuit Low
DTC P0123 Throttle Position Sensor Circuit High
DTC P0182 Fuel Temperature Sensor Circuit Low
DTC P0183 Fuel Temperature Sensor Circuit High
DTC P0192 Fuel Rail Pressure Sensor Circuit Low
DTC P0193 Fuel Rail Pressure Sensor Circuit High
DTC P0201 Injector Circuit Open – Cylinder 1
DTC P0202 Injector Circuit Open – Cylinder 2
DTC P0203 Injector Circuit Open – Cylinder 3
DTC P0204 Injector Circuit Open – Cylinder 4
DTC P0217 Engine Coolant Over Temperature Condition
DTC P0219 Engine Overspeed Condition
DTC P0234 Turbocharger Overboost Condition
DTC P0237 Turbo Charger Boost Sensor Circuit Low
DTC P0238 Turbo Charger Boost Sensor Circuit High
DTC P0299 Turbocharger Underboost
DTC P0335 Crankshaft Position Sensor Circuit
DTC P0336 Crankshaft Position Sensor Circuit Range/Performance
DTC P0340 Camshaft Position Sensor Circuit
DTC P0380 Glow Relay Circuit Error
DTC P0401 EGR Flow Insufficient Detected
DTC P0404 EGR Control Circuit Range/Performance
DTC P0409 EGR Sensor Circuit
DTC P041C EGR Cooler Outlet 1 Temp Sensor Circuit Low
DTC P041D EGR Cooler Outlet 1 Temp Sensor Circuit High
DTC P0427 Catalyst Temperature Sensor Circuit Low Sensor 1
DTC P0428 Catalyst Temperature Sensor Circuit High Sensor 1
DTC P042C Catalyst Temperature Sensor Circuit Low Sensor 2
DTC P042D Catalyst Temperature Sensor Circuit High Sensor 2
DTC P0522 Engine Oil Pressure Sensor Circuit Low Input
DTC P0523 Engine Oil Pressure Sensor Circuit High Input
DTC P0545 EGR Cooler Inlet 1 Temp Sensor Circuit Low
DTC P0546 EGR Cooler Inlet 1Temp Sensor Circuit High
DTC P0560 12 Volt Circuit Error
DTC P0563 System Voltage High
DTC P0601 Internal Control Module Memory Check Sum Error
DTC P0602 Internal Control Module QR Code Error
DTC P0604 Internal Control Module RAM Error
DTC P0606 Internal Control Module CPU Error
DTC P060A Internal Control Module CPU IC Error
DTC P060C Internal Control Module A/D Processing Performance
DTC P0615 Starter Relay Circuit Error
DTC P0638 Throttle Actuator Control Range/Performance
DTC P0685 ECM Power Relay Control Circuit Open
DTC P0687 ECM Power Relay Control Circuit High
DTC P06A6 Sensor Reference Voltage 1 Circuit
DTC P06A7 Sensor Reference Voltage 2 Circuit
DTC P06A8 Sensor Reference Voltage 3 Circuit
DTC P06A9 Sensor Reference Voltage 4 Circuit
DTC P06AF Torque Management System – Forced Engine Shutdown
DTC P06D5 Sensor Reference Voltage 5 Circuit
DTC P1076 Charge Air Cooler (CAC) Temperature Sensor 1 Circuit Low Voltage
DTC P1077 Charge Air Cooler (CAC) Temperature Sensor 1 Circuit High Voltage
DTC P1093 Fuel Rail Pressure Too Low
DTC P1097 Compressor Outlet Temperature Sensor Circuit High
DTC P1098 Compressor Outlet Temperature Sensor Circuit High
DTC P1236 Charge Air Cooler Performance Failure
DTC P1261 Injector Positive Voltage Control Circuit Group 1
DTC P1262 Injector Positive Voltage Control Circuit Group 2
DTC P1404 EGR Position Fault
DTC P1606 SW-IC Internal failure
DTC P160B AD-IC Failure Error
DTC P160C AD-IC2 Failure Error
DTC P1621 Control Module Long Term Memory Performance
DTC P1622 Control Module Long Term Memory Hardware
DTC P1669 DPD Lamp Control Circuit
DTC P204F SCR System Error (No Inducement)
DTC P207F Urea Fluid Concentration Too Low
DTC P20C9 SCR System Error
DTC P2122 Pedal Position Sensor 1 Circuit Low Input
DTC P2123 Pedal Position Sensor 1 Circuit High Input
DTC P2127 Pedal Position Sensor 2 Circuit Low Input
DTC P2128 Pedal Position Sensor 2 Circuit High Input
DTC P2138 Pedal Position Sensor 1 – 2 Voltage Correlation
DTC P2146 Fuel Injector Group 1 Supply Voltage Circuit
DTC P2149 Fuel Injector Group 2 Supply Voltage Circuit
DTC P2228 Barometric Pressure Sensor Circuit Low
DTC P2229 Barometric Pressure Sensor Circuit High
DTC P2457 Exhaust Gas Recirculation (EGR) Cooling System Performance
DTC P2458 Purge time Out Error
DTC P2BA7 Urea Fluid Quantity Too Low
DTC P2BAA SCR System Error (Inducement, No Purge)
DTC P3093 Fuel Rail Pressure Too Low
DTC U0001 CAN Bus Error (ISO-CAN)
DTC U0073 Control Module Communication Bus Off
DTC U0101 Lost Communication With CAN
DTC U010E Lost Communications With Dosing Control Module
DTC U0110 Lost Communication With VNT System
DTC U2106 Lost CAN Communications With Wheel Loader Transmission Control System
DTC U0411 Lost CAN Communications With VNT Control Module
DCU Trouble
Diagnostic Trouble Code_P0607: Control Module Characteristic Abnormality
Diagnostic trouble code_P060B: Control Module A/D Conversion Processing Device Abnormality
