wiq
1
377
#13
Welcome,
I am having problem with unpacking the package.
Password seems ok since it starts unpacking but I get error CRC part06, part14, part24 and part27. (I am using password @$%#dhtauto.com@komatsu)
Anybody had similar problem? I have downloaded this files twice but didn't work.
Anybody could suggest me what to do to unpack this or to check if the files are valid?
Master
Cleaner
635
851,251
#14
Welcome,
I think that.
The first you can download again those file and unwinrar one more.
The second you can unwinrar with broken file.
May be got some problems when you download. Please try again and tell me.
wiq
1
377
#15
Finally got to it
Welcome,
I was sure I have posted it but don't see it coming so once again:
The password was incorrect. After some digging I have find out that the proper password for this files is: df3@54bg@dhtauto.com&&^8
Best regards.
hamed90
5
294
#17
question
Welcome,
Best regards.
hi
password is correct. i download and install the software and it works. but when i'm trying to open some books like hd465-7r sn 15001 and up, in the engine (saa6d170e-5br-w sn 610001-up) see the below error:
the book saa6d3gc from komatsu is not available!
so many other books have this problem only in engine parts.
does anybody know the solution?
thanks in advance.
Master
Cleaner
635
851,251
#18
hi
thanks in advance.
Hi you, let me check now. Don't worry.
Alcoholahmed
4
hi
thanks in advance.
Installation Instructions:
1. Download the program
2. Install LinkOne (probably a .dll error will appear, but it's ok, anyways it will work)
3. Apply Licenses
4. Each Book must be renamed to KOMATSU....that is the trick. So you can copy all models into one folder, but that folder has to be named KOMATSU because LinkOne is configured that way.
5. Open LinkOne Administration, then open Books TAB
6. Press the ICON on the left side of that window (the one that seams some books). If you point the mouse over that ICON it will appear as description ADD LIBRARY
7. Select the Folder named KOMATSU
That's all.
hamed90
5
294
#20
3. Apply Licenses
That's all.
thats it. you are right. the problem solved.
