Komatsu Engine SA6D140-1B 10185-UP Parts Catalog
Model: Komatsu SA6D140-1B Engine
Serial Number: 10185-UP
Number of Pages: 154 Pages
SA6D140-1B S N 10185-UP
CYLINDER HEAD
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR INTAKE MANIFOLD AND AFTER COOLER (EXCEPT JAPAN)
EXHAUST MANIFOLD AND TURBOCHARGER
TURBOCHARGER (INNER PARTS)
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT
IDLER GEAR
OIL PAN
OIL PAN (WITH OIL LEVEL SENSOR)
OIL PAN (WITHOUT OIL LEVEL SENSOR)
OIL PAN (COLD TERRAIN SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER AND FUEL FILTER
LUBRICATING OIL ADAPTER
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
LUBRICATING OIL FILTER AND FUEL FILTER AND PIPING
WATER SEPARATOR
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP) (1 2) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (PUMP) (2 2) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (3 3) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (COUPLING) (EXHAUST GAS REGULATION) (INNER PARTS)
FUEL INJECTION PUMP (FEED PUMP) (EXHAUST GAS REGULATION) (INNER PARTS)
COOLING SYSTEM
WATER PUMP AND MOUNTING
COOLING FAN AND TENSION PULLEY
CORROSION RESISTOR AND PIPING (EXCEPT JAPAN)
ELECTRICAL SYSTEM
ALTERNATOR AND MOUTING
STARING MOTOR AND MOUNTING
ACCESSORY
AIR COMPRESSOR AND MOUNTING (EXCEPT JAPAN)
AIR COMPRESSOR PIPING
AIR COMPRESSOR (INNER PARTS)
TOOL AND KIT
GASKET KIT
CYLINDER HEAD
WATER PIPING
CYLINDER BLOCK
IDLER GEAR
OIL PAN
CRANKSHAFT
CAMSHAFT
FUEL SYSTEM
WATER SEPARATOR
COOLING SYSTEM
ELECTRICAL SYSTEM
ACCESSORY
TOOL AND KIT
GASKET KIT
- KOMATSU Fault Codes
