Komatsu Engine S6D140-1R 10001-UP Parts Catalog
Model: Komatsu S6D140-1R Engine
Number of Pages: 116 Pages
S6D140-1R S N 10001-UP
AIR CLEANER AND MOUNTING
AIR CLEANER AND MOUNTING (WITH INTAKE EXTENSION)
MUFFLER AND MOUNTING (AIR CLEANER WITH AIR INTAKE EXTENSION)
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT (WITH P.T.O.)
FRONT COVER AND FRONT SUPPORT (WITHOUT P.T.O.) (EXCEPT JAPAN)
OIL PAN (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
ENGINE STOP MOTOR AND MOUNTING
WATER SEPARATOR AND MOUNTING
ADDITIONAL FUEL FILTER
WATER PUMP AND MOUNTING
COOLING FAN AND TENSION PULLEY
CORROSION RESISTOR AND PIPING (EXCEPT JAPAN)
ALTERNATOR AND MOUNTING (50A)
STARTING MOTOR AND MOUNTING (7
ALTERNATOR (50A) (WITH NON HARDENING PULLEY)
ALTERNATOR (50A) (WITH HARDENING PULLEY)
STARTING MOTOR (11KW)
ACCESSORY
AIR COMPRESSOR AND PIPING (EXCEPT JAPAN)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR RELIEF VALVE
AIR COMPRESSOR
TOOL AND KIT