Diagnostic trouble code_P062F: Control Module EEPROM Abnormality
Diagnostic trouble code_P0641: Sensor Reference Voltage Abnormality
Diagnostic trouble code_P0658: Actuator Supply Power Feed System Abnormality
Diagnostic trouble code_P0659: Actuator Supply Power Feed System Abnormality
Diagnostic trouble code_P1462: Urea Solution Quality Sensor Time-Out Abnormality
Diagnostic trouble code_P1464: Main Relay Abnormality (Early OPEN Error/Sticking Error of Main Relay)
Diagnostic trouble code_P1468: Urea Solution Injection Control Module (DCM) High Temperature Abnormality
Diagnostic trouble code_P1491: Urea Solution High Pressure Abnormality
Diagnostic trouble code_P1493: Urea Solution Injection Control Module (DCM) Screwdriver High Temperature Abnormality
Diagnostic trouble code_P149C: Urea Solution Reducing Pressure Abnormality
DTC P149D Urea Fluid Tank Overtemperature
Diagnostic trouble code_P2000: Cleaning Ratio Abnormality
Diagnostic trouble code_P203B: Urea Solution Tank Level Sensor
Diagnostic trouble code_P203C: Urea Solution Tank Level Sensor Low Voltage Potential
Diagnostic trouble code_P203D: Urea Solution Tank Level Sensor High Voltage Potential
Diagnostic trouble code_P2048: Urea Solution Injector System Low Voltage Potential
Diagnostic trouble code_P2049: Urea Solution Injector System High Voltage Potential
Diagnostic trouble code_P204B: Urea Solution Pressure Sensor System Characteristic Abnormality
Diagnostic trouble code_P204C: Urea Solution Pressure Sensor System Low Voltage Potential
Diagnostic trouble code_P204D: Urea Solution Pressure Sensor System High Voltage Potential
Diagnostic trouble code_P205B: Urea Solution Tank Temperature Sensor Characteristic Abnormality
Diagnostic trouble code_P205C: Urea Solution Tank Temperature Sensor Low Voltage Potential
Diagnostic trouble code_P205D: Urea solution tank temperature sensor high voltage potential
DTC P206A Urea Fluid Quality Sensor Circuit
Diagnostic trouble code_P206B: Urea Sensor High Temperature Abnormality
DTC P206C Urea Fluid Quality Sensor Circuit Low Voltage
DTC P206D Urea Fluid Quality Sensor Circuit High Voltage
Diagnostic trouble code_P207F: Urea Solution Concentration Low
Diagnostic trouble code_P208A: Urea Solution Pump Control System
Diagnostic trouble code_P208B: Urea Solution Pump Characteristic Abnormality
Diagnostic trouble code_P208C: Urea Solution Pump Control System Low Voltage Potential
Diagnostic trouble code_P208D: Urea Solution Pump Control System High Voltage Potential
Diagnostic trouble code_P208E: Urea Solution Injector Attachment
Diagnostic trouble code_P20A0: Urea Solution Reverting Valve System Disconnection
Diagnostic trouble code_P20A2: Urea Solution Reverting Valve System Low Voltage Potential
Diagnostic trouble code_P20A3: Urea Solution Reverting Valve System High Voltage Potential
Diagnostic trouble code_P20AC: Urea Solution Pump Temperature Sensor Characteristic Abnormality
Diagnostic trouble code_P20AD: Urea Solution Pump Module Temperature Sensor Function
Diagnostic trouble code_P20B1: Urea Solution Tank Heater Coolant Control Valve System Disconnection
Diagnostic trouble code_P20B3: Urea Solution Tank Heater Coolant Control Valve System Low Voltage Potential
Diagnostic trouble code_P20B4: Urea solution tank heater coolant control valve system high voltage potential
Diagnostic trouble code_P20E8: Urea Solution Low Pressure Abnormality
Diagnostic trouble code_P20E9: Urea Solution High Pressure Abnormality
Diagnostic trouble code_P20EA: Urea Solution Reducing Pressure Abnormality
Diagnostic trouble code_P20FE: Urea Solution Build-Up Abnormality
Diagnostic trouble code_P2201: NOx Sensor Upstream Function
Diagnostic trouble code_P2206: Ft NOx Sensor Disconnection
Diagnostic trouble code_P2207: Ft NOx Sensor Short-Circuit
Diagnostic trouble code_P2210: Rr NOx Sensor Disconnection
Diagnostic trouble code_P2211: Rr NOx Sensor Short-Circuit
Diagnostic trouble code_P242B: Exhaust Gas Temperature (EGT) Sensor 3 System Function
Diagnostic trouble code_P242C: Exhaust Gas Temperature (EGT) Sensor 3 System Low Voltage Potential
Diagnostic trouble code_P242D: Exhaust Gas Temperature (EGT) Sensor 3 System High Voltage Potential
DTC U0002 CAN Bus Off
DTC U0100 Lost Communication With ECM
Diagnostic trouble code_U029D: CAN Communication Error Between DCU-Ft NOx Sensors
Diagnostic trouble code_U029E: CAN Communication Error Between DCU-Rr NOx Sensors
