Komatsu Engine SA6D140-1B 10185-UP Parts Catalog
Model: Komatsu SA6D140-1B Engine
Serial Number: 10185-UP
Number of Pages: 154 Pages
SA6D140-1B S N 10185-UP
AIR INTAKE MANIFOLD AND AFTER COOLER (EXCEPT JAPAN)
WATER PIPING
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT
OIL PAN (WITH OIL LEVEL SENSOR)
OIL PAN (WITHOUT OIL LEVEL SENSOR)
OIL PAN (COLD TERRAIN SPEC.)
LUBRICATING OIL FILTER AND FUEL FILTER
LUBRICATING OIL ADAPTER
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.)
LUBRICATING OIL FILTER AND FUEL FILTER AND PIPING
FUEL INJECTION PUMP (PUMP) (1 2) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (EXHAUST GAS REGULATION) (INNER PARTS)
WATER PUMP AND MOUNTING
COOLING FAN AND TENSION PULLEY
CORROSION RESISTOR AND PIPING (EXCEPT JAPAN)
ALTERNATOR AND MOUTING
STARING MOTOR AND MOUNTING
ACCESSORY
AIR COMPRESSOR AND MOUNTING (EXCEPT JAPAN)
AIR COMPRESSOR PIPING
AIR COMPRESSOR (INNER PARTS)
TOOL AND KIT
