118
6,911
Kubota GAS Engine WG1605G Supplement Parts Catalog 4100068 2014
Brand: Kubota, PowerBoss
Type of Machine: GAS Engine
Type of Manual: Supplement Parts Catalog
Model: Kubota WG1605G GAS Engine
Part Number: 4100068
Publication Date: 2014
Number of Pages: 46 Pages
Preface
Crankcase - 000100
Oil Pan - 000200
Cylinder Head - 000300
Gear Case - 000400
Head Cover - 000500
Oil Filter - 000600
Dipstick And Guide - 000700
Main Bearing Case - 010000
Camshaft And Idle Gear Shaft - 010100
Piston And Crankshaft - 010200
Flywheel - 010300
Sensor - 026000
Ignition Coil - 030200
Cover - 030500
Stop Solenoid - 030800
Alternator And Pulley - 040200
Alternator [Component Parts] - 040300
Starter - 040400
Starter [Component Parts] - 040500
Oil Switch/Thermometer/Plug - 040600
Water Flange And Thermostat - 050000
Water Pump - 050100
Water Pipe - 050300
Fan - 050400
Reserve Tank - 050500
Valve And Rocker Arm - 060000
Inlet Manifold - 060100
Exhaust Manifold - 060200
Wire Harness - 080600
Ecu - 080700
Accessories And Service Parts - 080800
Label And Operator's Manual - 080900
Upper Gasket Kit [Option] - 090001
Lower Gasket Kit [Option] - 090002
Metal Kit [Option] - 090100
Piston Kit [Option] - 090300
Option - 090600
Direct Sales - 091000
Warranty
Notes