J HYDRAULIC EQUIPMENT (PUMP, OPERATION SYSTEM VALVE)
Hydraulic Device
Hydraulic Pump (LC)
Hydraulic Pump (Blade)
Control-related
Control Valve (LC)
Control valve (Blade)
Solenoid Valve (4 stack)
Remote Control Valve for Left/Right Operations
Remote Control Valve for Travel Operation
Valve for Blade Operation
Remote Control Valve Characteristic Diagram
Operation Remote Control Valve Control Diagram
Travel Remote Control Valve Control Diagram
Blade Remote Control Valve Control Diagram
Cushion Valve (with Heat Circuit, Shuttle Valve)
Selector Valve
Relief Valve (Electromagnetic Proportional)
Basic Functions
Oil temperature gauge
Static Horsepower Control
Overload Warning (Function for Europe Only)
Pressure Boost Control
Stroke Control
Boom Down Energy Save
Pump Horsepower Boost Control
Arm 1 Semi-parallel Control
Arm 2 Semi-parallel Control
Hot Shutdown Warning
Gate Lock
Breaker Mode
Crusher Mode
Quick coupler
Hydraulic Oil Filter Clog
Solenoid Sticking Prevention
Port Diagram
Hydraulic Pump (standard model)
Control valve
4 Stack Solenoid Valve
2 Stack Solenoid Valve
Remote Control Valves (upper, travel)
Remote Control Valves (left and right)
Remote control valve (travel)
Remote Control Valve (blade)
Cushion valve
2-way Selector Valve
Direction Valve
Reducing valve (4-line)
Relief Valve (electromagnetic proportional)
Manifold Under Cab
Manifold (accumulator section)
Hydraulic tank
Type Indication
Specifications
Hydraulic Pump Internal Structure Diagram
Overall View
Drive Shaft Front Side
Drive Shaft Rear Side
Development Diagram
Part Table
Regulator
Regulator Operation Explanation
Regulator Operation Explanation Diagram
Internal Configuration Diagram of Regulator
Development Diagram of Regulator
Component Table
Operation Outline of Electronically-Controlled Pump
Control Valve
Basic Configuration
Operation
Operation of Main Unit
Activation of Relief Valve
4 Stack Solenoid Valve Operation Explanation
External Shape Diagram and Component Parts
Upper Pilot Valve (remote control valve)
Structure
Function
Operation
Structural Diagram
Travel Pilot Valve (remote control valve)
Operation
Pressure Reducing Valve Section
Damping Mechanism in Operation Section
Structural Diagram
Cushion Valve
Structure
Selector Valve (2-way)
Structure
Development Diagram
Direction Valve (3-direction)
Structure
Electromagnetic Relief Valve
Structure
Operation of Check Valve
Operation of Electromagnetic Relief Valve
Removal and Installation of Hydraulic Reservoir
Removal of Hydraulic Reservoir
Installation of Hydraulic Tank
Removal and Installation of Hydraulic Pump
Removal of Hydraulic Pump
Removal and Installation of Pump coupling
Removal of Pump Coupling
Installation of Pump Coupling
Removal and Installation of Control Valve
Removal of Control Valve
Removal and Installation of Travel Remote Control Valve
Removal of Travel Remote Control Valve
Removal and Installation of Operation Remote Control Valve
Removal of Operation Remote Control Valve (left side)
Installation of Operation Remote Control Valve (left side)
Removal of Operation Remote Control Valve (right side)
Installation of Operation Remote Control Valve (right side)
Removal and Installation of 4 Stack Solenoid
Removal of 4 Stack Solenoid Valve
Installation of 4 Stack Solenoid Valve
Removal and Installation of Cushion Valve
Removal of Cushion Valve
Removal and Installation of 4 Stack Reducing Valve
Removal of 4 Stack Reducing Valve
Procedures for Assembly and Disassembly of Hydraulic Pump Main Unit
Tools
Assembly Procedure
Pump Main Unit Maintenance Standards
Replacement standards for worn parts
Standards for repairing cylinders, valve plates, and swash plates (shoe plates)
Tightening torque
Overall View
Development Diagram
Part Table
Regulator Adjustment
Appendix Table and Drawings
Regulator Assembly and Disassembly Procedures
Tools
Preparations for Disassembly
Assembly Procedures
Component Table
Procedures for Assembly and Disassembly of Control Valve
Disassembly
Caution for Disassembly
Cleaning
Inspection
Assembly
Internal Structural Diagram
part list
Relief Valve
Assembly and Disassembly Procedure of Main Relief Valve
Assembly and Disassembly Procedures of Overload Relief
Assembly and Disassembly Procedure of Main Relief Valve for Add-On
Assembly and Disassembly Procedure of Negative Control Relief Valve
Adjustment of Relief Valve
Installation
Operation
Malfunction and Countermeasure
Procedures for Assembly and Disassembly of Operation Remote Control Valve
