Martin Welker
104
230,310
Lift-Tek 35DV-MQ Full Freelift Four stage Opti-Vis Quad Mast Part Manual 263917
Download this document, you need 250 Gallons
Brand: Lift-Tek
Type of Machine: Mast Lift
Type of Manual: Part Manual
Model: Lift-Tek 35DV-MQ Full Freelift Four stage Opti-Vis Quad Mast
Part Number: 263917
Number of Pages: 83 Pages
Cover
Introduction
Safety Decals
Cylinders
Free Lift Cylinder
Free Lift Cylinder - Cold Storage
Right Hand Main Lift Cylinder
Right Hand Main Lift Cylinder - Cold Storage
Right Hand Main Lift Cylinder - External Drain
Left Hand Main Lift Cylinder
Left Hand Main Lift Cylinder - Cold Storage
Left Hand Main Lift Cylinder - External Drain
Weldments
Hoist Chains and Free Lift Hoses
Carriages
4 Roller Carriages
6 Roller Carriages
Side Shift Carriage Assembly - CL II, 4R, 3” UC
Side Shift Carriage Assembly - CL II, 4R, 5”UC
Side Shift Carriage Assembly - CL II, 6R, 3” UC
Side Shift Carriage Assembly - CL II, 6R, 5” UC
Side Shift Carriage Assembly - CL II, 6R, 3.7” UC
Side Shift Carriage Assembly - CL II, 6R, 3” UC OEM Custom
Side Shift Carriage Assembly - CL II, 6R, Camera Kit
ISS Fork Positioner Kit
Lowering Control Valve
Slack Chain Valve
Lower Back Rest
Cable Kit - Camera
Internal Hose Reeving
Single Function OPTI-VIS IHR
Single Function IHR - High Pressure
Single Function OPTI-VIS IHR With High Pressure Rear Hoses
Single Function OPTI-VIS IHR With ORFS Fittings
Single Function OPTI-VIS IHR With ORFS Fittings and Female Termination
Double Function OPTI-VIS IHR
Double Function IHR - High Pressure
Double Function OPTI-VIS IHR With High Pressure Rear Hoses
Double Function OPTI-VIS IHR With ORFS Fittings
Double Function OPTI-VIS IHR With ORFS Fittings and Female Termination
Cable Hardware
RH Single Function - Cable Hardware Kit
LH Single Function - Cable Hardware Kit
Double Function - Cable Hardware Kit
Recommended Spare Parts List
Document Revision Records
