Komatsu Engine SA6D140E-3 Parts Catalog
Model: Komatsu SA6D140E-3 Engine
Number of Pages: 95 Pages
SA6D140E-3 S N .-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD AND AFTER COOLER
AFTER COOLER WATER PIPING
AIR CLEANER
AIR CLEANER (INNER PARTS)
EXHAUST MANIFOLD
TURBOCHARGER AND OIL PIPING
TURBOCHARGER (KTR110L-3H4E) (INNER PARTS)
HEAT SHIELD
MUFFLER
CYLINDER BLOCK
CYLINDER BLOCK COVER AND OIL FILLER (WITH WATER TEMPERATURE SENSOR)
FRONT COVER
FRONT COVER MOUNTING AND BREATHER
IDLER GEAR
CAM FOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
ROCKER ARM
CAM FOLLOWER
OIL PUMP
OIL FILTER
OIL COOLER
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING
FUEL SUPPLY RETURN PIPING
FUEL SUPPLY PUMP (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS)
COMMON RAIL (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVER
FUEL PIPING
FUEL SUPPLY PUMP LUBRICATOR
FUEL FILTER (THREAD 1-1 4)
FUEL INJECTOR
FUEL RETURN PIPING
FUEL CONTROL (CHASSIS MOUNT)
WATER PUMP
THERMOSTAT AND AIR VENT
COOLING FAN
FAN PULLEY AND V-BELT
FAN DRIVE
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
WIRING (1 3) SWITCH AND HEATER
WIRING (2 3) FUEL INJECTOR
WIRING (3 3) SENSOR
FRONT GEAR COVER (WITHOUT COMPRESSOR)
GASKET SET (CYLINDER HEAD)
GASKET SET (CYLINDER BLOCK)
GASKET SET (WATER PUMP)
NAME PLATE AND CAUTION PLATE