Maintenance Procedures
Required Tools and Tightening Torque
Assembly Procedures
Causes of Trouble and Countermeasures
Procedures for Assembly and Disassembly of Travel Remote Control Valve
Assembly Procedures
Causes of Trouble and Countermeasures and Cross-section Diagram
Assembly and Disassembly of Cushion Valve
Reverse Operation Spool
Check Plunger With Orifice
Shuttle valve
Assembly Procedures
Check Plunger with Orifice
Shuttle Valve
Document
Procedures for Pressure Measurement from the Monitor Display
Monitor and Switch Panel
Pressure Measurement Method
Operating Method
PROCEDURES FOR MEASURING HYDRAULIC OIL TEMPERATURE FROM THE MONITOR DISPLAY
Hydraulic Oil Temperature Measurement Method
Operating Method
Procedures for Pressure Measurement by Installing Pressure Gauge
Preparations
Items to Prepare
Pressure Measuring Port
Control Valve
Location of Relief Valves
Pressure Measurement Preparations
A Attachment Pressure Measurement
Boom-down Pressure Measurement
D Option Line Pressure Measurement
Pilot Pressure Measurement
Pressure Gauge Installation
Negative Control Pressure Measurement
Pressure Adjustment
Main Pressure Adjustment
Pressure Measurement and Adjustment Preparations
Main Relief Pressure Adjustment
Overload Relief Pressure Adjustment
Adjustment of Swing Relief Pressure
Pilot Pressure Adjustment
Hydraulic Pump Flow Measurement Procedures
Preparations
Items to Prepare
Work Preparations
Flow Measurement
Air Bleed Procedure
Sampling Procedure
Sampling of Hydraulic Fluid
Hydraulic Equipment Layout
Overall View
Pump Chamber Hydraulic Equipment Layout
Swing Body Center Section Hydraulic Equipment Layout
Housing Left Side Hydraulic Equipment Layout
Layout of Hydraulic Equipment in Cab
N CAB
Removal and Installation of Service’s Seat
Removal of Service’s Seat
Removal and Installation of Cab Assembly
Removal of Cab Assembly
Removal and Installation of Wiper
Removal of Wiper
Installation of wiper
Removal and Installation of Cab Windshield
Removal of Cab Windshield
Installation of Cab Front Glass
Window Lock Adjustment Procedure
Window Lock (front side)
Window Lock (rear side)
Removal and Installation of Housing Guardrail
Removal of Housing Guardrail
Tightening torque
R ELECTRICAL PARTS
Basic Functions
Monitor Control
Monitor Display Dimming
Diagnostic trouble code indicator
Clock
Basic Operation
Battery save
Working Light
LED Light
Room Lamp
Radio mute
Wiper and Washer
Safety
Horn
Back/Side View Monitor
Precautions for Camera Installation
Switching of Camera Input
Maintenance
Anti-theft
Manual Lock
Service Support Screen Lock
Customer-specific System Information Screen Lock
Maintenance Information Screen Lock
Option Line Setting Screen Lock
Setting
Clock Adjustment
Screen Brightness Setting
Battery disconnect switch
Explanation of Controller
Service Support
Screen Operations
Screen Display List
Service Monitor Structure
CHECK Screen List
MACHINE STATUS
HYDRAULIC STATUS
ENGINE STATUS
FAULT HISTORY
WORK HISTORY
HYDRAULIC HISTORY
ENGINE HISTORY
DEVICE TEST
ECM/DCU Memory Clear
SCR Regeneration
Urea line leak test
CCV Operation Test
Dosing test
Reverting valve test
Common rail pressure test
Idle speed test/injector test
EGR valve control test
VG turbo control test
Intake throttle control test
Turbo Boost Pressure Test
CONTROL UNIT Screen List
MCM-MAIN
MCM-SUB1
COMMU TERMINAL
MONITOR
SETUP Screen List
MACHINE SELECT
DIMENSIONS
PARAMETERS
ENGINE INFORMATION
ENGINE INFORMATION
Data check
Data transfer (copy)
QR (INJECTOR) CODE
Injector number
Screen Layout
Data Source Selection
Manual Input
Message Area
CAMERA
PASSWORD
CALIBRATE Screen List
THROTTLE VOLUME
OPT LINE RELIEF
PUMP FLOW
RESET Screen List
Connection Connector Pin Layout
Main Controller
Monitor
Sequence Circuit Diagram
Code List
Overall
Block diagram
Main controller
DCU
ECM
Monitor
Air conditioner
Gate Lock
Option
Others
Electrical Symbol List
Electrical Equipment Layout Diagram
Main Unit Left-side Layout Diagram
Engine Section Layout Diagram
Main Unit Right Rear Section Layout Diagram
Main Unit Right Front Section Layout Diagram
Cab Layout Diagram 1
Cab Layout Diagram 2
Layout Around Service Seat
Stand Alone Parts Diagram
Removal and Installation of Wiper Controller
Removal of Wiper Controller
Installation of wiper controller
Removal and Installation of Wiper Motor
Removal of Wiper Motor
Installation of wiper motor
Removal and Installation of ECM
Removal of ECM
Installation of ECM
Removal and Installation of Main Controller
