Komatsu Engine S6D140-1R 10001-UP Parts Catalog
Model: Komatsu S6D140-1R Engine
Serial Number: 10001-UP
Number of Pages: 116 Pages
S6D140-1R S N 10001-UP
CYLINDER HEAD
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR CLEANER AND MOUNTING
AIR CLEANER AND MOUNTING (WITH INTAKE EXTENSION)
EXHAUST MANIFOLD AND TURBOCHARGER
TURBOCHARGER
MUFFLER AND MOUNTING
MUFFLER AND MOUNTING (AIR CLEANER WITH AIR INTAKE EXTENSION)
CYLINDER BLOCK
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT (WITH P.T.O.)
FRONT COVER AND FRONT SUPPORT (WITHOUT P.T.O.) (EXCEPT JAPAN)
IDLER GEAR
OIL PAN
OIL PAN (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER AND MOUNTING
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (COLD TERRAIN SPEC.) (EXCEPT JAPAN)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
ENGINE STOP MOTOR AND MOUNTING
FUEL FILTER AND PIPING
WATER SEPARATOR AND MOUNTING
ADDITIONAL FUEL FILTER
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (COUPLING)
FUEL INJECTION PUMP (FEED PUMP)
COOLING SYSTEM
WATER PUMP AND MOUNTING
COOLING FAN AND TENSION PULLEY
CORROSION RESISTOR AND PIPING (EXCEPT JAPAN)
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING (50A)
STARTING MOTOR AND MOUNTING (7
ALTERNATOR (50A) (WITH NON HARDENING PULLEY)
ALTERNATOR (50A) (WITH HARDENING PULLEY)
STARTING MOTOR (11KW)
ACCESSORY
AIR COMPRESSOR AND PIPING (EXCEPT JAPAN)
AIR COMPRESSOR MOUNTING
AIR COMPRESSOR RELIEF VALVE
AIR COMPRESSOR
TOOL AND KIT
GASKET KIT
CYLINDER HEAD
TURBOCHARGER
CYLINDER BLOCK
IDLER GEAR
OIL PAN
CRANKSHAFT
CAMSHAFT
FUEL SYSTEM
COOLING SYSTEM
ELECTRICAL SYSTEM
ACCESSORY
AIR COMPRESSOR
TOOL AND KIT
GASKET KIT
- KOMATSU Fault Codes
