Komatsu Engine SA6D140E-3 Parts Catalog
Model: Komatsu SA6D140E-3 Engine
Number of Pages: 95 Pages
SA6D140E-3 S N .-UP
HEAD COVER BOLT
AIR INTAKE MANIFOLD AND AFTER COOLER
AFTER COOLER WATER PIPING
AIR CLEANER (INNER PARTS)
TURBOCHARGER AND OIL PIPING
TURBOCHARGER (KTR110L-3H4E) (INNER PARTS)
CYLINDER BLOCK COVER AND OIL FILLER (WITH WATER TEMPERATURE SENSOR)
FRONT COVER MOUNTING AND BREATHER
CAM FOLLOWER COVER
VIBRATION DAMPER
CAM FOLLOWER
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING
FUEL SUPPLY RETURN PIPING
FUEL SUPPLY PUMP (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS)
COMMON RAIL (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVER
FUEL PIPING
FUEL SUPPLY PUMP LUBRICATOR
FUEL FILTER (THREAD 1-1 4)
FUEL INJECTOR
FUEL RETURN PIPING
FUEL CONTROL (CHASSIS MOUNT)
THERMOSTAT AND AIR VENT
FAN PULLEY AND V-BELT
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
STARTING MOTOR MOUNTING (11KW)
WIRING (1 3) SWITCH AND HEATER
WIRING (2 3) FUEL INJECTOR
WIRING (3 3) SENSOR
FRONT GEAR COVER (WITHOUT COMPRESSOR)
GASKET SET (CYLINDER HEAD)
GASKET SET (CYLINDER BLOCK)
GASKET SET (WATER PUMP)
NAME PLATE AND CAUTION PLATE
SA6D140E-3 S N .-UP
HEAD COVER BOLT
CAM FOLLOWER COVER
VIBRATION DAMPER
CAM FOLLOWER
FUEL PIPING
FUEL INJECTOR
FUEL RETURN PIPING
WIRING (3 3) SENSOR