Main controller Removal
Removal of DCU
Installation of DCU
Removal and Installation of Monitor
Removal of Monitor
Removal and Installation of Rear View Camera
Removal of Rear View Camera
Removal and Installation of Side Camera (Right)
Removal of Side Camera (Right)
Removal and Installation of Side Camera (Left)
Removal of Side Camera (Left)
Removal and Installation of Ambient light
Removal of Ambient Light
Installation of Ambient Light
Removal and Installation of WAVES Controller
Removal of WAVES Controller
How to Set WAVES
Air Conditioner Overall Diagram
Frame
Circuit Diagram
Air Conditioner Circuit Diagram
Explanation of Functions
Air Mix Motor Actuator Control
Blow Mode Motor Actuator Control
Refresh/Recirculate Switch Motor Actuator Control
Blower Amp Control
Compressor Clutch Control
COOLMAX Control and HOTMAX Control
Abnormality Detection and Control after Abnormality Detected
Monitor Mode
Door Switch Control
Actuator Inspection
Air Mix Motor Actuator Inspection
Refresh/Recirculate Switch Motor Actuator Inspection
Mode Motor Actuator Inspection
Self-diagnosis Function with Panel Display
Abnormality Display and Self-check Procedures
Abnormality Display Position
Explanation of Abnormality Display
Motor Actuator Abnormality
Sensor Abnormality
Explanation of Monitor Mode
Monitor Mode Display Position
Monitor Mode Display Operating Method
Display Contents in Monitor Mode
Air Conditioner Troubleshooting
Part Function and Good/Poor Judgment
Control Panel
Blower Amp
Relay
Air Mix Actuator
Refresh/Recirculate Actuator
Mode switch actuator
Evaporator Sensor
Dual Pressure Switch
Solar Radiation Sensor
Inside Air Sensor
Assembly and Disassembly of Unit
Removal of Blower Unit
Replacement of Blower Motor
Replacement of Blower Amp
Removal of Heater Core
Removal of Switchover BOX
Replacement of Evaporator and Expansion Valve
Installation of Evaporator Sensor
Replacement of Motor Actuator
Removal and Installation of Compressor
Removal of Compressor
Removal and Installation of Condenser
Removal of Condenser
Removal and Installation of Receiver Dryer
Removal of Receiver Dryer
Work Precautions
Work Procedures
Air Conditioner Refrigerant Filling is Divided into the “Vacuum Operation” and “Gas Filling Operation”
Operation Chart
Tools
Filling Procedures
Charging Hose Connection Position
Connecting Gauge Manifold
Vacuuming
Gas Filling Operation, High-pressure Side
Gas Filling Work, Low Pressure Side
V ATTACHMENTS
Backhoe Attachment
Cylinder
Cylinder (Blade)
Attachment (Backhoe)
1 Boom and Swing Frame Installation Section
2 Boom Cylinder and Swing Frame Installation Section
3 Boom and Boom Cylinder Installation Section
4 Boom and Arm Cylinder Installation Section
5 Boom and Arm Installation Section
6 Arm and Arm Cylinder Installation Section
7 Arm and Bucket Cylinder Installation Section
8 Arm and Arm Link Installation Section
9 Bucket and Bucket Link Installation Section
10 Bucket Link and Bucket Cylinder Installation Section
11 Bucket and Arm Installation Section
Dozer Blade
1 Blade Cylinder Installation Section
2 Lower Frame and Blade Cylinder Installation Section
3 Lower Frame and Blade Installation Section
Removal and Installation of Bucket Cylinder
Removal of Bucket Cylinder
Removal and Installation of Arm Cylinder
Removal of Arm Cylinder
Removal and Installation of Boom Cylinder
Removal of Boom Cylinder
Removal and Installation of Blade Cylinder
Removal of Blade Cylinder
Procedures for Operation/Assembly and Disassembly of Hydraulic Cylinder
Specifications and Structure Diagram (including the assembly diagram and parts table)
Basic Functions
Function of Each Location
Cylinder Head Assembly (made by KYB)
Piston Assembly (made by KYB)
Pipe Assembly (made by KYB)
Handling Precautions
Precautions for Installing the Cylinder on the Machine Body
Usage Cautions
Maintenance and Inspection Cautions
Maintenance Inspection and Service
Trouble Diagnostics
Storage Standards
Storing Parts Individually (In principle, store indoors )
When Mounted on Vehicle Body
Recommended Anti-rust Oil
Preparations ····· Prepare the Following before Starting Disassembly
Inspection after Assembly
Required Tool
General Tool
Special Jig (made by KYB)
Special Jig Parts Number List (made by KYB)
Disassembly Procedures (made by KYB)
Assembly Procedures (made by KYB)
Test Operation
Usage Limits
Structural Diagram (made by KYB)
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Blade Cylinder
HBCV
structure
Function
