Lift-Tek 45R-MT Three stage Full Freelift Mast Kion Service Manual 294530
Brand: Lift-Tek
Type of Machine: Mast Lift
Type of Manual: Service Manual, Hydraulic Diagram
Model: Lift-Tek 45R-MT Three stage Full Freelift Mast Kion
Part Number: 294530
Number of Pages: 88 Pages
Cover
Introduction
Special Definitions
Installation
Truck System Requirements
Mast Installation
Mast Inspection
Chain Lubrication
Upright and Carriage Position
Channel Lubrication
Mast Skewing
Internal Reeving Installation
Periodic Maintenance
Daily Inspection
100 - Hour Inspection
200 - Hour Inspection
500 - Hour Inspection
Troubleshooting
Troubleshooting Chart
Service
Mast Removal
Cylinders
Main Lift Cylinder Description
Free Lift Cylinder Description
Cylinder Operation
Main Lift Cylinder Service
Free Lift Cylinder Service
Mast Uprights
Upright Description
Upright Chain Inspection
Chain Length Adjustment
Chain Removal and Replacement
Upright & Pantograph Removal & Replace Roller Shim Adjustments
Upright Removal
Upright Disassembly
Shimming
Pantograph Carriage Rollers
Upright Rails to Rollers
Shim Adjustment
Pantograph & Fork Carriage Assembly
Tilt Cylinder Overhaul
Reach Cylinder Overhaul
Side Shift Cylinder Overhaul
Reach and Tilt Selector Valve
Document Revision Record
Brand: Lift-Tek
Part Number: 294530
Cover
Introduction
Special Definitions
Installation
Mast Installation
Mast Inspection
Chain Lubrication
Channel Lubrication
Mast Skewing
Daily Inspection
Troubleshooting
Service
Mast Removal
Cylinders
Cylinder Operation
Mast Uprights
Upright Description
Upright Removal
Upright Disassembly
Shimming
Shim Adjustment
- Lift-Tek 40D-MT Full Freelift Three stage Triple Mast Part Manual 7312855
- Lift-Tek E50-MT Triple stage Mast Part Manual 279426
- Lift-Tek 40TD-MT Three Stage Full Freelift Part Manual 261147R02
- Lift-Tek E60-MD Dual E Series Mast Part Manual 246842R3
- Lift-Tek 45D-MQ Four Stage Mast Part Manual 208943
- Lift-Tek E60-MT Triple Stage Mast Part Manual 279430
- Lift-Tek 45DV-MQ Full Freelift Four Stage Opti-Vis Quad Mast Part Manual 263918
- Lift-Tek E65-MT Triple Stage Mast Part Manual 279438
- Lift-Tek ES30-MS To EV60-MS Limited Free Lift 2-Stage Mast Service Manual 253176R3
- Lift-Tek 50D-MD Dual Mast Unlimited Freelift 2-Stage Part Manual 235895R1
- Lift-Tek ES30-MT To EV60-MT Full Free Lift 3-Stage Mast Service Manual 248645R3
- Lift-Tek 50D-MS Standard Mast Part Manual 235891R4
- Lift-Tek ES40-MT Triple E Series Mast Part Manual 269180R1
- Lift-Tek 50D-MT Three Stage Mast Part Manual 212703R05
- Lift-Tek ET50-MT Triple Stage Full Freelift Mast Part Manual 273796
