Martin Welker
104
230,310
Lift-Tek Mast Lift 40-MT 45HR-MT 40-MS 45HR-MS Service Manual 246552R2
Brand: Lift-Tek
Type of Machine: Mast Lift
Model: Lift-Tek 40-MT 45HR-MT 40-MS 45HR-MS Standard And Triple Stage Pantograph Mast And Pantograph
Part Number: 246552R2
Publication Date: 2003
Number of Pages: 96 Pages
Cover
Contents
Special Definitions
Introduction
Section 1
Truck System
Requirements
Mounting Bracket
Installation
Section 2
Mast Installation
Mast Inspection
Chain Lubrication
Upright and Carriage Position, Chain Tension
Channel Lubrication
Mast Skewing
Periodic Maintenance
100 - Hour Inspection
200 - Hour Inspection
Daily Inspection
500 - Hour Inspection
Troubleshooting Chart
Mast Removal
Cylinders
Main Lift Cylinder
Description
Free Lift Cylinder
Description
Cylinder Operation
Main Lift Cylinder Service
Disassembly
Cleaning and Inspection
Reassembly
Free Lift Cylinder Service
Free Lift Cylinder Disassembly
Reassembly
Mast Uprights
Upright Description
Upright Chain Inspection
Chain Length Adjustment
Chain Lubrication
Lift Chains (Standard & TSU)
Chain Removal and Replacement
Primary Cylinder/Carriage Chains (TSUs)
Other Chain Service Notes
Upright & Pantograph
Removal & Replace
Roller Shim Adjustments
Pantograph Removal
Preparation
Upright Removal
Preparation
Upright Disassembly
Rail Cylinders
Rollers and Shims
Free Lift Cylinder Cable, Hose and Chain Sheaves
Removal
Cable and Chain Sheaves
Pantograph Assembly
PANTOGRAPH CARRIAGE ROLLERS
Checks and Adjustments
Upright Rails to Rollers
Roller Clearance Inspection
Determining the Number of Shims needed to make roller adjustments
Pantograph & Fork Carriage Assembly
Preparation
Side Shift Models Only
Standard Models Only
Servicing Fork Carriage
Fork Carriage Removal
Servicing Pantograph Arm Rollers
Cylinder Removal
Tilt Cylinder Overhaul
Preparation Cleaning and Inspection
Disassembly
Reassembly
Reach Cylinder Overhaul
Cylinder Removal
Disassembly
Reassembly
Side Shift Cylinder Overhaul
Cylinder Removal
Disassembly
Reach and Tilt Selector Valve
Preparation
Disassembly
Side Shifter Solenoid Control Valve
Preparation
Removal
Installation