operation explanation
Port Diagram
HBCV
Air Bleed Procedure
HBCV
Boom Cylinder HBCV
Arm Cylinder HBCV
Removal and Installation of HBCV
Removal and Installation of Arm HBCV
Removal of arm HBCV
Removal and Installation of Boom HBCV
Removal of Boom HBCV
Installation of boom HBCV
Removal of Bucket
Removal and Installation of Bucket Link
Removal of Bucket Link
Removal of Arm
Installation of Arm
Removal of Boom
Removal of Blade
Blade Installation
Z OTHER
Change from Type 6
Overall Layout
Hydraulic-related Data
Oil Pressure Control
Cab, House
Electrical Data
Electric Control
Specifications (145X4) (LC Specifications)
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
Service ENVIRONMENT
UNDERCARRIAGE
MASS
DIGGING FORCE (with 0 5 m3 Sumitomo Bucket) (ISO 6015)
DIMENSIONS
WORKING RANGES
SYSTEM FLUID CAPACITIES AND SPECIFICATIONS
Specifications (145X4) (Blade Specifications)
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
Service ENVIRONMENT
UNDERCARRIAGE
DOZER BLADE
MASS
DIMENSIONS
WORKING RANGES
Arm Dimensions
Standard Arm [2 50 m (8 2021 ft )]
Short Arm [2 11 m (6 9226 ft )]
Long Arm [3 01 m (9 8753 ft )]
Main Unit Weight
Divided Weight (LC Specifications)
Divided Weight (Blade Specifications)
Stand Alone Part Weight
Shoe Weight (per Side) (LC Specifications)
Shoe Weight (per Side) (Blade Specifications)
Arm Weight
Bolt Size and Torque Table
Special Torque Setting
Overall View
145X4 (LC Specifications) (Grouser Shoe)
145X4 (LC Specifications) (Link Chain)
145X4 (Blade Specifications) (Grouser Shoe)
145X4 (Blade Specifications) (Link Chain)
WORK RANGE DIAGRAM
New Machine Performance Judgment Table
Table of Standards
Measurement Method
Engine Speed
Pressure in Each Section
Pump command displacement
Cylinder Falling Amount
Attachment Speed
Swing Speed
Swing (180°) Brake Angle
Travel Speed
Travel Deviation
Travel Sprocket Speed
Shoe Tension Amount
Swing Ball Race Bearing Movement Amount and Bucket Tip Movement Amount
FLUIDS AND LUBRICANTS
HYDRAULIC FLUID
Engine Oil
Fuel
Conditions applicable to diesel fuel
Recommended conditions applicable to diesel fuels
Main-Unit-related Diagnostic Trouble Code List
Main Unit-side Trouble
Diagnostic Trouble Code: 7000 Pressure Sensor P1 Abnormality
Diagnostic Trouble Code: 7001 Pressure Sensor P2 Abnormality
Diagnostic Trouble Code: 7002 Pressure Sensor N1 Abnormality
Diagnostic Trouble Code: 7003 Pressure Sensor N2 Abnormality
Diagnostic Trouble Code: 7004 Pressure sensor Boom Cylinder Bottom Abnormality
Diagnostic Trouble Code: 7007 Pressure Sensor Arm Cylinder Rod Abnormality
Diagnostic Trouble Code: 7021 Pressure sensor swing pilot abnormality
Diagnostic Trouble Code: 7023 Pressure sensor arm-in pilot abnormality
Diagnostic Trouble Code: 7040 Level Sensor Fuel Abnormality
Diagnostic Trouble Code: 7041 Temperature sensor hydraulic oil abnormality
Diagnostic Trouble Code: 7065 Pressure sensor boom-up pilot abnormality
Diagnostic Trouble Code: 7067 Pressure sensor bucket-close pilot abnormality
Diagnostic Trouble Code: 7068 Pressure sensor boom-down pilot abnormality
Diagnostic Trouble Code: 7069 Pressure sensor arm-out pilot abnormality
Diagnostic Trouble Code: 7070 Pressure sensor bucket-open pilot abnormality
Diagnostic Trouble Code: 7071 Pressure Sensor Travel Right Pilot Abnormality
Diagnostic Trouble Code: 7072 Pressure Sensor Travel Left Pilot Abnormality
Diagnostic Trouble Code: 7074 Pressure Sensor 1st Option Pilot (Common/Front Press) Abnormality
Diagnostic Trouble Code: 7075 Pressure Sensor Arm Cylinder Bottom Abnormality
Diagnostic Trouble Code: 7078 Pressure Sensor 1st Option Pilot (Back Press) Abnormality
Diagnostic Trouble Code: 7200 Swing Brake Solenoid Abnormality
Diagnostic Trouble Code: 7201 Travel 2nd Speed Switchover Solenoid Abnormality
Diagnostic Trouble Code: 7202 Pressure Boost Solenoid Abnormality
Diagnostic Trouble Code: 7203 Travel Alarm Buzzer Abnormality
Diagnostic Trouble Code: 7206 Option Return Line Switchover Solenoid Abnormality
Diagnostic Trouble Code: 7207 Free Swing Solenoid Abnormality
Diagnostic Trouble Code: 7213 Quick Coupler Buzzer Abnormality
Diagnostic Trouble Code: 7214 Quick Coupler Solenoid Abnormality
Diagnostic Trouble Code: 7247 Boom-2 Down Pilot Proportional Valve Abnormality
Diagnostic Trouble Code: 7249 Bucket-close Pilot Proportional Valve Abnormality
Diagnostic Trouble Code: 7250 Option Relief Pressure Proportional Valve Abnormality
Diagnostic Trouble Code: 7265 Arm 1 Semi-Parallel Proportional Valve Abnormality
Diagnostic Trouble Code: 7270 Tilting 1 Proportional Valve Abnormality
Diagnostic Trouble Code: 7271 Tilting 2 Proportional Valve Abnormality
Diagnostic Trouble Code: 7273 Straight Travel Proportional Valve Abnormality
Diagnostic Trouble Code: 7400 Coolant Temperature Overheating 1
Diagnostic Trouble Code: 7401 Coolant Temperature Overheating 2
Diagnostic Trouble Code: 7404 Oil Temperature Overheating
Diagnostic Trouble Code: 7405 Boost Temperature Overheating 1
Diagnostic Trouble Code: 7406 Boost Temperature Overheating 2
Diagnostic Trouble Code: 7420 Alternator Power Generation Defect
Diagnostic Trouble Code: 7421 Decrease in Coolant Level
Diagnostic Trouble Code: 7422 Decrease in Engine Oil Pressure
Diagnostic Trouble Code: 7423 Air Cleaner Clogging
Diagnostic Trouble Code: 7424 Return Filter Clogging
Diagnostic Trouble Code: 7426 Fuel Filter Clogging 1
Diagnostic Trouble Code: 7427 Fuel Filter Clogging 2
Diagnostic Trouble Code: 7428 Inducement (Remaining Urea Level Low) – Warning
Diagnostic Trouble Code: 7429 Inducement (Remaining Urea Level Low) – Early
Diagnostic Trouble Code: 7430 Inducement (Remaining Urea Level Low) – Final
Diagnostic Trouble Code: 7602: ECM Communication Abnormality
Diagnostic Trouble Code: 7605 ECM Not Matched
Diagnostic Trouble Code: 7606 EEPROM Abnormality
Diagnostic Trouble Code: 7608 Camera Abnormality
Diagnostic Trouble Code: 7612 Air Conditioner Communication Abnormality
Diagnostic Trouble Code: 7613 Monitor communication (CAN) abnormality
Diagnostic Trouble Code: 7618 DCU Communication Abnormality
List of special tools
NUMERICAL VALUE CONVERSION TABLE
Unit Conversion Ratio
Length
Area
Volume
Weight
Pressure
Torque
Temperature
A
Travel Motor Special Tool
145X4
Take-up Roller Special Tool
145X4
Upper Roller Special Tool
130X4/145X4
Lower Roller Special Tool
130X4/145X4
C
Swing Motor Special Tool
145X4
H
Engine Oil Filter Special Tool
130X4/145X4/160X4
Fuel Filter Special Tool
130X4/145X4/160X4
Injector Special Tool
130X4/145X4/160X4
Circuit Test Special Tool
130X4/145X4/160X4
Valve Guide Special Tool
130X4/145X4/160X4
Cylinder Head Special Tool
130X4/145X4/160X4
Head Bolt Special Tool
130X4/145X4/160X4
Crankshaft Special Tool
130X4/145X4/160X4
Valve Spring Special Tool
130X4/145X4/160X4
J
Remote Control Valve Special Tool
130X4/145X4
R
Gas Filling Special Tool
130X4/145X4
V
Attachment Special Tool (for Cylinder Assembly)
Special Jigs Part Number List
Paint Colors
Abbreviation
Brand: Link-Belt
Excavator
SAFETY
Safety
ROPS
A LOWER
Lower Component
Travel Unit
Take-up Roller
Upper Roller
Lower Roller
Recoil Spring
Shoe (LC)
Shoe (Blade)
Center Joint (LC)
Travel Motor
Safety Precautions
Data
Use of Product
Specifications
Type Indication
Part List
Exploded Views
Reduction Gear
Usage Precautions
Line
Hydraulic Fluid
Daily Inspection
Lubricant
Table of Seals
Port Diagram
Travel Motor
Center Joint
Basic Functions
Travel Alarm
Dimension Diagram
Assembly Procedures
Dimension Diagram
Assembly Procedures
Dimension Diagram
Assembly Procedures
Dimension Diagram
Assembly procedures
Dimension Diagram
Assembly Procedures
Safety Precautions
Service Overview
Tools
Tightening Torque
Weight Table
Disassembly
Preparations
Seals
Assembly
Preparations
Assembly Procedure
Drive Sprocket
Take-up Roller
Upper roller
Lower Roller
Inspection Gauge
For Drive Sprocket
For Take-up Roller
For Upper Roller
For Lower Roller
Preparations
Air Bleed Procedure
Travel Motor
Upper Component
Swing Unit
Swing Unit
Hydraulic Motor
Mechanical Brake
Relief Valve
Make-up valve
Bypass Valve
Parts List
Port Diagram
Swing motor
Basic Functions
Swing brake
Swing lock
Swing Speed Limit
Swing Relief Cut
Tools
Jig
Tightening torque
Weight Table
Disassembly
Assembly
Parts List
Preparations
Air Bleed Procedure
Swing Motor
Check
H ENGINE
Engine-related
SCR
Basic Functions
Fuel Gauge
SCR Gauge
Fuel economy gauge
Neutral start
Power-cut Delay
Preheat
Throttle
Idle start
Auto idle
One-touch idle
Auto Warm-up
Idle shut down
Idle up
Work mode control
SCR RE-GEN
Inducement
Air Filter Clogging
Engine stalling
Abnormal Noise
OBD system check
Removal of Radiator
Removal of SCR
Installation of SCR
Lubrication System
Induction System
Exhaust System
Removal of DCU
Installation of DCU
Removal of Injector
Removal of Camshaft
Removal of Flywheel
CKP sensor Removal
CMP sensor Removal
IMT sensor Removal
Sampling Procedure
Engine-side Trouble
ECM Trouble
DCU Trouble
Hydraulic Device
Hydraulic Pump (LC)
Control-related
Control Valve (LC)
Selector Valve
Basic Functions
Stroke Control
Gate Lock
Breaker Mode
Crusher Mode
Quick coupler
Port Diagram
Control valve
Cushion valve
Direction Valve
Manifold Under Cab
Hydraulic tank
Type Indication
Specifications
Overall View
Development Diagram
Part Table
Regulator
Component Table
Control Valve
Basic Configuration
Operation
Structure
Function
Operation
Structural Diagram
Operation
Structural Diagram
Cushion Valve
Structure
Structure
Development Diagram
Structure
Structure
Tools
Assembly Procedure
Tightening torque
Overall View
Development Diagram
Part Table
Tools
Assembly Procedures
Component Table
Disassembly
Cleaning
Inspection
Assembly
part list
Relief Valve
Installation
Operation
Assembly Procedures
Assembly Procedures
Shuttle valve
Assembly Procedures
Shuttle Valve
Document
Operating Method
Operating Method
Preparations
Items to Prepare
Control Valve
Pressure Adjustment
Preparations
Items to Prepare
Work Preparations
Flow Measurement
Air Bleed Procedure
Sampling Procedure
Overall View
N CAB
Removal of Wiper
Tightening torque
R ELECTRICAL PARTS
Basic Functions
Monitor Control
Clock
Basic Operation
Battery save
Working Light
LED Light
Room Lamp
Radio mute
Wiper and Washer
Safety
Horn
Maintenance
Anti-theft
Manual Lock
Setting
Clock Adjustment
Service Support
Screen Operations
Screen Display List
CHECK Screen List
MACHINE STATUS
HYDRAULIC STATUS
ENGINE STATUS
FAULT HISTORY
WORK HISTORY
HYDRAULIC HISTORY
ENGINE HISTORY
DEVICE TEST
SCR Regeneration
Urea line leak test
CCV Operation Test
Dosing test
MCM-MAIN
MCM-SUB1
COMMU TERMINAL
MONITOR
SETUP Screen List
MACHINE SELECT
DIMENSIONS
PARAMETERS
ENGINE INFORMATION
ENGINE INFORMATION
Data check
QR (INJECTOR) CODE
Injector number
Screen Layout
Manual Input
Message Area
CAMERA
PASSWORD
THROTTLE VOLUME
OPT LINE RELIEF
PUMP FLOW
RESET Screen List
Main Controller
Monitor
Code List
Overall
Block diagram
Main controller
DCU
ECM
Monitor
Air conditioner
Gate Lock
Option
Others
Removal of ECM
Installation of ECM
Removal of DCU
Installation of DCU
Removal of Monitor
How to Set WAVES
Frame
Circuit Diagram
Blower Amp Control
Monitor Mode
Door Switch Control
Actuator Inspection
Sensor Abnormality
Control Panel
Blower Amp
Relay
Air Mix Actuator
Evaporator Sensor
Inside Air Sensor
Work Precautions
Work Procedures
Operation Chart
Tools
Filling Procedures
Vacuuming
V ATTACHMENTS
Backhoe Attachment
Cylinder
Cylinder (Blade)
Dozer Blade
Basic Functions
Usage Cautions
Trouble Diagnostics
Storage Standards
Required Tool
General Tool
Test Operation
Usage Limits
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Blade Cylinder
HBCV
structure
Function
Port Diagram
HBCV
Air Bleed Procedure
HBCV
Boom Cylinder HBCV
Arm Cylinder HBCV
Removal of arm HBCV
Removal of Bucket
Removal of Arm
Installation of Arm
Removal of Boom
Removal of Blade
Blade Installation
Z OTHER
Change from Type 6
Overall Layout
Cab, House
Electrical Data
Electric Control
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
Service ENVIRONMENT
UNDERCARRIAGE
MASS
DIMENSIONS
WORKING RANGES
ENGINE
HYDRAULIC SYSTEM
HYDRAULIC CONTROLS
ELECTRICAL SYSTEM
Service ENVIRONMENT
UNDERCARRIAGE
DOZER BLADE
MASS
DIMENSIONS
WORKING RANGES
Arm Dimensions
Main Unit Weight
Arm Weight
Overall View
WORK RANGE DIAGRAM
Table of Standards
Measurement Method
Engine Speed
Attachment Speed
Swing Speed
Travel Speed
Travel Deviation
Shoe Tension Amount
HYDRAULIC FLUID
Engine Oil
Fuel
Length
Area
Volume
Weight
Pressure
Torque
Temperature
A
145X4
145X4
130X4/145X4
130X4/145X4
C
145X4
H
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
130X4/145X4/160X4
J
130X4/145X4
R
130X4/145X4
V
Paint Colors
Abbreviation
- Linkbelt LS108C Parts, Operation Maintenance and Load Chart Manuals
- Linkbelt Greer BBTM-508/BB-509 ANTI TWO-BLOCK ALARM SYSTEM – HYDRAULIC CRANE SYSTEM LAYOUT
- Link Belt 350X3 Excavator Schematic Service Manual
- Linkbet LS 118 Operator's Manual
- Link Belt 145X3 Hydraulic Excavators Operator's Manual
- Link Belt 3400 Quantum Excavator Schematic Shop Manual
- Link Belt HTC86100 Operator's Manual
- Link Belt RTC80130 Parts Manual
- Linkbelt RTC-8065 II Operator's Manual (Spanish)
- Link Belt 2800 Quantum Excavator Shop Manual
- Link Belt RTC-80130 II Operator's Manual
- Linkbelt LS 98 Operator's Manual
- Link Belt 210X2-EX Excavators Parts Manual
- MicroGuard 404 Trouble Shooting Manual
- Linkbelt LS-278 Rated Capacity Limiter Operators Manual
